The problem is.....if you fill a cube with CO2 gas and expose it to the radiation frequency which CO2 is responsive to, THEN you get a measurable temperature rise.
They tried the same experiment with normal air (which contains this faint of CO2)....and no temperature rise was measurable.
That is because CO2 is too diluted to become sensitive to radiation. If that experiment would have been successful, then we won't discus then assumption becomes fact.
On the other hand, if a theory refuses a proper experimental proof then in most cases the theory is wrong.
These climate doomsday proclamationists try to work around the fact proof with statistic:
1850 - cold - CO2 low
2022 - warm - CO2 higher = man made global warming.
That is their only circumstantial they have. Their straw halm to government budgets and the world wide interest in climate subjects.
Before that, nobody even knew the word climate....but then these "prophets" with thin evidence climbed the stage and we can't get them off.
Edited by MadMarx
Marx,
Here's an English language version of your  past temps graph:
Schematic reconstruction of average temperature variations in the Northern Hemisphere during the Holocene. Adapted with permission from chapter 4, Figure 25 in Schoenwiese, C., 1995. Klimaänderungen: Daten, Analysen, Prognosen. Springer, Berlin, Heidelberg, 224 pp
No argument with that, but I fear your  Gedankenexperiment with an imaginary cube of CO2 gas is misleading.     You make the point that CO2 only absorbs heat at certain wavelengths of infrared radiation.   Indeed it does, but it is out-going radiation that it absorbs.      Sunlight passes through the CO2 in the atmosphere, to heat the land.  The land then radiates heat at lower, infrared wavelengths which ARE absorbed by CO2, heating the atmosphere.
This effect is also true of glass, so that gardeners use greenhouses to care for delicate plants.     'Climate change' used to be said to be due to the "Greenhouse Effect", and it is!
Actual greenhouses mainly work by stopping convection John.  That does not happen in the atmosphere so the analogy is nonsense really.
That is the thing.....CO2 is not intelligent. It doesn't know the direction of radiation.
It absorbs radiation from above and below.....but if it is diluted then it is like:
10.000 people
40 mad people spread over the crowd.
As a result, the 40 mad won't make the 10.000 go mad. They would basically ignored....and so it is with CO2.
The climate terrorist start their argue at 1850, which was a LOW temp age, also seen in the graph.
Normally you would compare high temp ages and you would compare low temp ages.
But comparing low temp ages with high temp ages doesn't make any sense.
You don't compare winter lows with summer highs. There is no point in doing.
But for sure it sounds great "pre industrial"....wow, how great this term sounds and supports the theory.
If they would compare it with the "pre-industrial holocene" age, then things fall over.
52 minutes ago, RobH said:
Yes, what you describe there is part of greenhouse gas warming theory ( it's more complicated than that due to the postulated amplification by water vapour and other factors, the extent of which is the topic of continued debate ) but there are still dissenting voices and the measured temperatures are not doing what the models say should be happening if the theory is correct.   What do you believe - the models or the measurements?
https://www.scirp.org/journal/PaperInformation.aspx?PaperID=82087.
https://www.sciencepublishinggroup.com/journal/paperinfo?journalid=298&doi=10.11648/j.ijaos.20210502.12
As for rapid loss of arctic ice - where?  This from the Danish Meteorological Institute:
It was declining long before 2017 when your graph started. It is declining at 12.6% per decade:
see figure 2 https://nsidc.org/arcticseaicenews/2022/09/arctic-sea-ice-minimum-ties-tenth-lowest/
Useful site for explanatory diagrams, aimed at our grandchildren. http://www.grandkidzfuture.com/earths-climate/the-greenhouse-effect.html
We can expect, perhaps quite soon, millions of young, angry Gretas attacking our enthusiams for classic motoring for causing GW-CC. We could usefully rehearse our arguments as to why running a TR is environmentally more reponsible than, say, flying off on hols or driving to away football matches, or w.h.y.  Denying GW wont be a valid defence, the young are too well informed.  Peter
But if you plot those minima from table 1 it shows no trend Peter?
