Z320 Posted July 7, 2023 Report Posted July 7, 2023 (edited) On 12/22/2022 at 6:30 PM, Z320 said: Hi, I compared cheap standard pads and the expensive 1144 pads the same day, driving my standard test loop. I expected no basic difference. But indeed the 1144 pads are better, in my opinion not the way to let me make air jumps, but indeed better and worth to spend the money. Ciao, Marco Hi, currently the Mintex 1144 pads are annoying me very much with often (not always) very loud sqeaking on low speed braking, for example rolling in a traffic jam or to a red traffic light. This is mostly in town / village and pedesrtians pedestrians notice me negative. Any idea? Ciao, Marco Edited July 7, 2023 by Z320 right letters in the wrong sequence Quote
BlueTR3A-5EKT Posted July 7, 2023 Report Posted July 7, 2023 (edited) 5 minutes ago, Z320 said: Hi, currently the Mintex 1144 pads are annoying me very much with often (not always) very loud sqeaking on low speed braking, for example rolling in a traffic jam or to a red traffic light. This is mostly in town / village and pedesrtians notice me negative. Any idea? Ciao, Marco Do the brake pad friction material have a slot in them? I found the slot added with a saw cured the squeal of my brakes many years ago. read these thoughts perhaps https://www.brakeandfrontend.com/brake-pad-chamfers-slots-shapes-controlling-brake-noise/ Edited July 7, 2023 by BlueTR3A-5EKT Quote
RogerH Posted July 7, 2023 Report Posted July 7, 2023 Hi Marco, if the pins are too tight, or the pads are too tight in their slots squeaking can be caused. There are anti-squeal shims available (Moss etc) but I have had no luck with them. There are 'rubber/plastic' shims that stick to the pads that work well. I first found these with 'GreenStuff' pads. Roger Quote
astontr6 Posted July 7, 2023 Report Posted July 7, 2023 On 12/15/2022 at 5:29 PM, Drewmotty said: M1144 pads is the only upgrade you need. Can you advise me of the Mintex part number for M1144 for a TR6 ? Thanks, Bruce. Quote
Drewmotty Posted July 7, 2023 Report Posted July 7, 2023 I’ve copied this from an earlier post: As for the 1144 pads - much better than standard search for MGB633 1144. You will get the ones with the smaller holes for the pins but it takes no time at all to enlarge with a drill. Far cheaper than seeking out the less common large holed pads. (Not sure you can get them with 1144material) Quote
DRD Posted July 7, 2023 Report Posted July 7, 2023 4 hours ago, Z320 said: Hi, currently the Mintex 1144 pads are annoying me very much with often (not always) very loud sqeaking on low speed braking, for example rolling in a traffic jam or to a red traffic light. This is mostly in town / village and pedesrtians pedestrians notice me negative. Any idea? Ciao, Marco Marco - I found the anti-squeal shims plus copious amounts of brake grease cured all my brake sqeaking. Darren Quote
Mike C Posted July 7, 2023 Report Posted July 7, 2023 10 minutes ago, DRD said: Marco - I found the anti-squeal shims plus copious amounts of brake grease cured all my brake sqeaking. Darren I've generally had good success with CRC Disc Brake Quiet, less so when I've used it with EBC Red Stuff pads. Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 Hi all and thank you, nothing suspicious, gaps are there, bolts move free, dull surfaces. What makes me wonder is how much they are down already. The ones on the outside some more than the ones on the inside. One step after one other, I broke the edges of the pads on the running on side. Out for a test drive down in the village now… Quote
Drewmotty Posted July 7, 2023 Report Posted July 7, 2023 6 hours ago, Z320 said: Hi, currently the Mintex 1144 pads are annoying me very much with often (not always) very loud sqeaking on low speed braking, for example rolling in a traffic jam or to a red traffic light. This is mostly in town / village and pedesrtians pedestrians notice me negative. Any idea? Ciao, Marco These worked well for me Marco https://www.ebay.co.uk/itm/312720241526?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=EeNOHQI-R3G&sssrc=4429486&ssuid=GeP3KodIRnW&var=&widget_ver=artemis&media=COPY Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 Noise gone…. What I really wonder is the wear out of this pads after only 7500 miles, I do not expect they will do much more than 10,000 Quote
RogerH Posted July 7, 2023 Report Posted July 7, 2023 15 minutes ago, Drewmotty said: These worked well for me Marco https://www.ebay.co.uk/itm/312720241526?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=EeNOHQI-R3G&sssrc=4429486&ssuid=GeP3KodIRnW&var=&widget_ver=artemis&media=COPY they are the rubbery/plastic things that I could not remember the name of. Roger Quote
Tim D. Posted July 7, 2023 Report Posted July 7, 2023 I used some rubber brake pad backing material for my 1144 pads. I think it was made by 3M. Almost completely eliminated squeels Tim Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 Sorry, I don’t want to have elastic material between pads and pistons. Quote
Tim D. Posted July 7, 2023 Report Posted July 7, 2023 15 minutes ago, Z320 said: Sorry, I don’t want to have elastic material between pads and pistons. Intersted, Why not? Many pads have some form of elastic material between? Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 To get a as solid and direct reaction of the brake as possible? “Druckpunkt“ ——> „pressure point“ Quote
Drewmotty Posted July 7, 2023 Report Posted July 7, 2023 2 hours ago, Z320 said: Sorry, I don’t want to have elastic material between pads and pistons. I understand your point but you don’t need to be concerned. I have all braided hoses and even with the backing pads and silicone fluid there is no noticeable sponginess. The change from rubber hoses made the most difference. Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 (edited) I used already elastic pads some years ago and have not been pleased. Braided hoses made no difference on my car because the rubber on the old ones has been only a cover over a Teflon hose. I‘m convinced the braided surface is only fake for our good customer feeling, the key is the Teflon hose. A friend of me working at Audi confirmed me this issue. I worked with braided material and also wire robes, they are very flexible. Edited July 7, 2023 by Z320 Quote
Drewmotty Posted July 7, 2023 Report Posted July 7, 2023 (edited) 32 minutes ago, Z320 said: I used already elastic pads some years ago and have not been pleased. …but were they 3M? Like all things there are differences in quality which translate to performance. They are cheap and easy to fit. Give them a try. Edited July 7, 2023 by Drewmotty Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 Using no elastic pads between….I don’t need to bother the quality? Yes I know, in many points I don’t follow the common opinion. Quote
Waldi Posted July 7, 2023 Report Posted July 7, 2023 I have the EBC Greenstuff and (I think) 3 M pads sticking on it. No squeals, never. Drewmotty’s remark about braided hoses has given me another job for the winter. Waldi Quote
ntc Posted July 7, 2023 Report Posted July 7, 2023 18 minutes ago, Waldi said: I have the EBC Greenstuff and (I think) 3 M pads sticking on it. No squeals, never. Drewmotty’s remark about braided hoses has given me another job for the winter. Waldi Get rid of them and get Hawk pads Quote
Waldi Posted July 7, 2023 Report Posted July 7, 2023 Hi Neil, they work ok, and I ordered them in 2016 because of…. recommendations on this forum. I have the larger Volvo servo, and have sufficient brake-force, but my pedal could be harder. I have just received an Easybleed to that off course is the first step. Cheers, Waldi Quote
Roadrunner Paul Posted July 7, 2023 Report Posted July 7, 2023 +1 for 3M. Cured some really piercing noises at times when I had Mintex pads, Quote
Z320 Posted July 7, 2023 Report Posted July 7, 2023 I bust ordered a new set from a different label Quote
