keith w Posted July 9 Report Posted July 9 Greetings all. It's been a while since I posted about my Grinnall restoration. It took me 17 years from arrival of the project car (eBay basket case) to the first tentative outings in 2024. Recently I've been tidying up the vacuum piping and tuning the Edelbrock 1404 which is where I'm after some advice. Today probably isn't the best day for tuning given that it's me getting cooked under the bonnet but hey=ho. I've jetted and rodded the carb to stock settings and the car starts from cold and runs pretty well, but after a quick warming up run, I adjusted the idle screws as per owner's manual and tuning guides and the idle speed increased significantly to near 1500 rpm. This is adjusting to maximum vacuum on a gauge connected to the non-timed carb port. I don't have any more adjustment on the idle speed screw, it's fully backed out and the choke screw is disengaged. Does anyone have similar experience and can they point me in the right direction please? BTW, a quick test drive after tweaking the idle screws showed the car drives pretty well with a little bit of exhaust popping on overrun. It's a bit exciting with the 1500 rpm minimum though. Quote
BlueTR3A-5EKT Posted July 9 Report Posted July 9 (edited) I suppose you have watched this video. It says to adjust the throttle lever stop and fine tune mixture tick over with the two screwed adjusters. Something about 400 rpm being max the mixture idle screws will correct. Edited July 9 by BlueTR3A-5EKT Quote
keith w Posted July 10 Author Report Posted July 10 (edited) Yes thanks Peter I have. I'm beginning to think the stock calibration of jets and needles is too much for the 3500. I've emailed Edelbrock as well, they usually come back in a day or so, but I'll try much smaller jets today before it gets too hot out there. 11.35 - Smaller jets corresponding to setup 11 on the Edelbrock chart - rougher performance but still idling at 1500. 17.25 - May have sussed this. I think the idle mixture screws were way too far out. Screwing them all the way in and coming two turns out, it seems to run smoother and slower. A US YouTuber reckons to lean them out from there so I'll vacuum gauge it again tomorrow when the noise is less obtrusive. Tuesday 11-00 am No that's not it. Starts easier and achieves smooth idle quickly but still around 1500. Pretty undriveable though so I'll revert to previous jet and needle settings and I'll take the carb off for a visual check on the secondaries. Check this guy out. Does anyone remember the movie Two Lane Blacktop? Edited July 14 by keith w Added information Quote
keith w Posted July 21 Author Report Posted July 21 Moving on a little with this. Yes indeed there was a vacuum leak. I could hear it when I got close enough to the brake servo. I had asked various suppliers and on FB pages if there was a gasket between the master cylinder and the servo but no sensible answers were forthcoming. There is on the standard setup in the form of a domed rubber dustcap but as this is a non-standard setup using a Stag or Sherpa servo, I'm not sure which, and a larger master cylinder (Lockheed 4224-762) no one could tell me for sure. When I split the two again it was pretty obvious there needed to be something there. I've put in a large rubber O-ring which seems to have done the job though I suspect a rubber gasket matching the face of the MC would be correct. If I can find one maybe I'll fit both. Anyway, idle speed is reduced to about 1000 rpm but start-up and idle is much better and it's drivable. So onwards with some tuning. Quote
