2 hours ago, Andy Moltu said:
It seems a lot of effort.
I have fun with it :lol:
Making a second set is boring already.....
I love Marco’s engineering abilities I really do, and wish I could do half the things he can, but in you car with this issue, why wouldn’t you just put a switch to earth the coil?
1 hour ago, John Morrison said:
Ah so that won’t work then,
Understood
FIRST - it has to work!
Another name for running on is ‘dieseling’. In other words the spark isn’t needed, the fuel air mixture ignites spontaneously under compression.
About heat, pressure, coak and explosion without ignition spark
I like that guy and his experiments
ready to ship, this is the hole story:
This Pierburg valves for VW I made suitable to fit 175 CD Stromberg carbs with the "brass plug" from below on the float camber lid.
AP1GczNqwJkskk9zeCbEzdnVChC4OqN-TGX-Kb-2
Indeed the "brass plug" is only a covered plastic plug, easy to get out.
AP1GczNb5UO4NakHij9wYW0nIBGrLC2faOXeLS45
The plastic plug holds the o-ring, sealing the lid in the bore. I had to solve this different because of limited space / diameter.
AP1GczOeUtL2AoBaOyNktio_4_WDVK3-V3y0eI5C
With the lid back on the carb a "snokel" is visible, via this the petrol gets up to the jet, inside there is the jet needle.
AP1GczMFG7DGeGkzRGFny_beLbRv-GM4hHIAuStr
The "snorkel" is needed because the jet is on a higher level than the max fuel level in the float chamber.
AP1GczOrY2Rx1Q9AiOTfn36MJG83G17h6jxdhFMp
The issue is to  connect the Pierburg valve with a o-ring this "snorkel", a 10 mm and a 4 mm brass bush helps.
AP1GczNci6p18oNxpqEX8dWglE4BJrtlp06_1BLE
Two tight loops of wire (Michael: don't unroll it) are pushed on the "snorkel" (yes, a bit fiddly)
AP1GczO6PZub_-k2VDlg33Exq7NERruqpPnm8uR0
Next a bush shaped like a "sewing thread bobin" is needed to connect "snokel" with the valve (inside) AND and to get the fuel down to the valve (outside).
AP1GczN1R4eajASCocRecRs40UPtLw9Von1FI9dG
Like this, later the "bobin" is no longer visible and no issue of any attention.
AP1GczMm9WF4LKPftEgZjY8ohQuVTA4teCtQNSzm
AP1GczOiBat-VgeVvRPIpvlgIi8iZZL1HKqYkRpa
Because it is inside the valve holder
AP1GczO0MMid_GrTcaSDt9W6oEMlzOosaIUaRjOT
This way the unit is fitted on the "snorkel" / on the carbs.
AP1GczOaVZAmxum_-DPvuQDSbvsce5a3pHI8Eo9M
I mentioned there is no space to seal to the lid like original,
I did it with a o-ring in a groove / on a flange, as I know it from my BMW R90S with Dellortos (fibre there)
AP1GczPRFkHmL6clyQBYG7GYPQW1Y0EGQzg_zat8
Assembly the whole issue: the valve holder first and SLACK through the lid.
AP1GczN7YXpchXDuDjYPBirzRu8vLtgzdjTSn3Db
Next the 6 screws SLACK though the lit, next the valve holder slightly tight (the original plug is not even tight!)
AP1GczNHsIzI9wBv9ImvSgf5nYqwBfSfN6LAL82k
Next the 6 screws tight. One edge has e drilling for a 1 mm wire to secure it anywhere on the carb.
AP1GczMM4_RvUKxEGu_ochO-2g_YcltCm44eSBde
I made a clip o fit under the next screw clockwise, if nothing usable is possible on the carb.
AP1GczMBOJ2yDSRgU7nv44aD0bBJqxfdKMq3cZ9s
This Pierburg valves are switched open, this is why they can simple be connected to an igintion switched terminal.
Iginition on -> valve opend, ignition off -> valve closed. I would connect it to the + terminal of the ignition coil.
AP1GczPE7qsqF-FWRyceTjQdivyLO5lNfdFQiu_B
If they fail, they stay closed. For this unlikely issue I recomment to carry the original plugs and o-rings in the cloves box or boot!
Ready to go out to Dortmund tomorrow to be installed and tested.
AP1GczOM5JcCzsO6uclIMAiKz9Xw5s3DkHwglUAK
The construction is very close to the Mercedes Benz construction, this is why I hope it works.
Perhaps the carbs need a slightly new adjustment, but I guess this is not needed.
Looking forward to hear from Michael.
empty lines out at the end of the post, wrong writing
  • 8 months later...
Report from my mate Michael:
the valves are installed and the engine does no longer run on.
He is very pleased and is looking forward for the summer without this problems.
Well done Marco, nicely engineered. 👍
