dblenk Posted September 30, 2025 Report Posted September 30, 2025 New pads classic gold with drilled discs got a squeal last year thought it was the rear so new shoes classic gold cleaned etc etc think its the front pads not the rear squeal still there seen a few kits on ebay for shims and goop any recommendations cheers David Quote
Paul Hig Posted September 30, 2025 Report Posted September 30, 2025 Had a squeal issue on my 6. Turned out to be the pins holding the pads were corroded, so not allowing the pads to move freely. New pins and now no squeal Quote
dblenk Posted September 30, 2025 Author Report Posted September 30, 2025 6 minutes ago, Paul Hig said: Had a squeal issue on my 6. Turned out to be the pins holding the pads were corroded, so not allowing the pads to move freely. New pins and now no squeal yeah the kits come with pins and clips just with ebay some are better than us i was wondering if anyone has bought one David Quote
Z320 Posted September 30, 2025 Report Posted September 30, 2025 (edited) Hi, due to the Ate „Brake Manual“ (German) it is the brake pads digging in the disk. To avoid this the load must be more on the running off side of the pad. Porsche used special pistons, Toyota a small and a bigger piston, what I call „half shims“ do that job very well. This is what I recommended to use here several times / postes, I use them too. Ciao, Marco Edited September 30, 2025 by Z320 Quote
RogerH Posted September 30, 2025 Report Posted September 30, 2025 They worked perfectly on both the TR4 and TR4A Roger Quote
Z320 Posted September 30, 2025 Report Posted September 30, 2025 „full shims“ can be cut in shape with a scissors Quote
John Morrison Posted September 30, 2025 Report Posted September 30, 2025 3M anti squeal pads from Big Red John Quote
PodOne Posted September 30, 2025 Report Posted September 30, 2025 9 hours ago, Z320 said: Hi, due to the Ate „Brake Manual“ (German) it is the brake pads digging in the disk. To avoid this the load must be more on the running off side of the pad. Porsche used special pistons, Toyota a small and a bigger piston, what I call „half shims“ do that job very well. This is what I recommended to use here several times / postes, I use them too. Ciao, Marco +1 for Marco's advice the above shims plus Mintex brake grease and I've no issues now for past 16 months or so. Quite as a mouse. Had tried 3M shims, full shims, copper slip, filed pads, pad springs and new pins all failed. Andy Quote
8iggles Posted October 3, 2025 Report Posted October 3, 2025 The shims on e-bay like the ones Marco recommends are for the 3/16" pins. Even the ones listed as fitting the earlier TRs: TR4, TR4A, TR5, TR6. These TRs need the shims with 1/4" holes to fit the imperial callipers. Just make sure you get the correct ones for your TR. It cost me half what I paid to send them back! John Quote
dblenk Posted October 3, 2025 Author Report Posted October 3, 2025 1 hour ago, 8iggles said: The shims on e-bay like the ones Marco recommends are for the 3/16" pins. Even the ones listed as fitting the earlier TRs: TR4, TR4A, TR5, TR6. These TRs need the shims with 1/4" holes to fit the imperial callipers. Just make sure you get the correct ones for your TR. It cost me half what I paid to send them back! John i am a late 6 so metric callipers Quote
Z320 Posted October 3, 2025 Report Posted October 3, 2025 (edited) I used a drill, with the shims in a machine vice! Edited October 3, 2025 by Z320 Quote
greasemonkey Posted October 3, 2025 Report Posted October 3, 2025 I have Willwood calipers & discs... with a squeal ! How thick are the shims? If I understand correctly, the half shim goes behind the pad effectively tipping the piston slightly towards the direction of travel. So the piston puts pressure on its trailing edge first?? Or have I got the wrong end of the stick here?? Phil Quote
Z320 Posted October 4, 2025 Report Posted October 4, 2025 (edited) The half shim gives the force more on the running off side of the pad and less on the running on. Imagine you are water skiing on a flat wooden board / water ski. You load your weight on the rear of the board / ski to slide up on the water. And not on the front to avoid diving with the board down in the water. I hope my explanation is good enough? On Willwood calipers I with 4 pistons I would do an experiment with 3/4 shimps, but due to responsibility I‘m not telling anyone to do experiments with brakes. Toyota did that with a smaller and a wider piston (hopefully TR owners using them have installed them correctly…) Better ask Willwood what they recommend. The shims are only about 0.5-0.6 mm solid. Ciao, Marco Edited October 4, 2025 by Z320 Quote
Z320 Posted October 4, 2025 Report Posted October 4, 2025 On 9/30/2025 at 10:54 AM, Z320 said: The gray „wedge“ is a tool to turn the Porsche piston (with its offset) in the correct position. After adjusting, the tool is removed. Where it has been for adjusting the piston, the piston has NO contact to the brake pad. I’a afraid I can’t explain the issue better, but for any more question please ask. Quote
