IanCoop Posted October 5, 2025 Report Posted October 5, 2025 Hi! I am looking to replace my injector bushes (nylon, push fit with o-rings) but don't know how to get them out of the throttle body without damaging things. Does anyone have any handy tips please? Thanks Quote
PodOne Posted October 7, 2025 Report Posted October 7, 2025 Welcome to the forum Ian. From memory I think I used a small screw driver and gently levered them out. I'm sure others will be along to offer advice as well. Andy Quote
Tom B Posted October 7, 2025 Report Posted October 7, 2025 Probably a good idea to use the keeper. Leave it in place and lever on that (removing the nut... and push to one side). I always use silicon grease on the O rings but if they have been in a while they can be awkward. Replacement O rings from Polymax: Good Luck Quote
harrytr5 Posted October 7, 2025 Report Posted October 7, 2025 I/4" wood chisel. Tap into the nylon without going through and just prise out. Regards Harry Quote
Steve-B Posted October 8, 2025 Report Posted October 8, 2025 1. Hold metal injector with soft pliers from the end the fuel line goes into 2. Get wife's hair dryer, put on medium, point at nylon bushing for ±1min 3. Gently pull it away from you with a set of pliers, and it should slide right off (forgot to add) 4. Wipe wife's hair dryer off, sneak back into the house before she discovers what you're doing 😉 Quote
