I've just received a set of Bosch WR78 Super 4 plugs, why? - well some people rate them and I'm curious.
Previously I've used NGK BP6ES (single electrode), NGK BUR6ET (triple electrode) and BOSCH W7DTC (triple electrode).
Although I have a set of single electrode Bosch resistor plugs, I've never used them as I learned there's losses when using resistor plugs, better to have maximum spark, though apparently suppressed plugs produce a longer lasting spark (though weaker at any given moment).
Before I fit the Bosch Super 4 plugs (yes resistor plugs), I lined up all the new spare plugs I have, Bosch, NGK and Champion.
The construction and materials of the Champion plug is definitely inferior, as if the silver coating is flaking off (notable on the outer electrode)! - the barrel ahead of the nut is also very different to the others, chunky. The central electrode has the largest diameter, the 2nd largest is the Bosch WR7DC (which is quite different to the WR8DC - and in the finishing of the ceramic end around the central electrode).
The Bosch triple has a notably long exposed central electrode, and which extends furthest into the cylinder of all the plugs... along with the NGK triple which has a very similar design, though with a slightly narrower central electrode...
Here's some close ups of the other plugs...
I also checked the resistence of the plugs,
Plugs without an internal resistor :
NGK BP6ES : 0.2 - 0.5 Ω
Bosch W7DTC : 0.3 Ω
Champion N9YC : 1 Ω
Plugs with an internal resistor :
Bosch WR78 (Super 4) : 5,860 Ω
Bosch WR7DC : 6,230 Ω
Bosch WR8DC : 4,780 Ω
___________________________
HT Leads (shortest and longest leads measured) :
Magnecor 7mm
7.5”     2,100 Ω
13”      3,800 Ω
PowerSpark 8mm
12.5”   1,600 Ω
21”       2,540 Ω
Lucas 800
8.5”     7,200 Ω
15.5”   11,600 Ω
No conclusions here, just thought you might like to see the above, and it might be of some use that I don't know of.
Edited by Jules TR6
Very interesting Jules, I use BP5ES in cylinders 5&6 and the BP6ES in the rest but I bought some Bosch WR78 plugs the end of last year. I’ve not tried them yet, I need to get my fuel system sorted first.
I’ll be interested to hear how you get on with them.
Kev.
How does one gap the multiple electrode type, or don't you?
Jerry
Jerry you don’t l have them in the 250 and a couple of guys use them in their 6s however they run carburettors and all seem to run smoothly , cannot comment on there use in injection cars
Jerry
You don't gap multi-ground plugs :
Bosch W7DTC                   0.031" (0.8mm)
NGK BUR6ET                  0.031" (0.8mm)
Bosch WR78 Super 4     0.035" (0.9mm)
I've found NGK BP6ES (single ground electrode), works best for my engine (a PI) and Flamethrower 3 ohm coil, at either 0.030" or 0.032", so the triple electrode (non-suppressed) plugs are within that. The Super 4 has a larger gap, and are suppressed. I'll let you know how the engine takes to them in due course.
Edited by Jules TR6
Hello All
            I have a mate that was running Bosch WR78 in his TR6 and they kept fouling
Changed to non resistor ones and been fine ever since?
My understanding is WR78 are for modern high voltage coils not the Standard Lucas or Sports type?
I run WR78 in my Spitfire but it has modern fuel injection and a Bosch type 4 outlet coil pack (The last set I changed had done 20,000miles with no problems)
But it does not run Very rich on start up like manual chokes!
Ok the verdict is in on the WR78 plugs (PI engine, Flamethrower 40,000 volt 3 ohm coil).
I'm not keen.
With any plugs (in my engine), often from idle, in neutral, flooring the throttle can cause the engine to 'choke' a little (warmed engine no choke), it gains then maybe too much fuel is injected then it drops back, all very rapidly in lower rpm range, a noticeable hesitation where the engine's rhythm is upset. Normally I don't floor the throttle in neutral from idle! - but is a test of the engine's overall willingness to perform. Usually one introduces the throttle quickly but not immediately at lower rev - then all is fine. Once past 2,000 rpm flooring the throttle in neutral causes zero issues. Anyway I mention this 'choking' but it's not a normal occurrence.
I'm noticing this phenomenon more with the WR78 plugs. I'm guessing a weak spark, can't properly ignite the extra fuel injected - at low rpm, in neutral, when the throttle is opened quickly. Past this the rpm the needle doesn't seem to rise quite as quickly or immediately, there's more lag as well. Many people wouldn't notice this, it's not so bad, though I do pick it up.
