Malcolm Davis Posted June 16 Report Posted June 16 TR4A 1967 speedo stop working on inspection I found that the drive shaft from the angle drive to the overdrive had striped only on the angle drive side as it's not posable to buy just the drive shaft I had to replace the complete unit 4 time as it continued to do the same think & at £52.00 a time not cheap, 3 new cable which when fitted to the angle drive locks up striping the driver shaft. A type overdrive Quote
