Steve Morris Posted October 2, 2025 Report Posted October 2, 2025 (edited) As above, any recommendations for sourcing a thicker head gasket would be very useful. I have tried Cometic but am not getting any response from them. It looks like they only do the thicker head gasket for the earlier flat block. A very smart friend has calculated my CR as being 10.6:1 and I would really like to bring this down to 9.5 - 9.75:1 if possible. Edited October 3, 2025 by Steve Morris Quote
Malbaby Posted October 2, 2025 Report Posted October 2, 2025 4 hours ago, Steve Morris said: As above, any recommendations for sourcing a thicker head gasket would be very useful. I have tried Cometic but am not getting any response from them. It looks like they only do the thicker head gasket for the esrlierflat block. A very smart friend has calculated my CR as being 10.6:1 and I would really like to bring this down to 9.5 - 9.75:1 if possible. Has your friend calculated how thick a gasket is required to achieve the desired CR. Apart from having one custom made [expensive], you could use two gaskets. You will also have to check the valve train geometry after fitment. Quote
Waldi Posted October 3, 2025 Report Posted October 3, 2025 Another head could also be an option, if this one is too much skimmed. That would be a permanent solution. Revington (and others) sell solid copper gaskets up to 1.5 mm, not sure if they would be ok for recessed blocks: https://www.revingtontr.com/product/rtr1489-1.5k/name/head-gasket-copper-15mm-thick-fi-tr25056 Waldi Quote
Steve Morris Posted October 3, 2025 Author Report Posted October 3, 2025 8 hours ago, Malbaby said: Has your friend calculated how thick a gasket is required to achieve the desired CR. Apart from having one custom made [expensive], you could use two gaskets. You will also have to check the valve train geometry after fitment. Thanks for your reply. He actually thinks 10.6:1 static is ok on the long stroke engine. I’m just a bit nervous about that myself. I think that a thicker gasket will improve valve geometry in my case as the pushrods are standard length, bizarrely. Would a double gasket solution be potentially weaker? it may be a case of just moving this head on I think. Quote
Steve Morris Posted October 3, 2025 Author Report Posted October 3, 2025 1 hour ago, Waldi said: Another head could also be an option, if this one is too much skimmed. That would be a permanent solution. Revington (and others) sell solid copper gaskets up to 1.5 mm, not sure if they would be ok for recessed blocks: https://www.revingtontr.com/product/rtr1489-1.5k/name/head-gasket-copper-15mm-thick-fi-tr25056 Waldi Thanks Waldi - Revington do have a thicker copper gasket - up to 2mm I think but it is very expensive - still an option though. Quote
Steve 286 Posted October 3, 2025 Report Posted October 3, 2025 Have you checked the head thickness as a standard early head with part number 516816 is 3.400 inches thick and the later heads including some pi can be thicker around 3.500-3.550 inches thick Quote
Steve Morris Posted October 3, 2025 Author Report Posted October 3, 2025 Hi Steve, yes I have it’s around 3.350 - have also buretted the chambers. Quote
Steve 286 Posted October 3, 2025 Report Posted October 3, 2025 My cylinder head is 3.300 but it has been ported Quote
Steve Morris Posted October 3, 2025 Author Report Posted October 3, 2025 Ah - any issues with pinking or is it fine? Quote
Steve 286 Posted October 3, 2025 Report Posted October 3, 2025 It runs fine but I use e5 fuel and I had Martin rebuild the distributor Quote
Phil Kirk Posted October 3, 2025 Report Posted October 3, 2025 13 hours ago, Steve Morris said: Thanks for your reply. He actually thinks 10.6:1 static is ok on the long stroke engine. I’m just a bit nervous about that myself. I think that a thicker gasket will improve valve geometry in my case as the pushrods are standard length, bizarrely. Would a double gasket solution be potentially weaker? it may be a case of just moving this head on I think. Steve on the for sale wanted Trseks is offering a TR6 cylinder head for free. Looks like it could be what you are looking for? Cheers Phil Quote
Steve Morris Posted October 3, 2025 Author Report Posted October 3, 2025 Phil, that’s an incredibly timely heads-up! I owe you a pint. Quote
