carld Posted December 11, 2019 Report Posted December 11, 2019 Hi all my light switch has failed and I need to replace it, So I need to undo the channel where the wiring goes down the steering column. Any advice on the best course of action after removing the seat and steering wheel, I can clearly see one bracket and can get access to that, but I’m assuming there’s going to be another bracket very close to the back of the dash? Is that a clicks out job to get to? TIA Quote
stuart Posted December 11, 2019 Report Posted December 11, 2019 Take the Rev counter and Speedo out that will give you much more access. Be careful of repro switches as some arent very good at all and dont pinch the wires when you put the tray back. Stuart. Quote
RogerH Posted December 11, 2019 Report Posted December 11, 2019 Hi Carl, another tedious job. Work slowly and it will happen. Ref this Moss page https://www.moss-europe.co.uk/shop-by-model/triumph/tr5-6/steering-suspension/steering/steering-column-wheels-tr5-6-1967-76.html You need to remove the cover #34 To do this you need to remove #50 & #51 and on a TR4A #48 This will allow the steering column to move up/down to get the cover #34 out. The cover pushes forward and then down. Do remember to put clip #51 back in place. Roger Quote
Rob Salisbury Posted December 11, 2019 Report Posted December 11, 2019 Of course you can refer to The Art of Coarse TR Maintenance manual which, so long as your soldering skills are up to it, says just cut and splice the wires near to the new switch and use heat shrink to insulate the joints .... saves an awful lot of fighting with the rest of the dash board!! Cheers Rob Quote
carld Posted December 11, 2019 Author Report Posted December 11, 2019 Cheers guys really appreciated, Rob unfortunately the switch gave way and caused a small fire and the wires are toast Quote
Rob Salisbury Posted December 11, 2019 Report Posted December 11, 2019 Yikes!!, ... the manual has one thing to say about fires, and that's stay away from them, they're too hot to handle!! ... back to the steering column, it helps if you disconnect the top rubber joint so that you can move the dash section of the column back and forth as the little tray wriggles out, .... with the new switch I recently installed I found that the supplied outer black sheath was a little on the large size and took a bit of squashing to get it to sit neatly. Cheers Rob Quote
Richard B 2.5PI Posted September 23 Report Posted September 23 This thread really helped me. I thought I would post a picture of the clamp that needs unbolting, showing why you need to remove the speedometer for access. Also I know I am missing the cable tray and spring clip at present. Quote
stuart Posted September 23 Report Posted September 23 45 minutes ago, Richard B 2.5PI said: This thread really helped me. I thought I would post a picture of the clamp that needs unbolting, showing why you need to remove the speedometer for access. Also I know I am missing the cable tray and spring clip at present. I might have a cable tray somewhere if you want it. Stuart. Quote
Phil Read Posted September 29 Report Posted September 29 On 12/11/2019 at 1:03 PM, Rob Salisbury said: Of course you can refer to The Art of Coarse TR Maintenance manual which, so long as your soldering skills are up to it, says just cut and splice the wires near to the new switch and use heat shrink to insulate the joints .... saves an awful lot of fighting with the rest of the dash board!! Cheers Rob Yes i did this but de soldered the wires from the old switch and soldered them onto the new one. saved a great deal of hassle. Quote
