Yeah I know,
it is not possible to fit the spring plate after (first) the leaver, so I never told this.
My main concerns are:
- what way around to put the spring plate and the loching washer
- and NEVER punch the distance washer in or out!!
I said punch locking washer not distance washer--I'd like to see how you could possibly get the locking washer in any other way! It was a gentle tap tap not a good pounding like there's no tomorrow!
Michael
Edited by michaeldavis39
Hi Michael,
after reading your and my post serveral times I think we both describe the same.
Yes, you describe and I understand: you fit the locking washer with a little punch in its final position.
This may be needed and I have absolutely made no critic about doing that.
But one of my 2 main concerns, independent from your advice, is about the distance washer,
the little tiny u-piece with the ends bended up: never punch THIS in or out like Buckeye describes it.
This caused my much pain the first time I did that (and then never again)
You and me, we are shure still friends?
  • 5 months later...
  • 6 months later...
...and filing the crude casting ridges back flush with the body so the cylinder slides in the backplate.
- other brands may differ!!!
Alan
  • 3 weeks later...
On 2/13/2020 at 10:17 PM, Z320 said:
You are welcome, last one is how to open this §$%&/?! mechanism,
because this can make a strong man desperated
Stick two small screw drivers between and with this you have two "ramps" to slide the locking plate over the tooth
Take a pliers and pull the lock plate out
Here a small drill and a hook would be helpful
I thinks they may be heat treated. so drilling might not be an option ill try and see if i get a carbide through one or check one with my hardness files
Merci à Marco pour ce tuto qui m'a bien aidé pour le sens de montage des différentes pièces .
Çà à l'air facile sur un moyeu posé sur l'établi ................ c'est une autre paire de manches quand on le fait sur l'auto !
Bonne route
Edited by Bear83
  • 2 months later...
On 2/19/2020 at 6:48 AM, Mick Forey said:
Wayne has kindly uploaded the series of photos and explanations onto the website under Resources / Technical Manuals https://www.tr-register.co.uk/past-issue/2020/02/0116/Girling-rear-wheel-brake-cylinder-dust-cover-fitting-guide so that all members can easily find this excellent work by Marco. It would also make an excellent article for TR Action.
Mick
Thanks for sharing the link it is really informative.
  • 2 years later...
Hi all,
can it be that the lever Springs out of the cylinder when I will press the brake. The 2 Small nippels Right and left of the lever doesnt hold.
Can it be that the Spring Plates and the rubber seal are not correct?
20 minutes ago, Johannes said:
Hi all,
If you read from the start of this thread it will tell you the correct way to fit them so they hold together.
Thxs Stuart, I will take a Look
  • 2 months later...
  • 5 months later...
Mine haven’t been properly fitted and don’t do what they’re supposed too-
Is it possible ? Or has anyone tried to renew/fit these while the backplate etc is on the car without having to remove everything just to renew the rubbers. Obviously the brake pipe & handbrake lever connection will have to be released but to have to remove everything else - hubs, brakes, backplate etc -  just to replace the rubbers seems such a lot. Surely the factory wouldn’t have designed it that way or expected all that to be removed for a ‘simple’ rubber replacement?
Edited by jimt
You would only need to remove the handbrake cable/brake pipe/drum and the linings to free off the cylinder, no need to remove the backplate.(Obviously if you have wires then you would need to remove the spline extension)
