3082 100 041  this is now obsolete and 3082 634 104 is suggested instead.
I have no experience of this item.  Just offering collected info from the TR world.
SACHS Clutch Pressure Plate.   this is the pressure plate suggested for TR 4A-6.
Not uprated.
Said to be as smooth and light as Laycock unit.
  • 1 month later...
  • 4 months later...
From Hamish   Torque setting for caliper assembly bolts if the calipers are taken apart.   Suit TR4-6
The torque figures are in the Daimler manual. Posted before but just in case the calipers are already split !!
  • 1 year later...
Wanner Grease Gun Instructions
https://drive.google.com/file/d/11fIwEeXca9jpWxc8ISaPCyQVYCqT5F0P/view?usp=sharing
If they are accessible on this area see below.
wanner_315.pdf - Google Drive.pdf
  • 1 month later...
  • 3 weeks later...
Workshop manual “Brown Bible” for the TR6 owners.
https://tecb.eu/onewebmedia/TR6_repair_manual.pdf
Workshop or Repair Operation Manual TR2-3
https://tecb.eu/onewebmedia/Triumph TR2, TR3, TR3A factory service manual.pdf
Workshop or repair manual TR4-4A
https://tecb.eu/onewebmedia/TR4 Manual.pdf
  • 5 weeks later...
  • 1 month later...
  • 6 months later...
  • 2 months later...
SMITHS INSTRUMENTS IDENTIFICATION AND OPERTIONAL TESTS
From Charlie D
Hello All,
I'm not sure if this has been mentioned before, but I've just discovered a page that lists all the Smith instrument part numbers (those little numbers found somewhere on the dial face) against what car they were used on.
https://vintagebritishcables.com/documents/SMITHSSUPERSESSIONLISTBYOLD-TO-NEWNUMBER.pdf
The site also has a Smiths "Care of instruments" .pdf, which I may well have seen before somewhere on our forum, but worth mentioning again.
https://vintagebritishcables.com/documents/SMITHStheCareofInstruments.pdf
Both may be of use.
Charlie.
PS
Just realized that the list only includes cars up to TR4, so mainly of use for TRs previous to TR4.
Edited 4 hours ago by Charlie D
On 5/2/2022 at 6:03 PM, BlueTR3A-5EKT said:
3.  Front Crank Pulley. Wet liner Engine . TR 2/3/3A/3B/4/4A/4A IRS   -  SKF 99175  or SKF CR 99175.  (1/2" wide) (CR Type is uprated item) (Moss 520-505)
    NB.  You can use SKF 99174 or SKF CR 99174 which are 3/8" wide and need care when installing to get in the right position over the wear groove of the engine front pulley drive flange.
Update for anyone wanting to undertake this work, there are now (Spring 2026) other sleeves available for the crank pulley including some that are 0.875" wide which means they can be pressed home as far as possible and the flange left intact at the base of the hub, guaranteed to cover the contact/wear zone of your chosen lip seal- BearingsRus..Part Number: 99175, also considerably cheaper than the thinner SKF version.
Thank you
link
https://www.bearingsrus.co.uk/99175-unbranded-shaft-repair-sleeve
  • 3 weeks later...
  • 2 months later...
Some articles to add to this very useful archive. I browsed through the posts so I don't believe these are duplicates.
The Lucas Electrical Handbook. This looks older than our TRs, but many of the components in our cars were inherited from earlier models.
The Lucas Fault Diagnosis Service Manual covers the kit in many of our cars.
The Gentleman's Guide to Smiths Gauges (Parts 1 and 2) are borrowed from the Alex Miller, Triumph Club of New Zealand (triumphclub.co.nz).
Repairing Jaeger and Smiths Speedometers was written by Anthony Rhodes when he was a member of Delaware Valley Triumphs of the Vintage Triumph Register, USA.
Lucas-Electrical-Handbook.pdf A-Gentlemans-guide-to-Smiths-gauges_Pt_1 (1).pdf A-Gentlemans-guide-to-Smiths-gauges_Pt_2.pdf Repairing-Jaeger-and-Smiths-Speedometers[1].pdf LucasFault.pdf
