Badfrog Posted May 18, 2013 Report Posted May 18, 2013 (edited) Hi all, As explained elsewhere, MdW now has her Kastner D cam set correctly at 110°. She goes almost like a dream, but quite too rich and tends to overheat in traffic jams. The cooling system had been set proprely, so I concentrated on the richness. I had SM needles, previously OK but it seems they were no more ideal. As a first move, I stepped down to TW needles and voila: great improv in terms of running, performance AND mileage. Just shows that when you improve and engine, you may not require more petrol but less, as the valve diagram increases the air-fuel mix intake. Going to Spa, will report on the reality of this first impression. Faster and cheaper, story of my life. Badfrog Edited May 18, 2013 by Badfrog Quote
Paul Harvey Posted May 18, 2013 Report Posted May 18, 2013 Faster and cheaper, story of my life. Badfrog Amen to that! Quote
peterm Posted May 20, 2013 Report Posted May 20, 2013 Hi Badfrog, As a matter of interest, what valve clearances do you use with your Kastner cam? Cheers, Peter Quote
Badfrog Posted May 20, 2013 Author Report Posted May 20, 2013 Peter, I use 0.35 mm or 14 thou. Rattles a bit when cold but smooth when warm. Badfrog Quote
Badfrog Posted May 30, 2013 Author Report Posted May 30, 2013 (edited) Hi, More on SU's. I am rebuilding mine to alleviate some throttle disc sticking problem. Going thru on-line catalogs, I realized that discs for AUC 209 and AUC 284 are different (at least in reference). Never paid any attention to this before. This might explain while my relatively recent discs get stuck: I may have the wrong reference in the wrong carb. Mind you, I don't even remember if I have a homogenous pair of carbs. Will rebuild and report. The carelessness of early years ... I was so much younger then, i'm older than that now (Bob Dylan). Badfrog Edited May 30, 2013 by Badfrog Quote
BrianC Posted May 30, 2013 Report Posted May 30, 2013 (edited) The carelessness of early years ... I was so much younger then, i'm older than that now (Bob Dylan). Careless indeed Badfrog ... Ah, but I was so much older then, I'm younger than that now (My Back Pages) Edited May 30, 2013 by BrianC Quote
Fireman049 Posted May 30, 2013 Report Posted May 30, 2013 (edited) Hi Badfrog ~ If you PM me your email address I'll send you a copy of the article I had printed in TRaction a few years ago regarding improving the breathing capabilities of SU carburettors. Regards ~ Tom. Edited May 30, 2013 by Fireman049 Quote
Badfrog Posted May 30, 2013 Author Report Posted May 30, 2013 Careless indeed Badfrog ... Ah, but I was so much older then, I'm younger than that now (My Back Pages) Yes Brian, I remembered it right but then it wouldn't have fit the situation. So I took the liberty of spoofing the good Mr Zimmermann. Bear with me. Badfrog Quote
Badfrog Posted May 30, 2013 Author Report Posted May 30, 2013 Hi Badfrog ~ If you PM me your email address I'll send you a copy of the article I had printed in TRaction a few years ago regarding improving the breathing capabilities of SU carburettors. Regards ~ Tom. Tom, you have PM. Badfrog Quote
Badfrog Posted June 1, 2013 Author Report Posted June 1, 2013 (edited) Tom, I read the TRaction article you sent me. The chamfering of pistons I have done before, with three different angles and amounts of grinding. I finally dropped the matter after reading a comparative paper showing chamfering is deleterious to mix flow speed (can't remember where). Another example of a counter-intuitive notion. So I'm back with normal pistons, but with careful weight equilibration and correct movement in the chamber (the 7 sec. drop theory). The shaft profiling is a good idea, especially as they show it, i.e. not grinding the screw area. I have done this too. Of course my manifold (long one, TR4A) is correctly flowed and I did something more, which is enlarging venturis and manifold entry side to 2". Much better than using straight 2" HS8's. I also changed the 8103 dampers (AUC 284 UK carbs) for 8114 (AUC 209), with SAE30 oïl (chainsaw engine lubricant). I use the standard paper filters for TR4A, not the K&N, as recommended by Paul Tegler. With all this and the correctly set cam (110°) I had to change needles from SM (AUC 209 standard, too rich for adjustment) to TW (AUC 284 standard), which reduced fuel consumption by 10% without performance loss. I use 8.5L/100 km at 90 km/h (27.67 mpg on 55 mph roads). Now I just have to check my throttle disc/shaft combos for correct fit in the venturi. Badfrog PS: a useful converter: http://www.unitjuggler.com/convertir-fuelconsumption-de-lper100km-en-mpg.html Edited June 1, 2013 by Badfrog Quote
Fireman049 Posted June 1, 2013 Report Posted June 1, 2013 (edited) Hello Badfrog ~ Thank you for that. Yes, you're quite right about chamfering the pistons on your HS carbs. The chamfering only applies to the H type carbs and is as recommended in the Vizzard Mini Coper tuning manual. What is the difference in the dampers? Tom. Edited June 1, 2013 by Fireman049 Quote
Badfrog Posted June 1, 2013 Author Report Posted June 1, 2013 Hello Badfrog ~ Thank you for that. Yes, you're quite right about chamfering the pistons on your HS carbs. The chamfering only applies to the H type carbs and is as recommended in the Vizzard Mini Coper tuning manual. What is the difference in the dampers? Tom. Honestly, I have no idea. By experience, the 8103 is larger than the 8114 and seems to restrain more the piston movement. I still have to observe any performance difference. I think I will homogenize my carbs parts to either spec, once I ascertain which ones I have, AUC 209 or 284. Badfrog Quote
