Looking for advice, the clutch is working but is no longer smooth, it’s hard to hold the bitting point without a shudder!
suggestions as to the cause please
thanks
Gordon
Edited by TR5 Fuel Lines
Title was incorrect
Check that the correct dowel bolts have been used where the gearbox is bolted to the engine, they are at twenty to two (clock face) when viewed from behind.
Hi Gordon,
        How old is the clutch/how many miles?, ..... if it's gone from smooth operation to shuddering with no removal/replacement of the gearbox then it could be oil contamination of the clutch linings or simply them worn down to the rivets, .... time to pull the 'box and have a look.
Cheers Rob
