I recently bought a beautiful TR4A. On a journey everything was going well when the overdrive stopped working. No drama, no, no noise it just wouldn't switch in or out. I tried the solenoid with the engine off - nothing. Set off again, tried it 10 minutes later, it worked fine and has worked since.
Any ideas ?
Gearbox and overdrive have a common oil sump so check the oil level for a starter.
Peter W
Peter W
There's no Starter in the sump... (Goes and hides!!!) :-)
Cheers!
Ian
Hi Neil,
intermittent faults are very hard to diagnose, unless they are present for a reasonable time.
The column switch is normally good so put that to the back of the checks.
Check all the bullet connectors to ensure they are clean.
It could be the rubber collar around the gear stick pushing the lever just a little to disengage the switches.
Hi Neil
You are best to trace the supply and Earth to the solenoid using the workshop manual circuit diagram.
It sounds like wiring to the solenoid as opposed to separate gearbox switches. My own had a switching problem on 3rd gear only which turned out to be a separate selector switch.
Kevin
Cheers!
Ian
Peter W
When you've done the starter I suggest you check these points ..... http://buckeyetriumphs.org/technical/AOD/AOD5/AOD5.htm
Peter W
?Are we going for the Tommy Cooper acknowledgment award?
Sounds like a dodgy earth. There could be other causes
but a dodgy earth is the easiest to check.
AlanR
Neil
Same thing happened to me.
On my car there was a connection in the feed wire just below the dash. It was in a position where I often nudged it getting in and out of the driver's seat mainly due to it being a bit loose and hanging down a bit. I cleaned the terminals, made sure there was a good, solid connection and taped it up to avoid any interference. It's been fine since.
Hopefully your fix is just as simple.
