MadMarx Posted January 30, 2023 Report Posted January 30, 2023 You know that pressure gets less with height? Means, your CO2 thins out with height. But.....still a pointless discussion. There is no proof of the CO2 relevance....still no experiment invented. That said....all is assumption with regards of CO2. Still nobody knows why ice ages come and go.....we are stepping in thick mist and make actions of basis of assumptions. Quote
RobH Posted January 30, 2023 Report Posted January 30, 2023 (edited) 2 hours ago, john.r.davies said: The Solar irradiance constant is 1361 Watt/m^2 -that's One Thousand Three Hundred and Sixty One Watts! And that is energy arriving on the surface, on a clear day. No John. That is the incident irradiance at the top of the atmosphere not at the surface and occurs only over the area exposed to sunlight, not the side of the planet in darkness. To quote wiki: The average annual solar radiation arriving at the top of the Earth's atmosphere is about 1361 W/m2. This represents the power per unit area of solar irradiance across the spherical surface surrounding the Sun with a radius equal to the distance to the Earth (1 AU). This means that the approximately circular disc of the Earth, as viewed from the Sun, receives a roughly stable 1361 W/m2 at all times. The area of this circular disc is πr2, in which r is the radius of the Earth. Because the Earth is approximately spherical, it has total area , meaning that the solar radiation arriving at the top of the atmosphere, averaged over the entire surface of the Earth, is simply divided by four to get 340 W/m2. In other words, averaged over the year and the day, the Earth's atmosphere receives 340 W/m2 from the Sun. This figure is important in radiative forcing. By the time the energy reaches the surface it has been reduced by about 25%, by scattering and other effects so the number at the surface is nearer 225W/m2 on average over the day. Edited January 30, 2023 by RobH Quote
Peter Cobbold Posted January 30, 2023 Report Posted January 30, 2023 57 minutes ago, MadMarx said: There is no proof of the CO2 relevance....still no experiment invented. That said....all is assumption with regards of CO2 The first experiment showing CO2 absorbs heat was by John Tyndall in 1859 https://en.wikipedia.org/wiki/John_Tyndall Nowadays that knowledge is school-level physics Quote
john.r.davies Posted January 30, 2023 Report Posted January 30, 2023 1 hour ago, RobH said: No John. That is the incident . By the time the energy reaches the surface it has been reduced by about 25%, by scattering and other effects. Thank you, Rob! But a quarter of 1300W is a lot more than the 2W/m^2 quoted by Marx. Quote
MadMarx Posted January 30, 2023 Report Posted January 30, 2023 According to the Climate terrorist is 2W the difference what makes the planet warm. Quote
Peter Cobbold Posted January 30, 2023 Report Posted January 30, 2023 The numbers are in here: https://en.wikipedia.org/wiki/Radiative_forcing Sun delivers, averaged over day and night, 340 W/m2 albedo reflects 30% So ca 210 W/m2 is absorbed. G/h gases are rising and account for an extra ca 2W/m2 - see histogram towards end. 2 on top of 210 does not seem much: 1%. BUT note that the forcing caused by Milankovich cycles, the cause of ice ages, was only one fifth of that (0.2%, negative) and occurred over 100,000 years. Compared with ide age climate we are causing forcing at 5 times greater magnitude over 100 years rather than 100,000. That's 5000 times faster. Peter Quote
MadMarx Posted January 31, 2023 Report Posted January 31, 2023 On 1/30/2023 at 1:59 PM, Peter Cobbold said: The first experiment showing CO2 absorbs heat was by John Tyndall in 1859 https://en.wikipedia.org/wiki/John_Tyndall Nowadays that knowledge is school-level physics yes.....and 1L of pure alcohol will kill a human. it is the dose. CO2 is so diluted, is has no effect. BUT if people are so convinced about this issue, then: don't own a computer don't write on the web don't have a cell phone don't own a car don't eat meat don't use any modern technic (which all is based on oil) walk, barefoot, as shoes are often made from plastic don't use glasses don't use forks and knives don't breath then you can lecture others. Quote
Phil Read Posted February 1, 2023 Report Posted February 1, 2023 15 hours ago, MadMarx said: yes.....and 1L of pure alcohol will kill a human. it is the dose. CO2 is so diluted, is has no effect. BUT if people are so convinced about this issue, then: don't own a computer don't write on the web don't have a cell phone don't own a car don't eat meat don't use any modern technic (which all is based on oil) walk, barefoot, as shoes are often made from plastic don't use glasses don't use forks and knives don't breath then you can lecture others. +1 Humans are the problem, period. Those who are concerned should volunteer for euthanasia. Less humans, less of a problem. Quote
MadMarx Posted February 1, 2023 Report Posted February 1, 2023 It is just a matter of equilibrium. If the earth can't feed all the people, the people will become less until the equilibrium is settled again. Very simple stuff. The good thing, mother natur has the plan for everything. And if driving Triumphs need lesser people on this planet, then she will care for us. Quote
Bleednipple Posted February 1, 2023 Report Posted February 1, 2023 4 hours ago, Phil Read said: +1 Humans are the problem, period. Those who are concerned should volunteer for euthanasia. Less humans, less of a problem. A standard, lazy and pointless go-to argument of people who want to appear clever enough to offer an obvious even though impracticable 'solution', but not really interested with discussing actual workable approaches to (a) reduce the level of emissions that humanity currently produces, and/or (b) societal approaches that could mitigate the harm of climate change on the most vulnerable people. Nigel Quote
Peter Cobbold Posted October 29 Report Posted October 29 Preparing for AMOC slowing https://theconversation.com/key-atlantic-currents-could-collapse-this-century-but-the-risk-is-missing-from-almost-all-national-climate-plans-new-study-295234 IIRC the sudden slowing 17500 yrs ago was due to a huge freshwater ice-dammed lake draining out from Canada to the Atlantic. Lake Agassis? Quote
