aleda Posted July 14, 2021 Report Posted July 14, 2021 Hi Jase - when you get round to sorting the plenum repairs, this is what my Engineer did in 2018. The tube goes right through the inner sill so no water sits there to start the problem again. Hope you find this useful Christine Quote
Jase Posted July 14, 2021 Author Report Posted July 14, 2021 Thank you, I'm interested to see what lies beneath the front wings as it seems the car has had some bodywork done over the years. I note the tubes sticking out at the front of the sills on mine, near to the front tyres. Quote
harrytr5 Posted July 15, 2021 Report Posted July 15, 2021 This is my take on it. one from the corner at the rear of the bonnet joining the plenum and through the sill to exit through the vertical floor pan panel. Regards Harry Quote
stuart Posted July 15, 2021 Report Posted July 15, 2021 10 hours ago, Jase said: . I note the tubes sticking out at the front of the sills on mine, near to the front tyres. In that case your plenum drains have already been extended. What people forget though with 4/4a/5 is that at the rear of each inner wing drain channels there is another drain hole that allows water to drain down inside the inner wing and over the top of the sill. I always fit an extra drain tube there that follows the extended plenum drain tubes down and out through the bottom of the wheel arch splash panels. I also do a similar thing for that area on TR6 though they require a small box at the top to act as a collector. I see Harry has beaten me to it with a similar answer Stuart. Quote
stillp Posted July 15, 2021 Report Posted July 15, 2021 1 hour ago, harrytr5 said: This is my take on it. one from the corner at the rear of the bonnet joining the plenum and through the sill to exit through the vertical floor pan panel. Regards Harry I'm not sure I like the idea of drilling the top of the sill. Pete Quote
stuart Posted July 15, 2021 Report Posted July 15, 2021 3 hours ago, stillp said: I'm not sure I like the idea of drilling the top of the sill. Pete Neither do I which is why I fit them the way I do out at the bottom of the splash plate. Stuart. Quote
Jase Posted October 2, 2021 Author Report Posted October 2, 2021 Well Mabel is currently sat in a warm garage. Although I shall be moving her shortly to make way for a new purchase. Quote
stuart Posted October 3, 2021 Report Posted October 3, 2021 9 hours ago, Jase said: Well Mabel is currently sat in a warm garage. Although I shall be moving her shortly to make way for a new purchase. What have you bought now? Stuart. Quote
stillp Posted October 3, 2021 Report Posted October 3, 2021 9 hours ago, Jase said: I shall be moving her shortly to make way for a new purchase. Ooh you tease! Pete Quote
Jase Posted October 3, 2021 Author Report Posted October 3, 2021 (edited) Any recommendations for a carpet supplier? Edited October 6, 2021 by Jase Quote
Jase Posted October 9, 2021 Author Report Posted October 9, 2021 Has anyone produced a step by step guide for repairing the bottom of the boot lid? Thanks Quote
RogerH Posted October 9, 2021 Report Posted October 9, 2021 41 minutes ago, Jase said: Has anyone produced a step by step guide for repairing the bottom of the boot lid? Thanks Hi Jase, step by step would be awkward as there are quite a few variables. Firstly you need a repair panel the fits the shape of the boot lid. It needs to be the correct depth ad widt (after taking nto consideration the curve from left to rigt. You need to remove the minimum from the actual boot. The more you remove the more work there is to get the correct shape back. The vertical drop at the back is not straight down - it is curved. Quite often the bottom flange of the internal rib has rotted away - Making these is fun. PM sent Roger Quote
Jase Posted October 17, 2021 Author Report Posted October 17, 2021 Just made some room with the Spitfire for the TR this winter. Although I think I need to paint the floor after the front end spray. Quote
Hamish Posted October 18, 2021 Report Posted October 18, 2021 12 hours ago, Jase said: Just made some room with the Spitfire for the TR this winter. Although I think I need to paint the floor after the front end spray. I have a single car prefab garage and I need a bigger garage !! but it seems you always fill the available space !! Quote
Jase Posted October 18, 2021 Author Report Posted October 18, 2021 4 hours ago, Hamish said: I have a single car prefab garage and I need a bigger garage !! but it seems you always fill the available space !! If I could fit another car in alongside the TR when it is in there I would too much space is fatal Quote
Jase Posted October 24, 2021 Author Report Posted October 24, 2021 Safe and sound and tucked in for the Winter. Plan is to remove the dashboard and top and windscreen surround, repair and repaint and fit a new screen, replace interior with new and service carbs. That should take me until April Quote
Jase Posted November 9, 2021 Author Report Posted November 9, 2021 Any parts shows coming up? Would like to pick up some interior and a new windscreen. Thanks Quote
Jase Posted December 16, 2021 Author Report Posted December 16, 2021 Just looking at replacement interior does anyone know what a crown cut gloss is? It reatils at approx 265 so not insubstantial. Thanks Quote
Jase Posted December 16, 2021 Author Report Posted December 16, 2021 Would help if I did somw research - new dash Quote
stuart Posted December 16, 2021 Report Posted December 16, 2021 6 minutes ago, Jase said: Would help if I did somw research - new dash Do be aware that you need to check the fit of everything in replacement dashes as the thickness of lacquer often makes it difficult to fit clocks. Original dash didnt have much depth of finish. Stuart. Quote
Jase Posted December 16, 2021 Author Report Posted December 16, 2021 Thanks Stuart, I was wondering what it was and the conversation I had with the supplier was very similar to your comments. I’ve re-veneered a few dashboards so will do mine as well. not sure if anyone knows the best varnish/lqcquer to ise to achieve the matt/Satin finish? Thanks Quote
stuart Posted December 16, 2021 Report Posted December 16, 2021 1 hour ago, Jase said: Thanks Stuart, I was wondering what it was and the conversation I had with the supplier was very similar to your comments. I’ve re-veneered a few dashboards so will do mine as well. not sure if anyone knows the best varnish/lqcquer to ise to achieve the matt/Satin finish? Thanks 2K lacquer would do, FWIW Ive got a spare litre of satin lacquer if you want it. Stuart. Quote
Jase Posted December 16, 2021 Author Report Posted December 16, 2021 Thanks Stuart, we have Fiddes just down the road so I may take the dash pre-strip down there for them to match it up. Appreciate the offer. Quote
Jase Posted January 7, 2022 Author Report Posted January 7, 2022 (edited) Could someone advise the best way of removing the winscreen frame please? Should I first remove the screen? Where is the best place to purchase a new screen and rubbers. I’ve located the two bolts either side of the screen (pic below) and the three bolts on top of the dash. Are there anymore? Thanks Edited January 7, 2022 by Jase Quote
