david johnson Posted September 22, 2012 Report Posted September 22, 2012 Id be interested to know what HP figures uprated engines are getting, and the spec to obtain the figures. My TR3A engine yet to be accurately tested has 89mm liners. Stage 2 gas flowed head. Phoenix long branch manifold and big bore exhaust Electric fan Electronic ignition Dizzy adjusted to suit HS6 carbs Balanced, with lightened flywheel but still with the early inlet manifold. What should I expect at the flywheel' Thanks David Quote
ianc Posted September 22, 2012 Report Posted September 22, 2012 Are you intending to test the engine on a dynamometer prior to installing it in the car? If not, then you can only infer the Brake Horsepower (BHP) from the Horespower (HP) measured at the rear wheels on a rolling road. With that specification, I would expect about 115 HP on a rolling road, which probably means some 135-140 BHP. However, it does depend whose rolling road you use! What is more important than maximum power is the shape of the TORQUE curve - see my article in TR Action 238 (October 2009). For road and rally work, you want a long, high and level torque curve - that gives real enjoyment to your motoring. The rolling road will give you the information and should reveal any deficiencies, such as a dip in the middle of the torque curve - not uncommon in 4-pot engines, it would seem (but scarcely visible in Mike North's TR4 and in my car on the rolling road at Enginuity). Ian Cornish Quote
stuart Posted September 22, 2012 Report Posted September 22, 2012 David it should be what I said to you the other night when you inquired about mine "Sufficient!!" Stuart. Quote
david johnson Posted September 23, 2012 Author Report Posted September 23, 2012 Similar to Adequate then Stuart. As Rolls would say. Don t worry about the nos just enjoy the car. Regards David. Quote
ianc Posted September 23, 2012 Report Posted September 23, 2012 The money spent on a rolling road test is, to my mind, worthwhile as it should result in the elimination of problems and an optimal set-up, which will give performance and economy. I would agree with the descriptions 'sufficient' and 'adequate' - I've never worried about the actual numbers. It's having easy starting and that high, flat and long torque curve that matters - like that, you can really enjoy your motoring. Ian Cornish Quote
Ashley James Posted September 23, 2012 Report Posted September 23, 2012 What head gasket do you use with the 89mm bore? I'm guessing that a millimetre or so of a standard one might protrude into the combustion chamber. I'm surprised you think there should be such a big increase in BHP Ian. The car started with 100 probably gross BHP, lightened flywheels make no difference, nor I suspect do HS6s, getting timing and the distributor correct will only ensure manufacturers figures, a modified head will help the car to rev more freely and power is a function of rpm. Obviously the 89 mm bore will increase compression ratio as well as capacity, so more torque and possibly power, but I'd have thought 5-10 BHP increase max, but a very nice road engine. I know it has a four branch manifold, but wouldn't expect much increase from it, perhaps someone has dyno'd one and can give results. The most effective way to increase power is to increase revs which means a hotter camshaft and the trick is to pick one that doesn't sacrifice too much at the low end, but gives more at the top. I hotted up a 250cc Desmo Ducati once, so instead of about 7,500 it revved with power to 11,500, but below 7500 it spluttered and coughed and then took off like a banshee! Not surprisingly it was rather fragile and only useable for racing. I'm just building an 87 mm engine with the lowest spec fast road cam to see what happens. I don't mean to contradict, so much as to learn what these engines can do. Quote
david johnson Posted September 23, 2012 Author Report Posted September 23, 2012 The rolling road that has given approx 180HP on various local upgraded TR6s to everyones satisfaction has give 120HP on the TR3. Id forgotten the cam has been changed to a KentTR4. id expected more. but it seems stifled by the log type inlet manifold. David. Quote
Ashley James Posted September 23, 2012 Report Posted September 23, 2012 With a cam 120 sounds good and what you'd expect. I should think it goes well. Does it still tick over nicely and is it happy six cars back from yer average dithering slow coach? (null) Quote