Plot from 1980 data onwards and you will see the trend - 12% loss per decade.
No. Soda glass does not transmit  >3,000nm IR well, which is the wavelength  region emitted by sunlight energy absorbed by the ground.
https://commons.wikimedia.org/wiki/File:Soda-lime_glass,_typical_transmission_spectrum_(2_mm_thickness).svg
of course if you leave the door open convection becomes important !
Peter
If you do that it becomes evident that the decline ceased about ten years ago.
Thats because theres less area left to  decline ! And ice nearer land in older and thicker so a simple area measure can fool us into thinking the ice is not melting faster than it forms in winter.
The line becomes flat. If your argument were correct it would be smooth curve which becomes increasingly asymptotic, which it clearly does not.
So cooling greatly increases if you leave the door open - ergo, convection is the major cooling vector and is blocked in a greenhouse but not in the atmosphere.  Thank you for making my point for me. :D
That argument does not hold water. When the planet itself is the greenhouse, and its atmosphere the glass, there is no door to open. Earth heats up.
The only way to transfer heat into the vacuum of space is by radiation. No convection.
Peter, the discussion topic was whether a greenhouse is a good analogy for the atmosphere.  Patently it isn't.
No-one disputes that the only way to shed energy to a vacuum is by radiation.
A greenhouse with doors and windows closed is an excellent analogy for the forcing action of CO2. It is easier to visualise and explain to the public who mostly have only a smattering of technical education.
The complexities of GW and CC are difficult science. And predictions of weather changes are especially precarious. But weather determines our environment and hence food, water etc etc. That's why we should not seize upon the uncertainties in the science of GW as being evidence for dissmissing it as unreal.  To me, it is a planet-wide experiment we are conducting and there is no sign whatsoever that effective action is being taken.
Well, I woke up this mornin'
And I got myself a beer
The future's uncertain
And the end is always near
To me the result of the 'cure' for a might-be-disease - for which the evidence so far is contradictory at best - is far worse than the consequences of doing nothing, and is certain to cause misery and deaths through cold when people no longer have the means to keep warm.   The country is being driven to economic suicide, through measures which will make no discernible difference to the climate.
The UK and north Europe are at a particular risk of severe winter cold should the AMOC fail. This current, orignating in the Gulf Stream, brings heat to us in enormous quantities, giving us winters that are much warmer for our latitude. Its difficult to measure the AMOC, but Arctic warming and Greenland glacier melt act to slow it. In the past it has stopped flowing in as little as ten years. The AMOC is but one example of an experiment we are conducting  without knowing with nay cetainty what the results could be. Runaway methane release from melted permafrost or oceanic clathrates is another. For many countries it will not be a question of economic suicide it will be actual suicide, or migration to....wherever remains habitable.
I agree the measures taken by UK and elswhere have had no meaningful effect. But many in UK seem to me to think we are not going to suffer directly from GW-CC. I am far from confident about that.
Years ago I used to watch the AMOC races at Silverstone. (Aston Martin Owners Club) ;).   That was long before the  Atlantic Meridional Overturning Circulation became of interest of course.
A recent paper suggests little problem with it though : "A 30-year reconstruction of the Atlantic meridional overturning circulation shows no decline"
https://os.copernicus.org/articles/17/285/2021/?mc_cid=cbeda0c2d5&mc_eid=b0f93db32f.
Me too, when I ran a DB2/4 Mk1.
The problem with the current is that freshwater melt off Greenland and melted Arctic Ocean Ice are both increasing and are expected to affect the current. "Past performance is no indicator of future....". Its an experiment.  It does beg the question: what would UK do if AMOC was found to be slowing? we dont know how to speed it back up.
