Tim T Posted April 8, 2025 Report Posted April 8, 2025 Went out for a drive the other day and the car ran very well. However, I noticed that the temperature gauge moved only just out of the white square on the left. Today I checked the thermostat which was fine and opened at 82 degrees, but I changed it anyway. Took the car out again and now there is no movement at all. This leaves the sensor and the gauge. What checks can I do for these please? Any other suggestions? Many thanks, Tim Quote
RobH Posted April 8, 2025 Report Posted April 8, 2025 I assume the fuel gauge is reading normally, which eliminates the gauge voltage regulator? If both gauges don't read, the regulator or the connection to it is duff. If that is OK, take the lead off the temperature sender and earth the lead. With the ignition on, the gauge should go full-scale to hot. (best to first take the power supply lead off the coil to prevent cooking it and/or any electronic ignition if that is fitted.) If the gauge does not budge the fault may be the wire connection, or the gauge itself. Most likely the wire which could have broken near the spade connector where it can waggle. Quote
Tim T Posted April 8, 2025 Author Report Posted April 8, 2025 17 minutes ago, RobH said: I assume the fuel gauge is reading normally, which eliminates the gauge voltage regulator? If both gauges don't read, the regulator or the connection to it is duff. If that is OK, take the lead off the temperature sender and earth the lead. With the ignition on, the gauge should go full-scale to hot. (best to first take the power supply lead off the coil to prevent cooking it and/or any electronic ignition if that is fitted.) If the gauge does not budge the fault may be the wire connection, or the gauge itself. Most likely the wire which could have broken near the spade connector where it can waggle. Thanks for reply Rob. All other gauges are working fine. Will do as you suggest tomorrow. Cheers, Tim Quote
Tim T Posted April 9, 2025 Author Report Posted April 9, 2025 Rob, All checked, as you suggested, and the gauge works fine so a new sensor is on it's way. Very many thanks, Tim Quote
stuart Posted April 9, 2025 Report Posted April 9, 2025 47 minutes ago, Tim T said: Rob, All checked, as you suggested, and the gauge works fine so a new sensor is on it's way. Very many thanks, Tim Make sure it has a black ring round the centre where the wire goes on and not a red one like most supply. otherwise you`ll be reading too high on the gauge. Been there done that a few times now. The red ring one is TR7/Dolomite not TR4/5/6. Stuart. Quote
Tim T Posted April 9, 2025 Author Report Posted April 9, 2025 2 hours ago, stuart said: Make sure it has a black ring round the centre where the wire goes on and not a red one like most supply. otherwise you`ll be reading too high on the gauge. Been there done that a few times now. The red ring one is TR7/Dolomite not TR4/5/6. Stuart. Coming from from TR Shop so hope it’s correct, but will check. Many thanks Stuart. Tim Quote
stuart Posted April 9, 2025 Report Posted April 9, 2025 40 minutes ago, Tim T said: Coming from from TR Shop so hope it’s correct, but will check. Many thanks Stuart. Tim Hopefully should be right as I did tell them the difference a while ago but sadly most suppliers only hold stocks of the red ones. Stuart. Quote
BlueTR3A-5EKT Posted April 9, 2025 Report Posted April 9, 2025 5 hours ago, stuart said: Hopefully should be right as I did tell them the difference a while ago but sadly most suppliers only hold stocks of the red ones. Stuart. Ahh. The old chestnut. Intermotor 5271 being supplied when Intermotor 5273 is the correct item. Quote
Phil Read Posted April 10, 2025 Report Posted April 10, 2025 I have this problem. gauge tested ok, changed transmitter (twice), still the same. If stuck in traffic the gauge rises slightly. Quote
RobH Posted April 10, 2025 Report Posted April 10, 2025 26 minutes ago, Phil Read said: changed transmitter (twice), still the same. If the gauge and connecting wire work OK but changing the sender doesn't fix things, either you are being sold the wrong sender or somehow it is not connecting to earth through its body. Quote
Tim T Posted April 10, 2025 Author Report Posted April 10, 2025 (edited) Yesterday I fitted a secondhand sensor which a friend had just to see what changed. Went for a drive and the gauge sat at half way between cold and normal. Will replace it and fit the new one which is on its way. When I took the old sensor out it had a fibre washer. That will be affecting the earth, won’t it? Tim Edited April 10, 2025 by Tim T Quote
