Superpro always lubricated with the grease for the suspension etc
do you grease it for the steering rack i would think not as it would help it move
always fitted rubber so first time with poly
anyone with experience ??
thanks
David
Edited by dblenk
  • dblenk changed the title to TR6 steering rack poly mount install
Hi Dave
Why not fit solid mounts to eliminate movement?
Andy
the poly ones came in the set
are the solid ones fit and forget
i normally do std gear but was told the rubber is not as good these days it wasnt anything to do with performance stuff
i could be wrong but the solid ones transmit and the bumps etc into the steering ???? not sure
David
thanks
David
Simple rule (really pretty simple):
grease what you want to slide, don't grease what you want to fit tight.
I fitted PUs to keep it "slightly" elastic, indeed this is not really "elastic".
that does for me
david
David
I helped a friend  fit solid mounts to his TR6, all was fine until the test drive when the rack slid through the mounts and the car went kind of straight on!
Turned out the hole through the solid mounts was a fraction larger than the rack diameter. The mounts were from TRGB and the 2 halves are the same width, about 15mm, the ones on my car have a wider lower section +-40mm which locates against the  flange on the rack giving extra lateral support
We ground a millimetre from the face of the 2 halves of my friends mounts and they now grip
As for fit and forget, mine have been on for in excess of 20 years of daily use without any issues
George
Edited by harlequin
George
thanks George solid are out of stock on Moss and i have the polys not a big job so i will fit the poly and see and upgrade to solid maybe later as i was wanting to do them this week
where did you get yours ??
David
David
I'm sorry David it was so long ago I really can't remember. At the time I bought lots of parts from a place near Middlesbrough (Sedgefield ?) but they have gone out of business, the important thing is to get the type with the wide bottom section so that the rack cannot move sideways.
George
David
Stick with the Pollys they are the better choice.
George
Northern TR Centre that was a while ago handy for me when it was around, My Brother worked there briefly, i used to go down on a weekend to help out sometimes 40 years ago now
when fitting the new bushes can it be one side at a time or is it best to remove both so the rack is easy to move about
i was thinking if one side at a time no settings are changed makes sense to remove both though ??
i havent removed the track rod ends either
i am happy with the tracking etc got it done last year
Edited by dblenk
question
the superpro polys are 2mm larger than the standard rubber ones i have
hence a bit of a pain are the polys supposed to be larger ???
David
I'm surprised to hear they are bigger, maybe it just the old aftermarket parts quality problem again. I have a couple of sets of polybush amongst my spares, if no-one else can advise you David I will dig them out this afternoon and measure them.
I have always struggled with fitting the standard type arrangement which is why I have gone for the solid type
George
10 hours ago, dblenk said:
question
David
Bigger in which direction, please?
Your ? Let me suppose you did not try to fit it on the car?
Are your standard rubber ones new or old? 2 mm too small?
Your question causes multiple question to me.
Everything is new i will ask TR shop for the dims of a std one tomorrow to check
the old one is correct with the new rubber i have except the hole in the middle hence the movement
think i am going back to rubber then if they go in a few years i will just replace them
david
Edited by dblenk
all fitted and torqued up using rubber
i had 1/8" gap using mole grips either side 22NM 16lbft but looks they sprung a little so gap is 4mm ???
brackets are touching the chassis
rocked the steering wheel steering rack moves slightly maybe 1/2 a millimetre is this ok i have never looked on previous cars ??
thanks
David
Any movement of the complete rack sidewards
makes your steering wheel out of control being twisted slightly left and right, or not.
Are you sure the whole rack moves and not only the steering gesrbox on the steel tube (this was my problem, another thread)
Surely the rack is designed to move slightly otherwise what would be the point of mounting it in rubber.
Ralph
Ralph
Just checking first time i have fitted them
david
Ralph
It shouldnt move as the mounts are designed to hold the rack tube in both horizontal and vertical plane.
 looked again think its just a bit of flex int eh rubber mount no more than 1/2 millimetre definitely not 6mm like previous
Most of Standard Triumph's work changing to rack and pinion from the steering box was carried out when developing the Triumph Herald. When the car was introduced in 1959 it had solid mounts.
The motoring press reviewed the Herald in 1959 and complained about rough roads being felt through the steering. So from 1960-on the Herald was fitted with the rubber bushes. This resulted in all subsequent Triumph models fitted with rack and pinion getting the rubber bushes.
I changed to solid mounts on my Vitesse over 25 years ago and haven't noticed any vibrations problems through the steering on rough road surfaces.
No sense no feeling I guess!
Dave
