after only 4 years and 20,000 km my diff needs new planet gear shims again, its play makes me unhappy again.
Also a chat with the technical speaker of our club made me unhappy. He told me this what I have to expect.
My thought:
what other badge could be fitted on your TRs, apart from the Nissan R200 (too rare / expencive)?
On an older thread a BMW (E43?) diff is mentioned, but their ratio is only +/- 3:1, as other modern and powerful cars.
I had a closer look on a ZF diff from a SUV (my thought: bigger tires / higher ratio), which I was able to buy NOS for a VERY low price.
The ratios reach from about 3 up to about 4,6. A 3.7 is aviable - but no info about the serial numbers.
AP1GczO65oDT4Vz_926n1ffNbDt_5ZAwdwDDMunu
Sadly it has been sold to me prommissed being a 3.7, but it is 4.1 and has to go back.
to get the title of the topic more universal
There must have been something very wrong with your last diff rebuild if it needs another after only 20,000 km. There will always be play in a Triumph diff, it's just the clearances of the time, surely.
If you are set on fitting a modern diff, the Subaru unit is very compact & is probably available with many ratios.
Jerry
Hi Jerry,
I shimmed it new with my experienced friend Gerhard with original part.
My club mate Michael told me his experiense, 20,000 km with a new shimmed diff what can expected.
Thanks for the Subaru advice, sadly what I see on Ebay the are very long....
Nobody has another idea?
Ciao. Marco
Ford Sierra diff popular amongst kit cars in many configurations. I might even have one in the back of the shed. MX5 I think has a wide casting which may not be suitable.
Would a Quaife ATB resolve your issues?
Jerry
Edited by jerrytr5
Add ATB
Any useful suggestions here Marco?
on TR Experience forum. .
https://www.triumphexp.com/forum/tr6-tech-forum.2/differential-replacement-with-nissan-r200.1294609/
The Quaiffe ATB is a lovely item.  Just build it into your axle instead of the differential gear set and crown wheel carrier.    No fiddling about cutting the chassis or having special prop shaft and drive shafts produced.   I built one into a Girling TR3 axle in late 1980’s for my brother’s hill climb and sprint TR. It has done years of competition and road, and  is still running today.    Functions like a regular diff but better,  nothing seems to wear out.    Uses standard axle oil , no noises, doesn’t overheat like plate type diffs.      He initially ran a GKN plate type axle but chose to swap ratios, so I did the Quaiffe axle build.   I wish I’d done one for my car axle then, the units were very reasonably priced and various ratios were off the shelf for sensible money.
https://shop.quaife.co.uk/shop/atb-differentials/quaife-triumph-stag-tr2-tr3-tr3a-tr4a-tr5-tr6-atb-differential-qdf23k/
If you do buy one be sure to specify which axle it is to go in as the IRS unit does not need the axle shaft thrust button that the rigid axle must have
At one time Quaiffe were fitted to UK police force vehicles that were known for weak axles when subjected to high mileage and aggressive use.
https://www.quaife.co.uk/quaife-products/atb-limited-slip-differential/
Hi Peter,
don't wonder because I did not anser:
I was shock froozen about your simple "Quaife"-answer.
The R-200 diff is too rare, too expensive and too often I read "overhault" + the Goodparts set....not my way.
Next I will change the moon gear shims one more time and if they wear out again as fast as before the Quaife-diff is an option.
But why do these shims on the TR diff grind down so fast (if it is the case, not opended at the moment)?
What ever car I owned, not one had diff problems.
BTW I suppose "kangaroo petrol" on my TR4A has not only one reason,
for example the unfortunate carb linkage on my TR4A (cured), the worn shims are another one.
Waiting for parts and better temperature in my garage, Ciao, Marco
Albeit on a small chassis car, I too can recommend the Quaife ATB.
Tough?   At Le Mans, I broke a half shaft.  I didn't realise, because the car kept driving.     But on the way home, it went slower and slower, until I gave up and called Continental Rescue.    I discovered the half shaft when it got home weeks later.   Thinking that sending all the engine power down the other shaft, I dispatched  it to Quaife for renovation.   They sent it back, saying "No measurable wear".     I have used it for road and race ever since, and still no problems.
  • Z320 changed the title to another differential for my TR4A IRS wanted
That's the kind I use in my competition car Marco, it's silent in use, & takes standard transmission oil. I've not had any problems with it & I know some of the others use the same as me and they are not given an easy life 😁
Blackline is half the price of Quaife!
