Hi all,
I've had my battery out for a while and my electrical work has taken FAR too long to complete.
Can someone please translate the switch positions (1-4) in the attached AAW wiring diagram to the actual key positions in the switch?
My switch has the off position at 12 o'clock, an 11 o'clock position, a 1 o'clock position and the 2-ish momentary position for starting.
I am managing to confuse myself with the switch wiring!
Thanks.
tr4 wiring diagram.pdf
Those numbers are the pin numbers Jim, not the operating positions.
I believe your switch is connected like this (the green wire could go on either of the two tags at '4'):
11 o'clock  1>>4.        (auxilliary power to instruments etc only )
12 o'clock OFF no connections
1 o'clock  1>>2 & 4.      ( ignition on - normal running)
2 o'clock 1>>2 & 3       (ignition on - cranking)
Edited by RobH