On the road a similar story, maybe less high performance, less willingness to respond quickly, and reduced acceleration. Again many people might not notice this, the difference is not dramatic.
Possibly as with the triple electrode plugs, the 4's are a little smoother / more even in the cylinders firing than single electrode plugs.
From this current test, the WR78 plugs are coming out once the engine has cooled down. They are the wrong plugs from my TR6, and I would suggest, for any TR6 (especially a PI with its pre richness, and post fuel injection response, though I just don't see them as the 'right fit' for any TR6). The main issue probably is the resistor, it's not helping. They are the first resistor plugs I've used, and the difference is noticeable (to me as the driver). That them having 4 ground electrodes, and 0.035" gaps may also not be helping (I do realise that the spark is not divided into 4 paths, and so 1/4 of the strength across each electrode jump, the spark usually jumps to the easiest / cleanest electrode - just one).
I have found the NGK and Bosch triples (non-suppressed) to be good, though the NGK single electrode (non-suppressed) also to be good.
Possibly the Bosch triples stayed clearer than the NGK triples.
So after these WR78's come out (£36 into the bin), I'll go back to standard NGK BP6ES gapped to 0.030"... then report back again.
Which is what most of us run and what I usually fit at service intervals.
Used with non suppressed leads? Double resistance would not help if the leads were also suppressed.
In the world of old motorcycles it is easy as NGK do both suppressed and non suppressed spark plug caps so the resistance could be at the plug or the cap (not both) depending on the spark plug used (resistance or non resistance)
I will be trying Denso plugs.
These are the HT leads I'm using, shortest and longest leads measured :
Magnecor 7mm
7.5”     2,100 Ω
13”      3,800 Ω
so yes, they are suppressed, to a low-medium amount.
Jules, I've tried a variety NGK plugs and have found the best for my 6 are the iridium ones, BPR6EIX. These are resistor ones but I've never noticed any difference with non resistor equivalents.
Cheers Darren
On 17.7.2026 at 17:12, Jules TR6 said:
Okay, das Urteil zu den WR78-Zündkerzen ist gefallen  (PI-Motor, Flamethrower 40.000 Volt 3 Ohm Zündspule).
Ich bin nicht begeistert.
Bei allen Zündkerzen (in meinem Motor) kann es vorkommen, dass der Motor beim Vollgasgeben im Leerlauf kurzzeitig „abwürgt“ (bei warmem Motor tritt dieses Problem nicht auf). Er beschleunigt dann kurz, möglicherweise wird zu viel Kraftstoff eingespritzt, und fällt anschließend wieder ab. Das alles geschieht sehr schnell im unteren Drehzahlbereich und führt zu einem spürbaren Ruckeln, wodurch der Motorlauf gestört wird. Normalerweise gebe ich im Leerlauf im Leerlauf nicht Vollgas! – Es ist aber ein Test für die allgemeine Leistungsfähigkeit des Motors. Üblicherweise gibt man bei niedriger Drehzahl schnell, aber nicht abrupt Gas – dann läuft alles einwandfrei. Ab 2000 U/min verursacht Vollgasgeben im Leerlauf keinerlei Probleme mehr. Ich erwähne dieses „Abwürgen“, aber es tritt nicht regelmäßig auf.
Mir fällt dieses Phänomen vermehrt bei den WR78-Zündkerzen auf. Ich vermute, der Zündfunke ist zu schwach und kann das zusätzlich eingespritzte Benzin nicht richtig entzünden – vor allem bei niedriger Drehzahl, im Leerlauf und wenn ich schnell Gas gebe. Darüber hinaus steigt die Drehzahlanzeige nicht mehr so schnell und verzögerungsfrei an. Vielen würde das nicht auffallen, es ist nicht so schlimm, mir aber schon.
Im Straßenverkehr zeigt sich ein ähnliches Bild: möglicherweise etwas geringere Leistung, langsamere Reaktionsfreudigkeit und reduzierte Beschleunigung. Auch hier werden viele dies wahrscheinlich nicht bemerken, der Unterschied ist nicht dramatisch.
Möglicherweise ist es ähnlich wie bei den Dreifach-Elektrodenzündkerzen, dass die Vierfach-Elektrodenzündkerzen eine etwas ruhigere/gleichmäßigere Zündung in den Zylindern aufweisen als Einzel-Elektrodenzündkerzen.
