I think I have just realised why the pipe ends in the engine bay do not have a swagged end fitting.
I would imagine the pipes are swagged before fitting into the plate. The swagging would not allow the pipe to fit into the plate.
Otherwise the hole to allow a fit would be too big for the pipe.   Very naughty
When I fitted a new heater hose connection to my 4A I turned a couple of brass rings and silver soldered them to the tubes. What I found with the stainless steel version the two bends were necked ( bends were very poor).
Graham
Hi Peter
Apart from the flaking paint, mine look pretty much the same as yours - and these were fine for at least the eight years of my ownership. But the same type of pipe plus clips do not work when I try to replace the old pipe. I do now have the circlips suggested by Roger and when I get time I will ty again with these.
Have a good weekend all.
Ernest
Hi Ernest
I’ve never in all my years had or known of a problem like this are you sure the new hose isn’t too short ? It must have some slack or the engine movement will pull it off
Aaahh Roger, you merely repeat what Marco theorised ( correctly I think) about 7 or 8 posts ago, I couldn’t think of another way to produce them in volume.
Mick Richards
Mick Richards
I wish I had read Marco's post. It would have saved a few dwindling grey cells.
TrChris
Yes I have tried different lengths of pipe and used new circlips, tightened up as far as they could go.
The length of metal that the rubber pipe is attached to is very shiny. I think I will try sanding it down, as well as using the clips recommended by Roger.
Have good weekend all - and hope that you can get out and about in your TRs!
Ernest