BlueTR3A-5EKT Posted June 3, 2013 Report Posted June 3, 2013 Honestly, I have no idea. By experience, the 8103 is larger than the 8114 and seems to restrain more the piston movement. I still have to observe any performance difference. I think I will homogenize my carbs parts to either spec, once I ascertain which ones I have, AUC 209 or 284. Badfrog From memory there is a difference in the length of the barrel bit on the damper shaft of AUC8103 and AUC8114, that restricts the piston lift. A shorter barrel will give a faster initial lift. There is a MG/SU service bulletin about this issue from the 1950's. It advised changing the barrel length to overcome acceleration problems reported by owners (What - a MG without acceleration I hear you gasp!) When I find it I will post it. Cheers Peter W Quote
Badfrog Posted June 3, 2013 Author Report Posted June 3, 2013 Great idea Peter, I'll be happy to clear my views about dampers and may be clear out my collection of these, too. Badfrog Quote
Richard V Posted June 18, 2013 Report Posted June 18, 2013 (edited) Hi JF, Just fitted my TW's in the SU's this evening. Set up planned for tomorrow (yes I now you told me to do this a year ago, but with one thing and another..etc... What did you set your jets to when you moved from SM to TW? (I was at 70 thou with my SM's) thats 17 flats in old money.) I will do some trial and error work tomorrow, but Im interested what you are set at. Set up now; had to wind in the idle stops by a quarter turn and increase the 2 jets. Now at 85thou on the rear carb, and 87thou at the front so as to get good plug colours (light brown). The exhaust note is less roarty with less of the flamboyant "paaarpp" when accelerating, however it is better at idle and start up. I think that the power is still there but I have the impression that the car feels a little more restrained. Not convinced yet, more tweaking needed. Cheers, Richard. Edited June 19, 2013 by Richard V Quote
Peter Cobbold Posted June 18, 2013 Report Posted June 18, 2013 (edited) Badfrog, Counter-intuitive indeed. I am still working to figure out the fluid mechanics of the SU, 'cause I have to for TR6SE. But the chamfering of the leading edge of the piston I think I am on top of. Here's my interpretation. The piston's straight vertical edge is seen in many other carbs, eg Villiers. It seems to me to be designed to act as an 'orifice plate' to sense air flow. The pressure drop it creates follows Bernoulli and is proportional to the square of the air velocity. fig 2.18 here: http://www.ddc-online.org/Input-Output-Tutorial/Flow.html If the base of the piston is chamfered the air velocity will increase locally over the base of the piston, close to the piston/choke vents on an HS8, and lift will increase. It now resembles the venturi of fig 2.19 rather than a straight sided orifice. So there will be more lift even if we dont change the mass air flow. Again by Bernoulli, if chamfering doubles the local velocity the local pressure drop will go up, ideally, 4-fold. So chamfering could have a big effect on lift. That extra lift will completely mess up the calibration of the needle* as we no longer have the same 'constant depression'. But that extra lift might be why its sometimes suggested as a racing mod. *How much exactly? - don't ask! That lower 'constant' depression would suck less fuel. The jet would also see slower air flow, because the piston has lifted more, so fuel flow due to venturi suction also drops . So chamfering will work to reduce suction acting on fuel in the jet. But the needle has been lifted more, its thinner, so more fuel could flow. But its highly unlikely that the balance of suction and fuel annulus stay in balance. Tuning with an AFR sensor seems to me to be the answer, and a means of measuring piston lift to see which bit of the needle to resize, maybe thinner maybe fatter. In the meantime, here's nice cfd picture of a simple carb venturi to look at: - its counterintutive too! Fig 6.6, when the throttle plate is 90 open, there will be maximum amount of air flow through the inlet of the carburetor. In this case the pressure at the throat is found to be 85000 Pascal. source: http://ethesis.nitrkl.ac.in/2296/1/final_report.pdf Cheers Peter Edited June 19, 2013 by Peter Cobbold Quote
Badfrog Posted June 20, 2013 Author Report Posted June 20, 2013 (edited) Richard, Make that a turn and a half, so 9 flats for a beginning. Then refine from there. Cheers, Badfrog Edited June 20, 2013 by Badfrog Quote
Badfrog Posted June 20, 2013 Author Report Posted June 20, 2013 (edited) Peter, Thanks a lot for the infos. Finally, I found it easy to get the crux of it, especially since you showed it to me clear enough: whatever reshaping you do on the piston calls for an adapted needle, taken empirically from a complete stock. Could take years, and practically no rule of thumb, especially on the levels of the needle to modify. My gut feeling is that most of the time chamfering will open the carb too fast for the fuel to follow: instant air, viscous fuel. Hence the idea of long intakes in many cars as a solution for "preloaded" quickly available air-fuel mix. So: 1. either you stick with a specific needle and gradually file the piston, knowing the last filing will get you overboard, 2. or you design a basic shape (on what grounds if you don't have a flow-test bench?) and try to guess the best needle for it. In a nutshell: no rules, takes very specific equipment and won't amount to much if I trust my personal test of 4 different shapes with 10 different needles. Morality, work elsewhere, i.e. flow-in / flow-out: search the best needle for a native carb coupled with an improved camshaft (290° good for all-purpose road fun). Get good air filters with plenty of cfm and no restraint nor back depression. Make sure the block doesn't overheat. Get a good 2" 4/1 exhaust. And voila .... Cheers, Badfrog Edited June 20, 2013 by Badfrog Quote