Bei diesem Test stellte sich heraus, dass die WR78-Zündkerzen nach dem Abkühlen des Motors herausfallen. Sie sind die falschen Zündkerzen für meinen TR6, und ich würde sie für keinen TR6 empfehlen (insbesondere nicht für einen PI mit seiner Vorfettung und dem Ansprechverhalten nach der Einspritzung, obwohl ich sie generell nicht für die optimale Lösung halte). Das Hauptproblem ist wahrscheinlich der Widerstand; er trägt nicht zur Verbesserung bei. Es sind die ersten Zündkerzen mit Widerstand, die ich verwendet habe, und der Unterschied ist deutlich spürbar (für mich als Fahrer). Dass sie vier Masseelektroden und einen Elektrodenabstand von 0,89 mm haben, könnte ebenfalls problematisch sein (mir ist bewusst, dass der Funke nicht auf vier Pfade aufgeteilt ist und daher nicht mit einem Viertel der Stärke auf jede Elektrode überspringt; der Funke springt normalerweise zur leichtesten/saubersten Elektrode über – also nur zu einer).
Ich habe festgestellt, dass die Dreifachelektroden von NGK und Bosch (ohne Schalldämpfer) gut sind, wobei die Einzelelektrode von NGK (ohne Schalldämpfer) ebenfalls gut ist.
Möglicherweise blieben die Bosch-Dreifachvergaser sauberer als die NGK-Dreifachvergaser.
Nachdem diese WR78-Zündkerzen also raus sind (36 Pfund im Müll), werde ich wieder auf die Standard-NGK BP6ES mit einem Elektrodenabstand von 0,030" umsteigen... und dann wieder berichten.
Hello,
the worst mistake you can make is using resistor cables!!! I've installed the Bosch WR 78 in many TRs with 6 cylinders. They absolutely require the correct electrical infrastructure! Ignition cables should only be stranded copper, and distributor and spark plug connectors should have a resistance of 1 kOhm!!!! I'd only believe a 40,000-volt ignition coil if I saw it on an engine tester. The distributor rotor wouldn't last long either. It's not designed for that. I'd throw the ignition cables and ignition coil in the trash, but not the Bosch WR 78. That's my experience.
Best regards, Ralf
You are quite correct for points-based systems Ralph but unfortunately many of the electronic ignition systems people fit do not work with plain copper leads, as there is then too much high-frequency noise for them to function properly.
A coil may well be capable of more than 40kV under ideal conditions but it shouldn't reach that in normal use.  The voltage rises until the spark-plug gap breaks down, which typically in a standard 'old-fashioned' engine happens somewhere between 10 and 25kV depending on the plug gap and the pressure in the cylinder - full throttle demands more voltage than idle.  The voltage cannot rise any further than that so higher maximum capability of the coil is rather immaterial.
11 hours ago, Schnippel said:
Hello,
Best regards, Ralf
...I'm sure that would work, though if ever you might want to swap to electronic ignition, suppressed HT cables would need to used (so that's another set of cables and plugs, and testing etc).
The WR78's have a resistance of 5.9 kΩ, if you add on your quoted copper + connector resistance of 1 kΩ, that 6.9 kΩ.
I'm running suppressed Magnecor cables + non-resistive plugs that come in between, 2.1 kΩ and 3.8 kΩ, and it can all be used with an EI drop-in dizzy module if wanted.
As to the coil, many coils now are trash - unfortunately, I know, I've been through them! Lucas used to be superb, not now. The Pertronix Flamethrower, is probably one of the most well made, reliable and resilient coils available now, Martin of the Distributor Doctor wouldn't use them or stock them if they were otherwise!
Edited by Jules TR6
Hi!
My TR4A came with W8AC, which definitly have a too short electrode, and 10 kOhm plugs.
Meanwhile I used WR78G (short for 4 cylinders) with pleasure, also W6BC, at the moment W8BC.
Copper cables but also carbon cables (which failed and caused me a lot of troubles),
0 Ohm and 5 kOhm plugs.
At the moment I drive with copper / W8BC / 5 KOhm / an old blue Bosch coil and will refit WR78G.
It my be my lack of sensibility, but guess what…..
W / WR
4 hours ago, Jules TR6 said:
...Ich bin mir sicher, dass das funktionieren würde, aber falls Sie jemals auf eine elektronische Zündung umrüsten möchten, müssten entstörte Hochspannungskabel verwendet werden (was also einen weiteren Satz Kabel und Stecker sowie Tests usw. bedeutet).
Die WR78-Röhren haben einen Widerstand von 5,9 kΩ. Addiert man den von Ihnen angegebenen Widerstand von Kupfer und Stecker von 1 kΩ hinzu, ergibt das 6,9 kΩ.
