Z320 Posted November 6 Report Posted November 6 (edited) Hi, who did steel browning with vinegar and has own experience for me, please. The steel is a J235 pipe and 2 pieces of machinery steel. Cheers, Marco Edited November 6 by Z320 Quote
RogerH Posted November 6 Report Posted November 6 Hi Marco there is quite a lot of items on Google and UTube Browning Roger Quote
john.r.davies Posted November 6 Report Posted November 6 (edited) Please will someone explain? "steel browning with vinegar" is encouraging the metal to rust! The brown is iron oxide, Fe2O3, rust! Whereas 'blueing' covers the metal with magnetite (Fe3O4) instead of rust, which gives the surface some resistance to rusting. John Edited November 6 by john.r.davies Quote
RobH Posted November 6 Report Posted November 6 Explained here: https://firearmshistory.blogspot.com/2010/08/metal-treatments-browning-and-bluing.html Quote
Lebro Posted November 6 Report Posted November 6 Selenium dioxide used fore gun blueing, used it many times, in the form of a paste. Bob Quote
john.r.davies Posted November 6 Report Posted November 6 6 hours ago, RobH said: Explained here: https://firearmshistory.blogspot.com/2010/08/metal-treatments-browning-and-bluing.html Thank you Rob!.. But quote frim that site: "The process of browning is the older process and has been known for centuries, even before firearms were invented. " I do think that we have made some technical progress since then! Please, Marco? Tell us why you want to make your nice clean steel rusty? John Quote
RobH Posted November 6 Report Posted November 6 26 minutes ago, john.r.davies said: I do think that we have made some technical progress since then! Indeed John - it's called plating, but that involves some nasty chemicals which are hard to get and is difficult to do at home without the right apparatus. 'Rust-and-oil' is easy and cheap . Quote
Z320 Posted November 6 Author Report Posted November 6 (edited) I want to make it black, but not painted. I started a test with vinigar 25%, reduced 12.5%, 6.0% and from my wifes kitchen 5%. After 4 hours, looks lovely gray, but needs some more time Edited November 7 by Z320 Quote
Z320 Posted November 7 Author Report Posted November 7 9 more hours the pipe in vinigar with 25% acid is black, but only outside, not inside and not on prepared or drilled surfaces…. Quote
RogerH Posted November 7 Report Posted November 7 Hi Marco you need to keep the solution moving through any holes etc. The ac tive ingredient will wear out quickly in any one position and so needs to be replaced regularly by stirring. Roger Quote
BlueTR3A-5EKT Posted November 7 Report Posted November 7 1 hour ago, Z320 said: 9 more hours the pipe in vinigar with 25% acid is black, but only outside, not inside and not on prepared or drilled surfaces…. How did you clean or degrease the component prior to the blacking process? Quote
Z320 Posted November 7 Author Report Posted November 7 39 minutes ago, BlueTR3A-5EKT said: How did you clean or degrease the component prior to the blacking process? test no 1 was without any treatment, I show photo later Quote
Charlie D Posted November 7 Report Posted November 7 Marko, Back in the 1960's I played around with anodising aluminium. I remember reading that first you put the item in some chemical which gave a grey finish and then you immersed it in a coloured dye, but I'm not sure what type of dye. That way you could make the finish whatever colour you wanted. Maybe black "Dylon" would work. Charlie Quote
Waldi Posted November 7 Report Posted November 7 Hi Marco, I used to work for some time at Widia, and we “blackened” the multi-toolbit holders for milling machines (used in automotive industry for example with a salt bath treatment, with also gave some protection against corrosion. This was on Cr-Mo-V steel but it would work on any ferritic steel. Google: “metal black with salt bath” Waldi Quote
Z320 Posted November 7 Author Report Posted November 7 (edited) Thanks Waldi, I will have a look for that way of browning. What I do is making the surface black, what is calles "brünieren" at Germany, this is what I translated with "browning", sorry for this irritation. This are the first results after 24 h in vinigar, please notice the spot on the pipe where oxygene was involved. A closer look shows, the pipe is getting grey inside, but very gentle... Next experiment is with some heat added, reminds my to my wife, she wants to go out this evening for the first Glühwein this year. No worry, the lid is slack, not locked. Ciao, Marco Edited November 7 by Z320 Quote
Z320 Posted November 8 Author Report Posted November 8 Heat changed everything the total surface is nicely black. But - sadly the black finish does not allow any touching A treatment with oil changes nothing, test finished Quote
