23 minutes ago, Waldi said:
Very Good Kevin, that looks nice.
Waldi
Thanks Waldi and thanks for your help and advice.
p.s. Did you find out what happened to your PRV?
Edited by Kevo_6
14 minutes ago, TR NIALL said:
Kev if going for a Tap this is where I’d put it makes it handy for working on Pump,Pipes and Filter Changing.
Thanks Niall, yes that was my thought too but my concern was too many restrictions!
Use a full bore stainless steel ball valve, it's no more restrictive than a piece of pipe.  I use a 1/2" ss ball valve with adapter hose tails to suit the suction line.
Not yet Kev,
when (if ever) I understand the cause I will report back.
Regarding the fuel tap:
I do not have one, but considered it. I use a simple hose clamp, that works very well, so I have decided I will not install a tap. I’ve used it again in Malvern during my recent repairs, several times on and off, the hose still feels fine.
Waldi
Edited by Waldi
typo
As Niall has said a tap makes life very easy it’s always in the boot if needed.
There is a whole selection of taps available so you should be able to get one the same bore as your pipe so you won’t be introducing a restriction to your pipe work.
When fitting a tap there get one with fixing ears so it can be screwed to the rear of the spare wheel well.
  • 1 month later...
I’ve tested the car now on a few drives and I’m very happy with the results. So I thought I would compile a list of parts used and where I purchased them from, starting from the tank outlet onwards.
Larger Tank outlet for 10mm hose:- TR Trader £33 inc vat and delivery via eBay.
10mm Gates 4219BF R14 barricade low permeation fuel injection hose:- Racingcult 1metre £21.30 + vat & delivery.
SS 10mm barbed 90 degree large bend:- £6.52 from eBay robotron.2084 (I wanted to use this so I could keep the outlet feed as high as possible above the pump, keeping the filter above the pump)
Sytec SSF2012 fuel injection filter with 12mm push on hose tail to the outlet side:- Matt Lewis Racing £22.48 inc vat & delivery.
10mm push on M14 x 1.5 Inlet straight hose union  for the Sytec filter:- Merlin Motorsport £7.34 + vat & delivery.
Rubber lined steel pipe bracket 68-72mm with mounting stud removed to allow for  higher fixing of fuel filter, mounted through floor:- most plumbers merchants for about £1.00.
12mm Cohliine 2240 fuel injection hose:- Motorbling (75309) eBay 1 metre £28.95 inc vat & delivery.
Bosch 0580464126 electric fuel pump:- Opie Oils £82.50 inc vat & delivery.
Rubber lined steel pipe bracket 60-64mm:- most plumbers merchants for about £1.00 each, mounted through side floor with SS A2 M10 x 16mm x 4off button head allen screws (had to cut down a bit) with SS A4 marine grade M10 x 25mm dia 5off penny repair washers:- Kayfast Ltd £6.73 inc vat & delivery.
Fittings for outlet of fuel pump. 1 x Aluminium Banjo cap nut M12x1.5 £6.50, 2 x Goodridge 12mm copper sealing washers £1.02, M12 Banjo for 10mm hose. High pressure hose to pressure regulator T union 90 degree hose union 3/8 BSP female to 3/8 hose:- Merlin Motorsort.
10mm Gates 4219BF R14 barricade low permeation fuel injection hose:- Racingcult 1metre £19.93 + vat & delivery. **(ONLY 1 METRE NEEDED THIS INCLUDES TANK OUTLET TO FILTER)** Ferrules swaged on by Pirtek for £8.18 inc vat.
Diaphragm type modern pressure regulator:- TR Trader £195 inc vat & delivery via eBay.
6mm Gates 4219BF  R14 barricade low permeation fuel injection hose from PRV to tank:- ScimSharp eBay 3 foot £17.82 + vat & delivery.
Various rubber grommets and bungs.
This is just the way I’ve done it with the advise and help from members of this forum (which I appreciate very much) BUT I’m not saying this is the correct/better way or indeed the right way but it seems to work very well for me so far.
