Hi all,
I'm new here, but what a great resource here for TR owners and enthusiasts like me.
Could I ask a quick question?  I have a Crypton cruise mate 440 tuner and would really like a schematic diagram for it.  Would any nice person here have such a thing?
I would really appreciate any help with this.
Thank you .
Hello tinkerer, and a very warm welcome.
Let us have a name and an area, we are really a friendly crowd.
Hope someone can help with the diagram.
John.
Hi John,
Thank you for your kind welcome.  I am in Armagh, Northern Ireland.  A diagram for the analyser would be brilliant, but I would not be very confident that any service information exists out in the public domain.   Even any information about common faults and people's experiences would really help along with being very interesting.
Stephen.
Edited by tinkerer
Hi Stephen.
Some of us on here also lurk on another forum where this was a fairly recent topic and there is information there which might be pertinent:
https://sideways-technologies.co.uk/forums/index.php?/topic/6397-im-right-up-to-date-with-my-new-workshop-equipment/#comments
Rob
  • 3 years later...
  • 2 months later...
Hello to everyone out there in TR land.
Now, full disclosure here, I have an Austin Maxi........  don't hold it against me, it's a nice car.
I acquired a Cruise mate 440 some time ago as a non-runner but the good news is it came with a user manual, service manual, parts catalogue and full set of wiring diagrams, so I’m hoping it doesn't have a catastrophic failure and I'll be able to fix it. I might just need a little assistance if it comes to comparing operational parameters with a working unit, so perhaps a little reciprocal help is on the cards?
There's quite a lot of paperwork, some of it on A5 sheets, so scanning might be need a little thought.
let me know if I can help.
Steve
Oldham area
  • 6 months later...
Hi all. I’m after a manual for the 440 and any other info. Have a fault code and can see a resistor that looks blown but unable to get colour code off it.  Any help much appreciated
Also after the schematic and fault manual for a 440. The osciliscope not firing up, error 22 on the display. Found a couple of tantilum capacitors - well half of them that looked right crispy so have replaced them but still no joy. A couple of videos on youtube fault finding another model but the boards are not the same as the 440. Have power and the CRT glow but no display. If somebody has a schematic or set of service manuals that I can scan or photocopy then please please let me know. mike_bressington@yahoo.co.uk
Mike
  • 3 weeks later...
Hi Mike
I've attached the fault code list for you and also the A-D calibration procedure, although I doubt you'll need it once you have the 5v rail back in spec.  From my own experience I can say that the tantalum capacitors are a real pain on older equipment and frequently go short circuit, I've change loads in my machine and this finally got the DC supply voltages back to where they're supposed to be. Interestingly It was almost always the 47Uf capacitors that were short.
My own machine never gets as far as the fault codes, The display shows the decimal point in all segments and I don't see a 'post' test. In fact I have no idea what a post test should look like since the manual does not describe it.  If you know, and can describe, what should happen with the displays when switching on the unit that would be helpful.
Steve
Edited by Steve the Maxi man
Hi Mark
I've attached a full list of fault codes to this thread. f you can tell me which board has the crispy resistor I’ll check for a schematic.
Steve
Hi Steve,
many years ago (50 years)  in the Practical Television magazine one of the writers had an interesting monthly report that always (it seemed)
had a mention of 'beware of the Blue Tants'  it sounded like an illness.
Apparently over a very lomg time span Tantalum capcitors have weaved their disasterous effects.
  • 1 year later...
Steve
Oldham area
Hi Steve, further to your post above would you have diagrams for board 8 & 9 for the crypton cruse mate 440?
My unit has everything at the top of the display and I suspect the vertical deflection has failed.  I believe board 9 does the vertical deflection whereas board 8 does the horizontal deflection.
If you have a schematic for both boards it would be a great help.
Tom
Hi Tom
I do indeed have those. The easiest way to get them to you is via photograph, see attached.  If these are too difficult to use I can try scanning the pages, the only issue being that they are on A3 sheets and so won't fit in to my home scanner at one go, they would have to be in sections.
