Grahamgl Posted July 6 Report Posted July 6 Gentlemen, I have fitted Wosp starter motor to my rolling chassis and I want to fit the correct starter to solenoid cable. What amperage should the cable be please? I presume the same type of cable should go from the solenoid to the battery. The car will be negative earth. Thanks Graham Quote
RobH Posted July 6 Report Posted July 6 I take it this is a follow-on from your thread last year Graham? The heavy cable for the main starter current needs to be as big as is reasonable in order to minimise voltage drop. 35mm^2 (240A rated) would be more than adequate. Quote
BlueTR3A-5EKT Posted July 7 Report Posted July 7 (edited) Part Number 131114 Solenoid to starter cable TR2-4A Works fine on my car with Wosp starter. Maker. https://www.autosparks.co.uk/catalogsearch/result/?q=131114 Moss Page https://www.moss-europe.co.uk/en-gb/battery-tr2-4a-1953-67-tr24--16--02--01 Edited July 7 by BlueTR3A-5EKT Quote
