Ken F Posted June 14 Report Posted June 14 Hi, AI and Google is messing with my head. which way to turn the nylon retainer nut on a Lucas injector to increase pop pressure? I stripped and cleaned an injector which was only 46 psi. When I put it back together it was popping at 50 psi, as I set the others to 52 psi I tried to increase it. I turned the nut half a turn and it went to 49 so I looked at what AI had said ….. tighten to increase pressure. I did another AI search and it said undo to slacken the spring to increase. I slackened by 3/4 turn and it went to 46 psi. surely tightening and squashing the spring increases the pop pressure. Another few hours wasted. I’ve turned it both ways and it only decreases. I know a few forum members have set their injector pressures, hopefully one or two will see my post. any help gratefully accepted. Don’t ask AI and pass that on please. 😂 Ken. Quote
k_raven_smith Posted June 14 Report Posted June 14 Clockwise to increase. The lucas manual gives opening pressure between 45 & 55psi. Quote
Ken F Posted June 14 Author Report Posted June 14 12 minutes ago, k_raven_smith said: Clockwise to increase. The lucas manual gives opening pressure between 45 & 55psi. Thanks, that’s what I did with the others, I don’t get why it reduced when I tried to get another 2 psi to match the others. spring related issue maybe. many thanks Ken Quote