Don’t forget to upgrade your supply cable and use a relay and if you don’t have one a inertia fuel cut off switch.
I think I’ve about covered everything, all the best Kev.
FAE9A1D6-3EF6-4897-B186-8B7B855204C6.thumb.jpeg.04c9dbf56002d6c30da37735dcd1ab5e.jpegFF857EB8-2134-4FA3-A79F-997D068B7BA0.thumb.jpeg.d5ebd3346ad3b6fa2b95916620bcf3f0.jpegA2E6FBC4-4D8F-45D2-B8F0-583B828F6E98.thumb.jpeg.08b31281321c32e6c599109e4a7c8de9.jpeg
Edited by Kevo_6
7 minutes ago, Mike C said:
Thanks for the update. Looks good and the list of the parts and suppliers will save a lot of procurement legwork.
I have similar set up the only thing I found is that the non-return valve on the Bosch and sytec  pumps have only got a 4 mil hole in the  outlet of the non return valve which makes a pump overheat in hot weather to cure it I fitted a motorsport non return valve with a 6 mil hole using the heat gun the pump is normally around 30 to 35° with a motorsport non return valve on and the standard  non return valve the pump is running between 45 and 50° but my car runs best with the Pressure regulator valve set up 108 psi
Steve, I assume the NRV you are referring to, is in the outlet side of the pump before my banjo fittings. Do you have a part number and retailer for this larger outlet NRV please.
Cheers Kev.
Edited by Kevo_6
Yes that’s right if you  remove the non-return valve and have a look in the end it is only a 4 mil hole it should be 12.1.5 thread size but some Bosch pumps have a smaller diameter thread so check size before buying on mine I use #8 fittings but I think you can get a adapter to fit the banjo you have I took a picture of my purchase hopefully it’s come across ok
1 hour ago, TR NIALL said:
Well Done on the fitting Kev and that’s a nice list of parts for others to copy or add to.
Excellent work Kev, time enjoy your work now.
I found the copper rings on the outlet were difficult to seal when I had to replace them in August. It could be the copper replacement rings were harder, I do not know; they came from a local NAPA store. I had to use great force. This also compressed the 3rd copper ring and this started weeping (I had no proper special spanner for  the narrow ringnut).
This 3rd ring is a thicker ring, the std rings are not thick enough.
So I will order a couple of sets of “original” copper rings, and was glad I had a steel banjo cap nut. So you may want to consider carrying a spare nut and rings in the boot too.
Steve,
I always thought the Bosch pumps have an internal NRV and as it’s designed by Bosch it would not beed modification?
Waldi
1 hour ago, Waldi said:
Excellent work Kev, time enjoy your work.
Waldi
Hi Waldi, thanks for your help during this.
I had no problem with the copper sealing washers but did with one of the aluminium ones on the Sytec filter which I did not have central enough.
Great idea about carrying the spare bits as you suggest.
Cheers Kev. 👍🏻
Steve,
Waldi
Try annealing them, often even new copper gaskets have been work hardened during manufacture. I heat copper gaskets in a gas flame until they do cherry red then dunk them in water. They then compress and seal properly.
Thanks Mike and Roger,
I’m not convined they are annealed, they are bright and shiny, not oxidized / coloured so probably not.
But I know from own experience with 300-series SS that if the annealing is done in an inert gas atmosphere, there is virtually no change in colour.
If you look on the WWW, most of the rings which are specified as “annealed”are dull and sometimes spotted.
Most of the rings you can order are stamped from plate. The stamping process will cold-work harden them, so they should be annealed after forming.
Waldi
It's so easy to anneal a copper washer, it seems pointless to seek them out new!
If you haven't a gas torch - butane or otherwise - in your work shop, then the domestic gas ring will work well.    An electric stove?   No flame to go green, but it will still heat the washer.
Inductive hob?   Now you're just pushing me!