david johnson Posted September 23, 2012 Author Report Posted September 23, 2012 Will find out tomorrow Ashley, and report back. Regards David. Quote
ianc Posted September 23, 2012 Report Posted September 23, 2012 I had assumed a modified camshaft - seems I was correct! Best stock inlet manifold is TR4A, which then needs to be fettled - see Kastner's tuning manual. The head, too, needs to be modified as indicated by Kastner. You have to decide just how high you are prepared to rev the engine on a standard crankshaft - as I want mine to last, I use a normal limit of 5000, knowing that it could go to 6000 if necessary. But whereas a standard engine is seeing its torque diminish from about 3800, mine is considerably higher at that point and continues almost level past 5000 - that's what makes the difference on the road. Ian Cornish Quote
david johnson Posted September 24, 2012 Author Report Posted September 24, 2012 Thanks Ian. Which Kastner book, in detail do I need for the manifold fettling. Regards David. Quote
Guest ntc Posted September 24, 2012 Report Posted September 24, 2012 (edited) The rolling road that has given approx 180HP on various local upgraded TR6s to everyones satisfaction has give 120HP on the TR3. Id forgotten the cam has been changed to a KentTR4. id expected more. but it seems stifled by the log type inlet manifold. David. I would try another rolling road, you all maybe then in for a surprise Edited September 24, 2012 by ntc Quote
Ashley James Posted September 24, 2012 Report Posted September 24, 2012 I had assumed a modified camshaft - seems I was correct! Best stock inlet manifold is TR4A, which then needs to be fettled - see Kastner's tuning manual. The head, too, needs to be modified as indicated by Kastner. You have to decide just how high you are prepared to rev the engine on a standard crankshaft - as I want mine to last, I use a normal limit of 5000, knowing that it could go to 6000 if necessary. But whereas a standard engine is seeing its torque diminish from about 3800, mine is considerably higher at that point and continues almost level past 5000 - that's what makes the difference on the road. Ian Cornish Which camshaft are you using Ian? Quote
ianc Posted September 25, 2012 Report Posted September 25, 2012 Kastner's manual is "Triumph Preparation Handbook" - it was available from the Register (contact Brian Sparrowhawk or look at the on-line shop). A mine of useful information as Kas was getting over 150 BHP from a 4-pot in 1961, when the best in the UK were getting 135. It was suggested that he was using 'Californian air', but he came to Britain, fetttled an engine and demonstrated over 150 BHP to Harry Webster and others at Triumph - Harry was so impressed that he arranged shipment of a dynamometer to the US for Kas's use. My camshaft (indeed, my whole engine apart from pistons and liners) is the one in the engine fitted by Gordon Birtwistle in 1967 - I would describe it as a Stage 2 and a bit! I have no figures for it, but the camshaft in Mike North's LNK must be very similar as, on Enginuity's rolling road, we returned almost identical torque and power graphs. Definitely a fast road/rally camshaft, not a racer. You could PM Mike and ask him about his camshaft. I would say that it is important to use a rolling road and operators whom you trust ,and to keep using them, as you'll be looking to remove problems and optimise performance. The figures only tell you whether things are being improved by any changes or adjustments, and are of lesser importance (unless you are an inveterate bragger!). And, as Neil is suggesting, the figures will differ from road to road! Ian Cornish Quote
Ashley James Posted September 25, 2012 Report Posted September 25, 2012 I'm using Moss's lower spec fast road, so I expect it'll be similar. At the moment everything is by the book, so I have a good starting reference and will use a rolling road if in trouble. It can't be the PITA the Bristol was after a camshaft change and it doesn't have Solexes. Quote