stuart Posted April 10, 2025 Report Posted April 10, 2025 (edited) 16 minutes ago, Tim T said: When I took the old sensor out it had a fibre washer. That will be affecting the earth, won’t it? Tim Shouldnt matter.. Stuart. Edited April 10, 2025 by stuart Quote
Tim T Posted April 10, 2025 Author Report Posted April 10, 2025 …. of course it wouldn’t, the thread will create the contact, doh!! Tim 12 minutes ago, stuart said: Shouldnt matter.. Stuart. Quote
Lebro Posted April 10, 2025 Report Posted April 10, 2025 16 hours ago, BlueTR3A-5EKT said: Ahh. The old chestnut. Intermotor 5271 being supplied when Intermotor 5273 is the correct item. Just looked to see what colour my sensor was ( fitted to my TR3 when changing from capillary type) its red ! No wonder I had so much trouble calibrating the gauge to it. Anyway its done now so won't be swapping for the black one. Bob Quote
Tim T Posted April 10, 2025 Author Report Posted April 10, 2025 Fitted the new sensor (correct one) this morning and went out for a 20 mile drive. Gauge never rose as it should, see image. So, currently the car has a new sensor, new thermostat and the operation of the gauge has been tested. The new sensor performs exactly the same as a used one. All hoses get hot, heater works. Could the calibration of the temp gauge suddenly fail? All was well last week. Is there any way of checking the accuracy of the gauge. I have put an infrared thermometer on radiator, top hose, thermostat housing, bottom hose and nothing looks untoward. Am now slightly baffled. Have i missed anything? Cheers, Tim Quote
RobH Posted April 10, 2025 Report Posted April 10, 2025 The easy way to test this is if you have an Ohm meter. When hot at around 80degC the resistance of the sender to earth should be 95-100 Ohms if you have the correct GTR108 sender. If that is OK, the gauge calibration must have changed somehow. Quote
Tim T Posted April 10, 2025 Author Report Posted April 10, 2025 32 minutes ago, RobH said: The easy way to test this is if you have an Ohm meter. When hot at around 80degC the resistance of the sender to earth should be 95-100 Ohms if you have the correct GTR108 sender. If that is OK, the gauge calibration must have changed somehow. I do have GTR108 and a multimeter! But that is the limit of my technical knowledge here Rob. I assume that I set the meter to resistance, black probe in common, red to one marked ohms. Do I need to remove the sender from the circuit ie put in on the bench? Any further tutorial very gratefully received! Many thanks, Tim Quote
RobH Posted April 10, 2025 Report Posted April 10, 2025 (edited) You can do it in-situ Tim. With the meter set to resistance , disconnect the wire from the sender. Put one probe on the centre contact and the other on the sender body - it doesn't matter which way round the leads are. When cold the resistance should be about 1400 Ohms and when hot at 80ºC about 100 Ohms. The resistances are only approximate - this is not a precision instrument so there could be a variation. Edited April 10, 2025 by RobH Quote
Tim T Posted April 12, 2025 Author Report Posted April 12, 2025 Rob, I have now had a chance to take some measurements! Put both a new (TR Shop) sensor and a used one in a pan of boiling water and left to get hot S/H unit gave a reading of 105 ohms and the new one 180 ohms! When cold they read 1000 ohms and 1760 ohms respectively. These seem a long way off your suggestions, so I have a professional coming to give his opinion on Wednesday. Fingers crossed. Many thanks for your help. Tim Quote
RobH Posted April 12, 2025 Report Posted April 12, 2025 Both should read a lot lower than that at boiling point, which is probably why your gauge isn't moving far. The new one is obviously a long way off being the correct type or is faulty. Unfortunately there isn't much information on the web on what the resistances should be and what there is tends to be contradictory. I have a data range for the GTR104 but only a couple of points for the GTR108 . The consensus I can find is that half-way on the temperature gauge is around 100 Ohms. If all else fails It is possible to calibrate the gauge to suit the sender. Note the slots do not turn - they sort of slide side to side. (This procedure is from a US source so ignore the note at the end). Quote