Ich verwende entstörte Magnecor-Kabel + nicht-resistive Stecker, die dazwischen liegen, 2,1 kΩ und 3,8 kΩ, und das Ganze kann bei Bedarf mit einem EI-Drop-in-Verteilermodul verwendet werden.
Hello,
I only install Luminition ignition systems. Contacts are immediately replaced! We want reliability! And with the comprehensive Trijekt engine management system, electromagnetic compatibility must also be guaranteed. I grew up with Bosch during my apprenticeship and still have many training manuals that deal with this topic. And that's exactly what I apply to the TR machines. Back to the Bosch WR 78: it came onto the market around 1998, and I've been installing it in TRs ever since! It has over 60,000 km on the clock! The ohmic resistance in the glass melt reduces erosion and thus lowers electrode wear. Self-cleaning is achieved through two different spark gaps. The electrode gap of 0.9 mm cannot be adjusted!! The Bosch Super 4 covers at least two temperature ranges. These are a few excerpts from a Bosch document. Having a very good ignition system in a TR is no accident. Bosch will definitely help you move forward with this.
Best regards, Ralf
Just to report on what's working well...
Put the NGK BP6ES in, gapped 0.030" which seems to have always been the optimum (the coil can more than enough cope), low rpm pick-up not exceptional but ok (as I've come to expect of a classic car), once above 2000rpm very responsive. On the whole better than the WR78 (though as we know I'm using somewhat suppressed (3kohm) HT cables, so suppressed plugs are out).
Then went back to the Bosch W7DTC, so much better. I have no bias or allegiance, just reporting, the engine so likes these plugs. Even starting, only needs a few seconds of the fuel pump then starts first time.  The Bosch W7DTC is unusual as seen at the top of this post, they extend further into the cylinder than any of the other plugs, whether this is good or bad or indifferent, I don't know, but maybe this and the more exposed spark of the tri-electrode arrangement seems to be what the engine is liking - in all its primitiveness of the injection squirt etc.
Reading other reports of plugs on this and other forums, the NGK BP6ES is always mentioned, though the Bosch W7DTC does get a lot of positive feedback, rightly so I'd say.
Edited by Jules TR6
9 hours ago, michaeldavis39 said:
Please note you mean Bosch W7DTC not W7TC - as this doesnt exist.
…many thanks for spotting that! - a simple typo on my part - that persisted. I’ve edited the posts above to avoid misinformation. The labelled photos are still incorrect, I may also update them when I have the time.
Another vote for the Bosch w7dtc from me, as well as strong performance they seem to last forever!
my ‘74 PI car ( but 2.7l and somewhat modified) runs 123Ignition distributor , beru coil, magnecor 8mm leads and the w7dtc plugs
checking my records I bought the plugs in 2019 and they’re still going strong!
steve
Just a question:
My TR PI (CR) is having some ignition issues right now. It misfires at high RPMs and runs a bit rough starting from idle, which means that at the lowest RPMs, early shifting isn’t as smooth anymore. And it’s also annoying to know that the system isn’t running 100% flawlessly.
Here’s what I have installed:
Bosch blue (3 ohms) ignition coil
Carbon ignition wires (now with 6–8 kOhm resistance)
Bosch WR78
Pertronix Ignitor2 / Accuspark
After doing some research, I’ve come to the conclusion that as the ignition coil and ignition wires have aged, their resistance has simply become too high for the WR78. Now that I’ve read up on the subject, I realize that simply replacing the spark plugs would have been the easiest way to confirm or rule out this theory.
I decided to replace the ignition coil (this time the Flame-thrower) and the ignition harness, including the cap. This time, though, I’m using copper wires and connectors with a resistance of only 1 kiloohm of resistance. Now I'm reading here that copper wires aren't good for Pertronix and similar brands??
Many thanks
Cas
Hi Cas,
 the earlier posts suggested that having resistance in the HT lead AND resistance in the plug (WR78) may be your problem (maybe!)
as you are adding two high resistance. You only need the one.
Yes, Roger, now I got it. I am wondering if the Carbon ignition wires had the restinance when they we're new.
But, what is about my brandnew extra thick copper wires, will the work with the Pertronix or strike?
The Pertronix installation instructions specifically state " DO NOT USE SOLID CORE SPARK PLUG WIRE. Use suppression or carbon type spark plug wires."
https://static.summitracing.com/global/images/instructions/pnx-1181ls.pdf