Last night we had dozens of electricity engineers with several vehicles, including a crane, in our village because of an issue with the power lines to the village. We watched as the crane off-loaded a huge generator from the lorry into the orchard next door. They connected this to the village grid so they could isolate the faulty lines. So all night the village has been powered by this huge diesel powered generator. We have a couple of Stop Oil activists in the village but so far haven't appeared to demand the generator is switched off which would stop the whole village using electricity. No lights, cookers, fridges, freezers, kettles or electric car charging. No one has suggested we use a windmill (no wind) or solar (no sun at night) or nuclear (no local uranium mine) or anything else as an alternative to the huge rumbling diesel generator next door. Funny that? Maybe we could have a large village treadmill?
Keith
And make the 'stop oil' crowd do the treading.................... B)
10.000 people
Marx,
Much of current  physics is based on Gendankenexperiment, starting (?) with Einstein, "riding on a light  beam", and not ending, I'm sure,  with Peter Higgs and the eponymous Boson and Field.   But they are always experiments based on accurate knowledge of existing physics, and the application of ?intuition, ?genius by rigourous mathematics.     I fear your image of a few mad people in a crowd is neither.
First, in any gas, there is a wide distribution of kinetic energy among the molecules on the volume.    This is  the basis of the modern Theory of Gases.
A crude image of a gas in a box.  You will observe that the molecules move about, in what is otherwise a vacuum, their velocity and mass giving their kinetic energy.     They collide and bounce off the walls, without losing any energy, which we perceive as 'Pressure'.      They also collide with each other - the image has a few red 'molecules' to help you follow one.    See that such collisions DO change the molecules' velocity as well as direction!    The "mad" molecules - the fast ones - could "infect" the others!     But no!   In such a collision, the two molecules share their kinetic energy, depending on their directions.   There is an equal total of energy afterwards as before.   There is no 'infection' as if there was an epidemic, or else panic.
If the collision with the box walls is "Pressure", what is "Temperature"?    It is the way we perceive the molecules' kinetic energy.   A thermometer will experience the collisions of millions (trillions?  quadrillions?? I don't know) of molecules every second, and so will register an average of all those.     In a sample of CO2, if some molecules absorb the energy from a photon of infra-red light, they will have more energy and move faster, the rest stay the same - but the average kinetic energy of the sample rises.
 The analogy/gedankenexperiment of angry molecules infecting others  isn't true.
Edited by john.r.davies
If so.....they're claiming 2Watts/m² planet surface.
as the atmosphere consist of almost NO CO2....only 0,04%..... these few CO2 molecules must be glowing to contain 2W over the height of about 40km.
Marx,  you are confused, as well as misinformed.   The Solar irradiance constant is 1361 Watt/m^2 -that's  One Thousand Three Hundred  and Sixty One Watts!    And that is energy arriving on the surface, on a clear day.    The amount of energy reflected and re-radiated outwards depends on what the surface is.
And those few CO2 molecules?   Ever hear of Avogadro? No?  Let me educate you.    Avogadro ( as long ago as the 18th Century so you have to catch up!) found that equal quantities of different compounds had the same number of molecules.   Avogadro's Number, that number of molecules, is 6.02214076 × 10^23.   That's a six with 23  zeros after it, before the decimal point!
Gases of course expand and contract with pressure and temperature, so we measure Avogadro's number at "normal temperature and pressure" (20C and 1 atmosphere, NTP).   That won't be true all the way up the atmosphere, but let's start at "NTP"    An Avogadro number of gas molecules - of any gas mark you! - will occupy 22.4Litres.    So, 1 Litre will hold 2.688458 x 10^22  molecules (2, followed by 22 zeroes!).   If 0.04% of these are CO2, then there are 1.075x10^18 of them in that one litre.
That's 1,075,000,000,000,000,000 molecules of CO2, more than a "Quintillion" of them.
You really do need to understand before you criticise, Marx,  else you look foolish.