From experience I would definitely suggest checking - replacing all the tantalum caps, they're a problem at this age.
If I might ask a favour?  If you unit powers up normally what does the start up procedure look like? I think that all the readouts and leds should 'exercised' in a particular order, but I can't get mine to do it.
Steve
14 minutes ago, Steve the Maxi man said:
Hi Tom
Steve
Hi Steve, excellent thank you. I'll download these and see if I can use them or if I can enhance them.
Attached is a video of my unit starting up. Before this I had an error 22 on the top display. This was fixed by replacing tantalum bead capacitor C3 on board 9 which was short circuit.
Please let me know if I can help in any other way.
Thanks again
Tom
Hi Steve, the displayed 12.2V on the bottom display is because it connected up to an old mini with the voltage option selected. Normally this would show 0V.
Hi Steve, what are you opening it with? I didnt think there is anything different with it. It's taken on a Samsung mobile phone.
If you're on WhatsApp or messenger I can try and send it.
Tom
Hello Steve,
I've hidden the post that contains your wifes telephone number,
probobly not wise these days to publish on a site.
You can send personal information via a PM (personal message) Click on Tom's profile i.e. ISBCA,
and see the message option.
I will 'Unhide' the post is you insist.
Best
John.
Hi Steve,
I too have a Cruisemate 440 and have been having problems getting it going. I have replaced some of the tantalum capacitors which enabled me to get it to start up, I even got a printout working, and then after about 30 minutes another tantalum capacitor blew. I am now replacing all of the tantalum capacitors on all the boards
I see that you have access to some technical repair documentation on the 440. I have been looking for this level of information for a while but cannot find any such sources on the internet. The user manuals are freely available but the service information is not. Would there be anyway I could obtain a copy of the service documents please, I would be quite willing to pay for any scanning or copying costs involved. I know on my machine I will need to setup the scope traces correctly and recalibrate it so any info in this area would be most useful.
Anything I learn during the fixing process of my machine I would of course share back with this chat in the hope that it will help you with yours.
I’m  also part of a Facebook group for “Crypton tune & diagnostic machine archive” and on there we have several files for things like EPROM code images, manuals and the like and some very helpful members.
Looking forward to hearing from you.
Thanks,
James (Swindon)
Edited by Mbalpha
Morning James
I have, I think, a full set of service manuals and schematics, the trick is getting them off the paper and onto the internet, As you can see above I photographed a few for another member but that's not ideal.
I have already asked one company for a quote on scanning the lot and am awaiting a response. I think this would make it easier for everyone. Depending on cost we could perhaps all make a contribution? I'd even considered buying a A5 scanner to scan things myself, they don't seem to be too expensive, but I think also having the software to make these searchable PDFs would also be helpful, trawling through several hundred images won't be fun.
I know the Facebook group, but I don't do social media myself.
In the mean time if there is anything specific you need I cold attach a photo here.
Steve
7 hours ago, Steve the Maxi man said:
Morning James
Steve
Hi Steve,
Thanks for getting back to me so quickly. It’s great to hear you have some service documentation. I know there are at least two of us on the Facebook group that would be willing to help you work out how to get these scanned and would probably chip in some funds to help. We’ve been searching for documentation like this for months.
Would you be able to let me know what documents you have please, maybe take a picture of the cover of the manuals or service books?
If you want to message me directly through the forum message system that would be fine rather than clog up this chat or we could do it on here, whichever is easiest.
For me it would be the board schematics and the test procedures for setup. These machines have lots of test points on the boards so I’m assuming that there is a test procedure somewhere that says check for x volts at test point y that helps us fault find the boards. Also anything on tuning the variable resistors on boards 8 and 9 for scope setup might also be helpful.
I have an A3 scanner but I’m in Swindon.
Thank you,
James
