1 hour ago, stuart said:
A very good advice!
But I have doubts this is true in its core.
The only issue I can imangine is the tube is too long and hits the toothed sleeve of the frinction plate.
--> the tube does not give the friction plate free via the contact to the sleeve.
This is why it is worth to check,
and looking on Jamie's video agian I see rust on the sleeve and rust on the tube too!
Thank you, all! Lot's to unpack, I will try to be succinct(?)
Here's the flywheel - the bolts were brand new when I installed the this past May.
Here's the gearbox nose and measurement:
Here's the Throw-Out Bearing and Sleeve:
Finally- Here's a link to a video of the parts:
I am going to buy an angle grinder today to get that cross-shaft out. The cross-shaft, along with most of the related parts is in my cart at Moss BUT... the darn fork is not in stock! Same thing at Rimmer Bros... Any other sources for the fork?
You all have been so helpful... I really appreciate the time you take replying to this thread.
-Jamie
It is copper grease and not rust on the toothed sleeve on your first video...
I do some measurement his eveneing and show you, but sadly my TR gearbox is fitted with a hydraulc concentric release bearing.
Try TRF for shaft etc. https://www.trfbasic.com/
You definitely have the wrong nose piece cover as seen in my post above which wont be helping. TBH the flywheel looks like a re-face wouldnt go amiss either.
Looks like the driven plate has chamfered splines on both sides.
So are you sure it was the right way round
Looking at the original picture when installed you can just see the circle of the extra plate that is on one side of the plate, thats shown in the last bit of the video clip. Ive not seen a plate with an extra section on one side like that.
Take a close look on the heads of the 4 bolts, please.
Yes thats the clue for the prate the wrong way round or a wrong plate as you can see the scuff marks, well spotted Marco.
I noticed those scuff marks - that's why I said the bolts were new with 0 miles on them. Those marks are from the limited use of me trying to get the car in gear... not good, I know.
The plate has a "long" side for the input shaft to fit into and a "short" side. I originally installed it with the long side towards the flywheel. Should I reverse it so the long side is towards the clutch?
Is this a reference to what I'm calling the "long" side of the plate? Where the input shat interfaces with the drive plate?
On the friction plate should be stamped „Flywheel side“.
I would scrap it, by fitting it wrong the tiny links have been bended / stressed
Jamie,
with the friction disc and clutch cover installed correctly you install a „bridge“ across the assembly.
Adjust its high for examble 100 mm in distance to the engine flange on both ends,
86 mm on the next photos is because of other reasons.
Now you can measure from the bridge down to the toothed sleeve, for example 15 mm.
100 -15 mm, the sleeve reaches 85 mm in the gearbox bell.
Now you put a level across the gearbox bell and measure down to the top end of the tube of the cover.
The dustance must me at least 5 mm more than your calculation above.
If not, cut the tube shorter. That‘s it!
I would also scrap the plate, it definitely doesn’t look correct for this application anyway, and as I said before I would have the flywheel refaced and either change the nose cover for the correct one or get it cut down to the correct length as I illustrated.
Very glad to see TRF up and running again, I wasn't aware of that! I ordered the forks from them.
The plate, diaphragm clutch and an oversize throw-out bearing (from a company called Koyo) were all part of a kit I purchased over ten, perhaps even fifteen, years ago. It was supposed to be a direct replacement for what I had installed at 72K miles 35 years ago. I ran that diaphragm clutch up until 2022 with the current nose...
I ordered the new, shorter nose. There were several options for plates - I'm not sure how to proceed... With the correct nose on the way, should I just get a whole new kit: clutch/plate/bearing?
I looked carefully, there's no indication stamped on the plate which end is flywheel....
Speaking of the flywheel: it feels really, really smooth with only those three darkened areas I couldn't clean up using 800 grit and a sanding block. Do you all think I should get it refaced? I guess if I remove it then I have access to that bushing... Don't know why but removing the flywheel feels like a huge defeat, but I know this is my opportunity to get it right.
Thanks for all your responses!
-Jamie
I would be inclined to get a new plate and have the flywheel refaced at the minimum.
I think that as the cause of the problems have already been discovered, ie the plate being fitted the wrong way round and catching the flywheel bolt heads, and the damaged clutch fork, I would be happy to just replace those parts and put it back together again. Flywheel looks fine to me, just a few marks where the grooves in the plate have rested which will soon disappear. I am slightly puzzled that I cannot see any marks on the clutch plate where it has been catching the bolt heads. I wouldn`t replace a perfectly good, new, pressure plate or release bearing, and the plate itself may well be ok to re use but as a precaution it would be best to replace.
Ralph
Current status: my first time using an angle grinder was a success, the cross shaft is cut and both ends are removed! Waiting on parts delivery for reconstruction.
