Grahamgl Posted April 12 Report Posted April 12 Gentlemen, Following on from my earlier post about the exhaust system I purchased that will not fit, who would be the recommended supplier of a system that would fit please? Thanks Graham Quote
Malbaby Posted April 12 Report Posted April 12 Hi Graham, I would take the system that you have to a "Exhaust Shop" and have them modify and fit what you have. Quote
BlueTR3A-5EKT Posted April 12 Report Posted April 12 Are Bell Exhausts still in Swindon? Might be worth a question….or are they just a tyre shop now? Quote
Ian Vincent Posted April 13 Report Posted April 13 9 hours ago, Malbaby said: Hi Graham, I would take the system that you have to a "Exhaust Shop" and have them modify and fit what you have. Can you not modify your existing system yourself? Unless you are getting a 100% rebate from the supplier I would have thought it was worth a try. Rgds Ian PS I had to modify the exhaust to fit my car, a few judicious cuts with a hacksaw and carefully pull into the correct alignment before welding back up. Quote
Hamish Posted April 13 Report Posted April 13 I agree if the boxes will fit and it’s just the pipes that need fettling find and exhaust shop or a garage that sort the local lads rally cars they can turn their hand to anything Quote
RogerH Posted April 13 Report Posted April 13 53 minutes ago, Ian Vincent said: PS I had to modify the exhaust to fit my car, a few judicious cuts with a hacksaw and carefully pull into the correct alignment before welding back up. +1 Roger Quote
stuart Posted April 13 Report Posted April 13 2 hours ago, Ian Vincent said: Can you not modify your existing system yourself? Unless you are getting a 100% rebate from the supplier I would have thought it was worth a try. Rgds Ian PS I had to modify the exhaust to fit my car, a few judicious cuts with a hacksaw and carefully pull into the correct alignment before welding back up. I had to do the same on the one I pictured before for the Italia. Couple of cuts and a bend was all it took. Stuart. Quote