TR 2100 Posted September 25, 2012 Report Posted September 25, 2012 I would try another rolling road, you all maybe then in for a surprise Absolutely. Giving encouraging readings is a good way to have the word spread and generate more business. I was rather disappointed with my actual readings, considering the extent of modifications - but the rolling road used was the same one as TR Enterprises use for their rally cars - and I'm told that my reading compared very well (i.e. only a little lower) than a typical 'long distance' rally car. AlanR Quote
John Pardue Posted February 9, 2025 Report Posted February 9, 2025 Don't forget that all these old engines were designed for 100 Octane fuel (5 star). When I used to drive the Triumph 6 cylinder cars back in the 70s, they always used to pink and run on with the 4 star that was the best available back then. I do not think that the six, or even the four, in standard states of tune, will get near to the original bhp values quoted. And like the commentator above, I cannot see how the 100bhp TR3a engine, even with the upgrades, would get near to the 140 bhp mentioned. Quote
Cleo's Dad Posted February 10, 2025 Report Posted February 10, 2025 If it is any help, I have standard engine with stage two head with larger valves, 4 branch exhaust, gas flowed inlet manifold and carbs and electronic ignition and it made 114 bhp at 4500 rpm. on the dyno. Didn't want it reved more than that as the bottom end is all original. Clive Quote
stuart Posted February 10, 2025 Report Posted February 10, 2025 On 2/9/2025 at 10:06 AM, John Pardue said: Don't forget that all these old engines were designed for 100 Octane fuel (5 star). When I used to drive the Triumph 6 cylinder cars back in the 70s, they always used to pink and run on with the 4 star that was the best available back then. I do not think that the six, or even the four, in standard states of tune, will get near to the original bhp values quoted. And like the commentator above, I cannot see how the 100bhp TR3a engine, even with the upgrades, would get near to the 140 bhp mentioned. Ahem I suggest you talk to Darryl at Racetorations about what can be wrung out of a four pot TR engine and its an whole lot more than 140hp. Stuart. Quote
mike ellis Posted February 10, 2025 Report Posted February 10, 2025 On 2/9/2025 at 10:06 AM, John Pardue said: Don't forget that all these old engines were designed for 100 Octane fuel (5 star) The four cylinder TR engines were designed to run on 97 octane but would happily run on 95, even less if the low compression plate was fitted. Mike Quote
Motorsport Mickey Posted February 10, 2025 Report Posted February 10, 2025 (edited) 4 hours ago, Cleo's Dad said: If it is any help, I have standard engine with stage two head with larger valves, 4 branch exhaust, gas flowed inlet manifold and carbs and electronic ignition and it made 114 bhp at 4500 rpm. on the dyno. Didn't want it reved more than that as the bottom end is all original. Clive Clive, Just to clarify, was that on an Engine Dyno, with the engine mounted on it ? or a chassis Dyno (commonly called a Rolling Road). ? It matters. Mick Richards Edited February 10, 2025 by Motorsport Mickey Quote
Hamish Posted February 10, 2025 Report Posted February 10, 2025 When TRE did mine and after run in and some timing and carb tweeks on my local rolling road it was over 155bhp calculated back to the flywheel. Quote
Tony_C Posted February 10, 2025 Report Posted February 10, 2025 That is mighty impressive Hamish!…… (However, possibly begs the question….. WHY AREN’T YOU WINNNG MORE RACES THEN? ) Quote
Hamish Posted February 10, 2025 Report Posted February 10, 2025 1 hour ago, Tony_C said: That is mighty impressive Hamish!…… (However, possibly begs the question….. WHY AREN’T YOU WINNNG MORE RACES THEN? ) ‘Cos I’d like that power at the wheels !!!!! and I’m up against some very good competition and particularly a very modified full race TR4 on slicks with a very ace driver in Len Olds so I’m just 2nd in championship 3 YEARS RUNNING !!! Arrgghhh ( not that I’m bitter ) anyone who can do 3 wheels up Shelsley is going some what makes it worse is he’s such a nice bloke. Come and join us Tony it’d be fun. probably be doing a bit less when the Alvis turns up tho.. Quote
Motorsport Mickey Posted February 10, 2025 Report Posted February 10, 2025 (edited) John, If the 4 cyl is worked and packages of improvement is input, double the engine standard hp numbers are reached. If you’re careful with compressions etc it’s still manageable on the road. Mick Richards Edited February 10, 2025 by Motorsport Mickey Quote