I'm curious to know how one removes the bushings from the bellhousing. I'm thinking of using a short bit of oversize diameter PVC tubing on the outside pulling a right-size piece of tubing on the inside with a long bolt. Does that sound plausible?
Thren, once the old bushings are out, what is the best method of installing new?
Also, thinking ahead... I have seen some videos where people drill a hole in the fork 90 degrees to the tapered pin and insert a second bolt. Any thoughts on this? I could use my old setup for practice.
Thanks- Jamie
Yes cross drill the fork and shaft and add the through bolt and nut to gain more security between the fork and shaft.  The taper pins are a menace if they sheer and are a very poor design to start with, being in single sheer.   Roger came up with a through bolt solution using a reamed hole in the shaft.  More faffing.  Just cross drill and add the additional nut and bolt as many others have done.  1/4” diameter bolt is sufficient in size.  I had a small stock of 5 mm diameter roll pins and have used them in the past   All used up now.
I remember I used a threaded bar some suitable nuts and washers to pull them out and the new ones in.
YES, fit a cross bolt, please! I fitted a 1/4" bolt with nylon nut, others fit a roll pin 1/4" (maybe better, but poor tho fit).
And check the tapered bolt for best fit, there is a lot of "look like suff" to buy.
I did this many, many years ago, but it may be helpful to Jamie to give an idea of the bolt size. I've forgotten what I used, but was always a bit concerned that too small could still snap, too big might compromise the cross shaft strength.
Charlie.
EDIT.... Marco beat me to it by giving an answer :D
Edited by Charlie D
I know there is a discussion abouth the benefit of a roll pin
or a tight fit of the bolt and shear forces and the disadvantage of a simple slack bolt and nut.
I heard about long after the I fitted the poor 1/4" bolt and nut,
never told the car about this, and it worked well as long I used this construction.
I just locked the nut tight and forgot. But it can be made always better.
AP1GczOhm3rwIDxBxsM0vYToHD8XWtE88RfUK5QR
Starting to get things ready for re-installation.
I used my old fork for practice instaling the addittional through-bolt on the fork. The process was as follows:
  • Drill a 1/8" pilot hole through entire assembly
  • Drill a 1/4" hole through front of fork and shaft, stopping before I reached the back of fork
  • Drill a 13/64" hole through the remaining space
  • Tap the 13/64" hole to 1/4" coarse thread 20 TPI (I used a coarse thread as that was the only one I had at the time)
  • Insert a 1/4" shoulder bolt from the front, thighten it down and use nyloc nut on the back
This is how it looks:
Washers needed? Should I cut the protruding part of the bolt down to the nut? Use 28 TPI bolt?
Also...
I have he input shaft nose removed. What kind of grease should I use there and on the new cross shaft bushings? Lastly, I was surprised there isn't a gasket where nose attaches, what should I use a a sealant for this area?
Thanks in advance for taking a look!
-Jamie
Edited by My Dads Car
Also...
-Jamie
There should indeed be a gasket for the nose cover, there is also an oil seal fitted inside the nose cover, double lip seals are favourite for that and the bolts holding it on should have copper washers to help seal as theres oil in there from the box so no grease. I take it youve shortened the original nose piece to the specified 2"
I ordered a new 2" nose piece, waiting on arrival.
This is what I found when I pulled the nosepiece:
Looks like the person who put this together used a form of Permatex "Form a Gasket" to seal things up... And it is definitely greased, no oil as far as I can tell. Looks like he used plain steel washers as well.
Am I missing anything else here before I order?
-Jamie
Hi Jamie,
you see the clip holding the main baering?
The clip has a gap, this gap must be in the 21:00 position, yours is on 20:00.
And the cover has a matching canal, also to fit at 21:00.
This is the oil return for the oil pressed through the bearing by its own centifugal forces.
Fit a new lip seal, clean the surfaces and fit a new gasket + copper washers under the heads of the 4 bolts.
If you get a new fork i recommend to drill through in line with the thread with a for example 4 mm drill.
This will make it easier to tap the coned bolt out for the case it will break.
AP1GczOJDtydDEqBnUuxTz9KqfaoxRzkRts8QcWa
Questions... always more questions...
The new nose and cross shaft came in today.
The old one has an inner sleeve the new one doesn't. Do I remove that sleeve and transfer it to the new nose? Also, the channel for the oil on the new sleeve does not extend as far as the old one did. Is this a problem?
Regarding the cross shaft:
The old one has the groove for that locating bolt, the new one (obviously) does not. Did I order the wrong part or are they interchangeable? Do I need to tap for zerk fittings with this un-grooved shaft?
-Jamie
