Malbaby Posted March 29 Report Posted March 29 I would not be worried about cutting the fins down. Never contemplated turning a diff upside down. Quote
Z320 Posted March 30 Author Report Posted March 30 Hi Malcolm, thank you for your answer, cutting them down could be one solution - but not on my mate Thomas' diff 😂 Another one is lowering the diff in the frame - or cutting out the crossmember. What I remember: it has a straight, slightly rolled up edge. The Z- and W-orientation is not turing the diff upside down. On T4A-TR6 it is Z, at solid axles it is W (if I remember correctly). Ciao, Marco Quote
Lebro Posted March 30 Report Posted March 30 If a dif (or solid axle) were to be turned upside down you would end up with 1 forward gear, & 4 reverse gears ! Bob Quote
AlanG Posted March 30 Report Posted March 30 4 hours ago, Lebro said: If a dif (or solid axle) were to be turned upside down you would end up with 1 forward gear, & 4 reverse gears ! Bob Did this on a Standard 8 back in the 60's, trying to lower it. You live and learn. 🙃 Alan Quote
Z320 Posted March 30 Author Report Posted March 30 23 minutes ago, AlanG said: Did this on a Standard 8 back in the 60's, trying to lower it. You live and learn. 🙃 Alan Cool, fastest Standard 8 driving revers! Quote
Malbaby Posted March 30 Report Posted March 30 13 hours ago, Z320 said: Hi Malcolm, thank you for your answer, cutting them down could be one solution - but not on my mate Thomas' diff 😂 Another one is lowering the diff in the frame - or cutting out the crossmember. What I remember: it has a straight, slightly rolled up edge. The Z- and W-orientation is not turing the diff upside down. On T4A-TR6 it is Z, at solid axles it is W (if I remember correctly). Ciao, Marco I think we will have to have a word with your mate Thomas 😁. It's a BMW diff, overengineered to start with. 😁 Quote
Z320 Posted October 10 Author Report Posted October 10 Hi, since months Thomas' BMW diff is like this in my workshop, with a wooden model of a rear bracket. Today I hade some time, a rainy Saturday and the mood to check: does it basically fit without cutting anything out? My diff out and next to the BMW diff it looks OK In my 4A IRS the PU bushes need some modification To my surprise there is space enough to fit it, the 2 "fins" and nothing on the BMW diff needs a modification. Even the z-orientation is possible, this makes me very pleased and makes the calculation and construction much easier. Ciao, Marco On the Quote
Malcolm Baker Posted October 10 Report Posted October 10 (edited) 31 minutes ago, Z320 said: Hi, since months Thomas' BMW diff is like this in my workshop, with a wooden model of a rear bracket. Today I hade some time, a rainy Saturday and the mood to check: does it basically fit without cutting anything out? My diff out and next to the BMW diff it looks OK In my 4A IRS the PU bushes need some modification To my surprise there is space enough to fit it, the 2 "fins" and nothing on the BMW diff needs a modification. Even the z-orientation is possible, this makes me very pleased and makes the calculation and construction much easier. Ciao, Marco On the Hi Marco.....Is that an E34 diff......I will be interested on what you design and fabricate for the mounting plates. Edited October 10 by Malcolm Baker Quote
Z320 Posted October 17 Author Report Posted October 17 (edited) All went well! What made me some worry was the position of the outgoing shafts, they are a few [mm] more to the rear compared with the TR diff. Will this match with the original setup? Or is this too far behind and the universal joints too much angled? And what abouth the hight of the drive shafts to the frame? For this I made wooden adapters (later steel, of cause). And indeed, the shafts are slightly out of the center to the hubs, as it should be to keep the UJ a bit angled to keep the needles moving. But - that means the original diff is inline with the hubs?!?! I did not mind and not check this before..... Indeed, the original setup of all 4 UJ is straight --> not the way it should be in my opinion. Well, all OK with my setup, maybe better than original. I will continue the project and see where it guides me. BTW, a question of an idiot (me): the drive shafts are straight in both directions (up/down + front/rear, the rear of my car is slightly lowered). What is the "game changer" of CV shafts, if they are not angled in any direction? No critism, I just want t know. Ciao, Marco Edited October 17 by Z320 typo Quote