I can't get any informtion where it is produced,
so it can be from Asia (they can make pretty good stuff, if you pay for it) or is diffreent labled from Quaife anyway
I would expect it is almost certainly of Asian origin and I was dubious about them but was recommended by another competitor who uses one & he puts a lot more power through his axle than I do (over 180 bhp) without breaking it. So far so good..
On 11/30/2025 at 9:33 AM, Z320 said:
My thought:
Hi Marco,
I am aware that a BMW diff of suitable ratio available here in Australa has been modified to suit.... Could also have been LSD....Definitely an E series...If not E43, perhaps E30...Length, width etc comparable...Front mounts were a simple fix...Rear mount was a custom made one piece [easy for you]😁...Not like the "agricultural" looking Goodparts R200 conversion.
Hi Malcolm,
from onother thread I know you have fitted on, could you post a photo please?
Indeed via Google I found a list,
BMW E30, 325i (not Touring, not Cabriolet) had a 3.73 ratio,
another E30 had the 3.64 ratio
14 hours ago, Z320 said:
Hi Malcolm,
Hi Marco,
I have the factory diffs in my cars......I do have a pic somewhere of the BMW diff alongside the the factory TR one...Plus the custom made back plate...Will try to find it.
15 minutes ago, Malbaby said:
Hi Marco,
Malcolm, thank you very much, but don't spend too much time,
the way I will go is the Quaife diff, if new shims worn out again.
This is safer and faster than to fit a 40 yeras old BMW diff.
These are pics borrowed from a knowledgable fellow enthusiast...Not my work
Edited by Malbaby
I rebuilt my diff last year to deal with excessive play and found that even after tightening everything up to the minimum specified figures a still had play. I can only assume it is in the splines because CWP was <.004” (just) and the planetary gears were tight.
  • 2 months later...
When I changed the moon gear trust washers a few weeks ago
I was very disappointed about the play I noticed
of the splines of the outgoing shafts in the sun gears!
A swap with other sun gears was the same.
I got 3 options now
- don’t matter this
- fit a Quaife diff, if the spines fit tighter there?
- use a BMW diff, but not  from a E30
Last weekend I was on a classic car fair and was shocked how lovely BMW diffs  was spinning on a local workshops stand.
I told the workshop owner my worry, he: „yes, I also had this problem with some Porsche diffs“
Next Stammtisch a club mate will support me with a BMW diff to have a closer look….
Malcolm, I need ist only for a tiny TR4A!
It's from a E10 2002. The 2002 was a 2 liter engine, 120 hp, on the market from 1968 - 1972.
The front nose similar to the Nissan R200 diff, easy to fix, the rear cover with 2 forks, ration 3.64, others are aviable.
Thursday I get a diff from a 1602 (ratio 4.11) from a friend to have a closer look.
On the photo you see the same diff from a E21 (rear cover different)
AP1GczNphEvWAie6521v8VHP39jkZvdtxz5_KXcV
I'm enthusiastic, that old BMW diff spins GREAT, with only a minimum play, far better than my TR diff!
AP1GczPc0EvUz3Zi8F9Y8caX7Wol3v9HJNdl3yJH
Much more slim, about 10 mm longer, the two "bridges" on top could disturb.
I guess this could become a project.
  • 1 month later...
because of other issues this is a very slowly gowing project, but it grows
AP1GczO50Zuu6fjZI6hFXFCn9KDS6tiBHStlfKmX
On a wooden model I placed the diff with the adapter flage in the TR position.
AP1GczMukKBjgZxiwVJrDFtod17n8iYAFKf_CYjj
The bigger flange (d=105 mm) compared to the TR diff flange (d=92 mm) could cause a touch with the car body,
but the offset sidewards RH of the BMW is less and the offset down is more..... And the 2 fins on top of the BMW diff could touch the rear crossmember.
 The rear end looks lovely in this position......
AP1GczMYQT-38vULXAg3qWseKBuPB6TS47ePiLAK
But moving the diff back would ingrease the offset of the outgoing flanges, this is about 5 mm now (1 mm + M8/2).
AP1GczNXfwRc-1jWdaxhbQrxM308wWgLa1qafyAM
One option to get the fins lowered is to change from the Z- to a W-orientation of the propshaft / diff. Thoughts are welcome.
