Ken F Posted June 15 Report Posted June 15 Hello, my TR6 is a 1970 and was never fitted with an inertia cut off switch. Originals are hard to find I’m told but I’d rather have a modern reliable one. which one should I buy? where should I buy it? Is there a technicality on fitting and wiring? Anybody who’s done it got any tips? I drove to the Dordogne in ‘91 with my little boys strapped in the seats I made and to the internationals in the 90s. Makes me shudder to think. petrol wasn’t so volatile back then I suppose. regards Ken. Quote
Trev Good Posted June 15 Report Posted June 15 MG owners club sell one of the best ones and at a price lower than most distributors. I've bought quite a few from them for my electric fuel pump cars. They sell to anyone, look on their website:- mgocspares.co.uk/product/e013/inertia-cut-off-kit Fitting is easy....it should be upright on the bulkhead and wired into the fuel pump live circuit. Quote
Ken F Posted June 15 Author Report Posted June 15 11 minutes ago, Trev Good said: MG owners club sell one of the best ones and at a price lower than most distributors. I've bought quite a few from them for my electric fuel pump cars. They sell to anyone, look on their website:- mgocspares.co.uk/product/e013/inertia-cut-off-kit Fitting is easy....it should be upright on the bulkhead and wired into the fuel pump live circuit. Thank you, should I fit one on my wife’s mgbgt when/if I get it back on the road? Ken Quote
Firefly Posted June 15 Report Posted June 15 MGOC are out of stock. Plenty on the bay, bought mine off there, half the price, its not something that wears out is it, and of a car that had it fitted in the factory. Quote
stuart Posted June 15 Report Posted June 15 9 minutes ago, Ken F said: Thank you, should I fit one on my wife’s mgbgt when/if I get it back on the road? Ken As it has an electric fuel pump then yes its a good safety feature. Stuart. Quote
john.r.davies Posted June 15 Report Posted June 15 The switch sold by the MGOC is used by many modern manufacturers, from Citroen to Jaguar to Maserati! Which has to be a recommendation. It may be worth noting that while the switch has three terminals, they are sold with a connector that uses only two. If the switch triggers, it disconnects the first two and connects the third, so that a warning light can inform you that it has been an impact that has caused your engine failure! Useful if, say, you run a kerb! Adding an extra wire to the connector should not be a difficult task. John Quote
Hamish Posted June 15 Report Posted June 15 I use the red top type like this https://ebay.io/m/YEQjAS you just need to satisfy yourself it suits Quote
StevecTR4 Posted June 15 Report Posted June 15 Interesting to hear where on the car, they are generally being fitted. I have installed one in the boot of a TR4A as a quick fix until I decide on the best long term option. Inserted the switch inline with the pump power supply. It came as a kit with indicator light from a main supplier Quote
Ken F Posted June 15 Author Report Posted June 15 27 minutes ago, StevecTR4 said: Interesting to hear where on the car, they are generally being fitted. I have installed one in the boot of a TR4A as a quick fix until I decide on the best long term option. Inserted the switch inline with the pump power supply. It came as a kit with indicator light from a main supplier That’s good to know, I thought why not put it on the boot between the pump (Lucas) wiring. Ken Quote
Tim T Posted June 15 Report Posted June 15 I bought a used LandRover one for the 5 for about £12 on eBay. Fitted it near the wiper motor where a 6 one would be. Tim Quote
Schnippel Posted June 16 Report Posted June 16 Hello, It's usually mandatory to operate electric fuel pumps only with a fuel pump relay. At least that's the case in Germany. This means the pump only runs when it receives a signal from the ignition. I install it this way on every TR with an electric pump. Best regards, Ralf Quote
RobH Posted June 16 Report Posted June 16 No relay mandatory here Ralf except perhaps on new cars, but all cars with an electric fuel pump have it ignition-switched. You wouldn't want it powered when the engine isn't running. It is a good idea to have a relay though, as it means less resistance in the fuel pump supply and saves the ignition switch from having to carry the pump motor current. Quote
Ken F Posted June 16 Author Report Posted June 16 3 hours ago, RobH said: No relay mandatory here Ralf except perhaps on new cars, but all cars with an electric fuel pump have it ignition-switched. You wouldn't want it powered when the engine isn't running. It is a good idea to have a relay though, as it means less resistance in the fuel pump supply and saves the ignition switch from having to carry the pump motor current. Thank you Ralf and Rob, I fitted a relay when I did the wiring mod with updated wire, the wires in the boot used to get hot. great improvement. I believe the mod is in technicalities or whatever it’s called. should a cut off switch be before the relay or after? Thanks Ken Quote
RobH Posted June 16 Report Posted June 16 45 minutes ago, Ken F said: should a cut off switch be before the relay or after? I don't think that really matters Ken - either way it cuts off the current completely. Which ever is most convenient for making the connections would seem sensible. As what could be viewed as a safety-critical component, I believe it should be in the main power feed to the pump and not just in the feed to the relay operating coil. Quote
