Keith66 Posted July 9, 2016 Report Posted July 9, 2016 Hi All Just building up the bare doors on 1972 TR6. I retrieved the door glass from my loft and found that attached to the metal channel on the bottom of the door glass is a plastic sheet. In the parts catalogue it is referred to as a Water Curtain. The thing i need to know is what happens to it inside the door, does it just dangle down or does it need to attach in some way to some part of the inside of the door. It isn't clear from the parts catalogues or brown book. Any help would be appreciated. Thanks Keith Quote
harrytr5 Posted July 9, 2016 Report Posted July 9, 2016 Just dangles down. I seal my doors with a plastic membrane on the outside of the inner door as per modern cars. I use double sided adhesive tape. Never had water come in or distort the trim. Regards Harry Quote
RogerH Posted July 9, 2016 Report Posted July 9, 2016 Hi Keith, as Harry as stated the curtain hangs down. It is tucked on the far side of the wind regulator. It is there to keep water off the regulator. Roger Quote
Mark69 Posted July 9, 2016 Report Posted July 9, 2016 Can you still get these, none fitted to my car. Quote
Keith66 Posted July 9, 2016 Author Report Posted July 9, 2016 Cheers all, that clears that one up. Not sure how effective just dangling down will be so i will also go the plastic sheet on the inner of the door as per modern cars. Thanks Keith Quote
RogerH Posted July 9, 2016 Report Posted July 9, 2016 Hi Keith, dangling down may not remain that way. As you operate the window it tends to ride up. I use a blob of silicon sealant in the bottom corners. Hi mark, not sure if they are available but any supple plastic should work. I think the originals came in three sections - I just use one. Roger Quote
Pogo Posted July 9, 2016 Report Posted July 9, 2016 Not sure if they are available new, but when I rebuilt my TR6 I made my own from some decent plastic sheet. Works well. Roger Quote
peejay4A Posted July 9, 2016 Report Posted July 9, 2016 Builders damp proof membrane works well. Quote
