got a little squeal dont think there are any anti squeal shims fittedĀ
so i have ordered some
did i see something on here about a thin smear each side of the shim with copper slip ???
David
Yes David, a very thin smear of Coppaslip on both sides of the shim is the usual practice. Just keep it off the pad material and disc.
Super thanks
I bought the 3m sticky pads from BigRed, cut them to size, also put some copperslip on the pins that go thru the pads as well
