dblenk Posted June 10 Report Posted June 10 here we go again anything on my car look right as it says i fitted a new universal rubber joint on the steering shaft (old one split) cap head counterbore go from bulhead to front normal hex bolts from front to bulhead all in tightened to 16 ftlb 21Nm and the caphead bolts with a allen key as much as i could Question the threads dont come all the way through the mating threaded section on the upper shaft about 2 threads short should i torque a bit more or leave it, it didnt notice if the bolts went all the way when stripping down, i could put longer bolts in (have to strip those out again capheads are great and the hole for the locking wire is well through thoughts ????? David Quote
dblenk Posted June 10 Author Report Posted June 10 just watched a video and both sets of bolts have locking wire mine doesnt i am starting to wonder someone has been messing forgot to say its a 76 USA LHD Quote
Steve-B Posted June 10 Report Posted June 10 (edited) When I replaced mine last month on our 73 TR6, I had to use 2 mated jubilee clips together to clamp & align in place though my bolts definitely had the safety wires. Any chance you’ve put the wrong bolts in as I almost dud that though I only had 2 bolts with safety wires. If not do you have a Dremel you could drill new holes as it’s a tiny hole to thread the locking wire through… Edited June 10 by Steve-B Quote
dblenk Posted June 11 Author Report Posted June 11 Steve thats the bolts i think should be in i think someone in USA has put shorter bolts in for the hex head ones lots of things on this car i have had to sort so no surprise the counterbore cap head bolts are fine and have the lock wire i checked moss catalogue and they sell the correct bolts so i will ask TR shop this morning to send me some yeah i saw your jubilee clip 25-35 and wondered i had a large one in the garage cheers David Quote
Steve-B Posted June 11 Report Posted June 11 David, fyi it took 2 clips mated to put enough pressure on the rubber to get everything aligning properly. Quote
RogerH Posted June 11 Report Posted June 11 12 hours ago, Steve-B said: When I replaced mine last month on our 73 TR6, I had to use 2 mated jubilee clips together to clamp & align in place though my bolts definitely had the safety wires. Any chance you’ve put the wrong bolts in as I almost dud that though I only had 2 bolts with safety wires. If not do you have a Dremel you could drill new holes as it’s a tiny hole to thread the locking wire through… Hi Steve, have you relieved the clamps such that they can actually grip on the splines. Easily done with a hacksaw - follow the dotted lines. Roger Quote
Z320 Posted June 11 Report Posted June 11 sorry me, IMO the jubilee trick is an issue of desperation Quote
Steve-B Posted June 11 Report Posted June 11 10 minutes ago, Z320 said: sorry me, IMO the jubilee trick is an issue of desperation I disagree or don’t understand your point. I learned of it from a neighbour TVR owner who did it to his TR6 years ago and speaking to others at Laon, I’m not alone in the challenge of fitting the new one where 40-50yr old one was. Quote
Z320 Posted June 11 Report Posted June 11 (edited) Easy job with a different tool Edited June 11 by Z320 Quote
dblenk Posted June 11 Author Report Posted June 11 all done one question i rotated the shaft 180 degree didnt realise until i had fitted that horrible turn signal clip does it affect the steering lock or anything all seems to turn ok not sure the lock comes in Anyone got a drg of the mechanism how it works just interested thanks David Quote
dblenk Posted June 11 Author Report Posted June 11 2 hours ago, Z320 said: sorry me, IMO the jubilee trick is an issue of desperation yep big jubilee clip squeeze it a bit and bolt went straight in, i remember in the eighties doing my 5 i had plumbers grips a lump of wood etc, i noticed the trick on here somewhere David Quote
Dale Moore Posted June 11 Report Posted June 11 Reminds me of the rotoflex couplings on the imp . AFAIR the competition ones came with a steel band wrapped around. Woe betide you if it was removed before you had the bolts in. Dale Quote
