Jimgreen01 Posted April 19, 2025 Report Posted April 19, 2025 Hi all, I've had my battery out for a while and my electrical work has taken FAR too long to complete. Can someone please translate the switch positions (1-4) in the attached AAW wiring diagram to the actual key positions in the switch? My switch has the off position at 12 o'clock, an 11 o'clock position, a 1 o'clock position and the 2-ish momentary position for starting. I am managing to confuse myself with the switch wiring! Thanks. tr4 wiring diagram.pdf Quote
RobH Posted April 19, 2025 Report Posted April 19, 2025 (edited) Those numbers are the pin numbers Jim, not the operating positions. I believe your switch is connected like this (the green wire could go on either of the two tags at '4'): 11 o'clock 1>>4. (auxilliary power to instruments etc only ) 12 o'clock OFF no connections 1 o'clock 1>>2 & 4. ( ignition on - normal running) 2 o'clock 1>>2 & 3 (ignition on - cranking) Edited April 19, 2025 by RobH Quote
Jimgreen01 Posted April 19, 2025 Author Report Posted April 19, 2025 Thanks again Rob. Very much appreciated. Clearly electrics not my forte Quote
