saffrontr Posted April 2, 2025 Report Posted April 2, 2025 Is it just me or my PC, why has the text on the forum changed to a light grey, it is almost unreadable? Derek Quote
Ransomes256 Posted April 2, 2025 Report Posted April 2, 2025 No issues on PC or Android phone. All looks as it should. Neil Quote
TR Rob Posted April 2, 2025 Report Posted April 2, 2025 When you “sign in” text reverts to normal ….. Quote
saffrontr Posted April 2, 2025 Author Report Posted April 2, 2025 Thanks, appears that I had to register as my email address was being used by someone else. I'm now a "newbie" but hey ho text is now back to normal. Derek Quote
Steve-B Posted April 3, 2025 Report Posted April 3, 2025 I realise there's one heckuva lot of work in transitioning to the new system. Where should we report potential bugs? I think I've found one -- on a normal desktop browser the text is unboleded but viewing the forums on an iPad/iPhone all the text is bolded which points to a rendering defect. Perhaps there's a setting in the new forum for mobile browser support not switched on? Thanks for everyone's work behind the scenes!!! Quote
TR NIALL Posted April 3, 2025 Report Posted April 3, 2025 7 minutes ago, Steve-B said: I realise there's one heckuva lot of work in transitioning to the new system. Where should we report potential bugs? I think I've found one -- on a normal desktop browser the text is unboleded but viewing the forums on an iPad/iPhone all the text is bolded which points to a rendering defect. Perhaps there's a setting in the new forum for mobile browser support not switched on? Thanks for everyone's work behind the scenes!!! On an iPad I also find the Text has shrunk in size and it ain’t to my liking. Quote
Chris Hale Posted April 3, 2025 Report Posted April 3, 2025 1 hour ago, Steve-B said: I think I've found one -- on a normal desktop browser the text is unboleded but viewing the forums on an iPad/iPhone all the text is bolded which points to a rendering defect. Perhaps there's a setting in the new forum for mobile browser support not switched on? It not bold on my iPad or iphone Quote
Steve-B Posted April 3, 2025 Report Posted April 3, 2025 2 hours ago, Chris Hale said: It not bold on my iPad or iphone on iOS 18.4 the appearance is only bold and creating text then trying to bold it looks the same. Quote
Hamish Posted April 4, 2025 Report Posted April 4, 2025 18 hours ago, TR NIALL said: On an iPad I also find the Text has shrunk in size and it ain’t to my liking. Niall I had the same issue on my iPhone you should be able to change the font size have a look at the screen shots where I have circled the screen areas which should help ? to see if it helps Quote
TR NIALL Posted April 4, 2025 Report Posted April 4, 2025 Thanks Hamish but I don’t seem to have those icons on my ipad but I’ve just pressed something and it’s got even smaller😂if I return it to Default the size increases but no bigger than what you now see,12 is smallest and Default is the largest that I can get. Quote
spaners Posted April 4, 2025 Report Posted April 4, 2025 Hi Derek. I reverted to a newbie initially with a rating of 1 but it sorted it self out after a couple of days. All seems ok now. Cheers, Pete. Quote
Chris Hale Posted April 4, 2025 Report Posted April 4, 2025 Niall On an iPad I think you have to change it through Settings Accessibility Display and Text Size Larger text size , select turn on then you can adjust the size using the slide barc Quote
TR NIALL Posted April 4, 2025 Report Posted April 4, 2025 22 minutes ago, Chris Hale said: Niall On an iPad I think you have to change it through Settings Accessibility Display and Text Size Larger text size , select turn on then you can adjust the size using the slide barc Thanks Chris I’ll try that as soon as I figure out where Settings are😉Cheers. Quote
Chris Hale Posted April 4, 2025 Report Posted April 4, 2025 It’s the gear wheel normally on your front/home screen Quote
Mick Forey Posted April 5, 2025 Report Posted April 5, 2025 If you have any issues with the forum but don't get any help from the forum, then send an email to moderator@tr-register.co.uk. Mick Quote
Lebro Posted April 6, 2025 Report Posted April 6, 2025 I find on both my PC & my Smart phone (Samsung) the the difference beween normal (read) & Bold (not yet read) topic headings is not as pronounced as it was before. Is it just me ? (In the line above the difference is very pronounced) Also I find it confusing that we have a "Chat" section inside the main "Chat" can it not be called something else - like "Social scene" as before ? Bob Quote
brian -r Posted April 6, 2025 Report Posted April 6, 2025 Hi Bob All the settings are as handed over and I understand this is an updated version of Invision not as used before. A lot is working ok but some issue's around our taking over full admin of the forum are still to be resolved. I'm sure over the the next week or so we will be able to sort things, at the moment we are taking things slowly and feeling our feet. We don't want to crash the forum😬 Bri Quote
TR Rob Posted April 6, 2025 Report Posted April 6, 2025 1 hour ago, Lebro said: I find on both my PC & my Smart phone (Samsung) the the difference beween normal (read) & Bold (not yet read) topic headings is not as pronounced as it was before. Is it just me ? (In the line above the difference is very pronounced) Also I find it confusing that we have a "Chat" section inside the main "Chat" can it not be called something else - like "Social scene" as before ? Bob Contrast regarding text all OK on my iPhone11. Quote
RobH Posted April 6, 2025 Report Posted April 6, 2025 (edited) You don't really need a large contrast change anyway. If a post is un-read there is a large dot or star before the text. Once read, that turns a very light grey (star) or disappears (dot) so it's pretty obvious. Edited April 6, 2025 by RobH Quote
Chris Hale Posted April 6, 2025 Report Posted April 6, 2025 For Apple users I have just found the way you increase the text size on any open browser page. In the search bar there is a oblong/square with two lines underneath it Click on this and a box opens In the center of the box you will see either A A or a number followed by % Tap the A’s or the number to increase or decrease the text size on that page Quote
RobH Posted April 6, 2025 Report Posted April 6, 2025 42 minutes ago, Chris Hale said: For Apple users I have just found the way you increase the text size on any open browser page. Maybe on i-phone but not on a Mac computer Chris. On a Mac desktop or laptop you just type "command +" together to increase the size or "command -" to decrease it. Quote
Lebro Posted April 6, 2025 Report Posted April 6, 2025 1 hour ago, RobH said: You don't really need a large contrast change anyway. If a post is un-read there is a large dot or star before the text. Once read, that turns a very light grey (star) or disappears (dot) so it's pretty obvious. Do you know - I have never noticed that dot ! Must try harder Bob Quote
TR NIALL Posted April 6, 2025 Report Posted April 6, 2025 2 hours ago, Chris Hale said: For Apple users I have just found the way you increase the text size on any open browser page. In the search bar there is a oblong/square with two lines underneath it Click on this and a box opens In the center of the box you will see either A A or a number followed by % Tap the A’s or the number to increase or decrease the text size on that page Hi Chris can you explain that a bit better as this is all I’m getting when I open the Forum Page,Cheers from a Apple Numpty. Quote
Chris Hale Posted April 6, 2025 Report Posted April 6, 2025 2 hours ago, TR NIALL said: Hi Chris can you explain that a bit better as this is all I’m getting when I open the Forum Page,Cheers from an Apple Numpty. I Niall I will try to Hopefully these two screen shots will show you Although looking at your screenshot more closely I have realised that I suspect you are using Google where as I use Safari as my browser. I have had a look but can’t see how you change it Google This is how big I can make it go using Safari Hope this is helpful Quote
