RogerH Posted August 21, 2016 Report Posted August 21, 2016 Hi Folks, John a has done a cracking job on the latest instructions. Roger Quote
Dave Larnder Posted August 21, 2016 Report Posted August 21, 2016 Hi Guys Now that info is one of the reasons why we use this forum, it´s these home made mods etc. that inspires us to do it yourself. I have archived my copy of John´s e mail and will spend my spare time making one up and store on the garage wall. I think we could all scratch our heads and come up with something simple like that for say a small bench hydraulic press for pressing bearings in and out. Anyone done that? What about a simple sheet metal bender while we are about it? Dave Quote
Lebro Posted August 21, 2016 Report Posted August 21, 2016 John. Your mailbox is full (tried to request a copy of your drawings) Bob. Quote
John Morrison Posted August 21, 2016 Author Report Posted August 21, 2016 Now Sorted - I didn't know it could fill up! Pm your email, for a copy. John. Quote
Marc R Posted August 21, 2016 Report Posted August 21, 2016 (edited) Hi John, Excellent document received, congratulation and thanks' very much. I shall study the opportunity to build one crane as per your study this coming winter. Regards Edited August 21, 2016 by Marc R Quote
Phil Kirk Posted August 21, 2016 Report Posted August 21, 2016 Hi John Thank you for the very detailed info. Must have taken a considerable amount of you time to put it together. Much appreciated Cheers Phil Quote
RandallD Posted August 24, 2016 Report Posted August 24, 2016 Hi John- I hope you haven't tired sending out information on your excellent kit - my aging back would greatly appreciate the plans! I will pm you. Regards Randy Quote
Johnatcastle Posted August 31, 2016 Report Posted August 31, 2016 Hi John, I too would appreciate a copy. Have Pm'd you. Thanks. John. Quote
Kevo_6 Posted September 17, 2016 Report Posted September 17, 2016 Hi John I would also appreciate a copy. Have Pm'd you. Many Thanks. Quote
marki Posted September 17, 2016 Report Posted September 17, 2016 Hi All. After putting my box back in today I can honestly say I think it's a brilliant idea. Why did Triumph decide it would be a good idea to have to remove the box through the car ?In my younger days I did plenty of Ford clutches and they were much easier. Mark. Quote
AlanG Posted June 13, 2017 Report Posted June 13, 2017 Hi John, Just finished building the crane and have removed and refitted my gearbox with ease. I fitted the 3" alignment dowel to begin with but found this made it difficult to get the clutch lever far enough forwards to clear the floor so removed it. Then with the clutch lever clear I screwed the dowel through the bellhousing and with the necessary wiggling the gearbox was in. Great bit of kit. Thanks very much. Alan. Quote
John Morrison Posted June 15, 2017 Author Report Posted June 15, 2017 (edited) Great Stuff Alan, Re the Clutch Lever, since writing the peice I've done another refit and now tie/cable tie the clutch lever as far forward as possible through a hole in the bellhousing, to aid fitting -- this works OK with the alignment dowel. Chuffed someone else built the crane, and then proved its worth. Cheers, John. Edited June 15, 2017 by john Quote
john.r.davies Posted June 15, 2017 Report Posted June 15, 2017 What an excellent idea and thread! Was just watching the assembly of a Bentley engine and gearbox, and John's kit must make the same almost as easy. https://www.bing.com/videos/search?q=bentley+engine+build&&view=detail&mid=EA19306A3A6C01D9F4FBEA19306A3A6C01D9F4FB&FORM=VRDGAR From 8 minutes Earlier, installing the pistons, see the 'horns' on the half-bigend? Another good idea that will guide it into place on the journal so easily! Got to think of how to do that on my engines. John Quote
Frank M Posted May 10, 2021 Report Posted May 10, 2021 On 8/15/2016 at 1:52 PM, stillp said: Twenty minutes? Is that including a tea break? Pete (recovering Imp addict) I would like the plans for a lift to remove the TR6 transmission Quote
John Morrison Posted May 10, 2021 Author Report Posted May 10, 2021 Frank, PM me an email address. John. Quote
RogerH Posted July 15, 2021 Report Posted July 15, 2021 Hi Folks, is it possible to remove the GB & OD with the prop shaft and exhaust pipe instu.? I want to take it out to sort an irritating oil leak but am struggling to find the enthusiasm to remove the pipe and prop. Roger Quote
stuart Posted July 15, 2021 Report Posted July 15, 2021 Yes you can, its a bit tight but definitely do-able. Stuart. Quote
keith1948 Posted July 15, 2021 Report Posted July 15, 2021 Hi Roger Never had to remove prop shaft or exhaust when removing gearbox and overdrive. Once disconnected you can push prop shaft back a bit on its splines. The bit that takes away any enthusiasm for this job is removing seats, H frame, tunnel, carpets, radio - the list goes on. The first time I removed gearbox I made a list as I went along of all the things I removed or disconnected. Then when refitting I went through the list in reverse. In that way I didn't miss anything. Enjoy your day! Keith Quote
RogerH Posted July 15, 2021 Report Posted July 15, 2021 Hi Keith, thankfully there is nothing in the car at present. I didn't want to fit the car out then have a change of plan and then remove the GB with all the hear ache. Roger Quote
Lebro Posted July 15, 2021 Report Posted July 15, 2021 On my '3 I only had to remove part of the exhaust. Prop shaft stayed put Bob Quote
Kiwi64 Posted July 17, 2021 Report Posted July 17, 2021 Hi, I know this was an 'old' article but does anyone have a copy of the gearbox crane dimensions? I am about to take out the gearbox out of my car as I found several bits of hardened steel (looked like bits of a cog) sitting in the bottom of the box when the oil was drained................. Cheers James Quote
AlanG Posted July 17, 2021 Report Posted July 17, 2021 pm John Morrison. He has the plans. Can't find mine just now. Alan. Quote
RogerH Posted July 17, 2021 Report Posted July 17, 2021 Hi James, Can you PM me your e.mail address - johns file is 20Mb and will not fit here Roger Quote
