For the sake of completeness, it should be mentioned that Ralph usually subjects the TR engines to his comprehensive overhaul, so the electric ignition is just the smallest detail.
My goal has always been to optimize—rather than change—the character and the basic technology of Triumph as much as possible. Because I like the original concept. Otherwise, I might as well just buy a modern sports car. That’s why no EFI, no 123, no Mazda transmission, etc., etc.
The reason I switched to standard shock absorbers back then was the lack of decent, redesigned lever-type shock absorbers at the time. The same was true for the ignition.
So now, with the newly ordered components, I’m going to give it another try to get it back to how it used to be with the Petronix system. And if that doesn’t work, I’ll go back to classic contacts (though possibly with the help of a transistor component—experimenting is fun, after all).
And now, please, back to the spark plugs. I apologize for that little digression into my personal issues.
Many thanks
Cas
  • 2 months later...
On 7/26/2026 at 4:55 PM, Jules TR6 said:
I did, BP6ET seemed to soot up fairly quickly. W7DTC stays cleaner.
The thing is, I and probably everyone else are often making 'improvements', so while I make observations (and copious notes about those observations along the way), it's tricky to point any fingers at one item.
The plugs are cheap, and easy to swap after having tried them for a 100 miles or so, everyone's 50-60 year old engine with mods will be different, different plugs etc may suit one engine more than another.
My default is always to keep reverting to the default (points and BP6ES) if there's any issues I can't solve. Then make one change in a direction if desired / required.
Hi Jules, do you know if there is a resistor version of the W7DTC plug? I gave them a try and although they are good they cause interference with my head unit.
Cheers Darren
Well you could try wearing a tin-foil hat.....:o
Seriously though, you really should only need one means of ignition suppression Darren.   Either carbon HT leads, resistor plugs or resistor plug caps.  If you need more than one of those  it is probably because the 'head unit' is picking up interference via its power connection which  an in-line filter might fix.
Too much suppression-resistance in the HT just reduces spark current.
I've got carbon HT leads and have put in a filter on the power supply but still had the issue. Whilst playing from a USB the volume drops intermittently. I've gone back to resistor plugs and the problem has gone away - very peculiar!
Latest updates from my end:
I installed new ignition wires (Mr. Retro Leads), new points, finger, condenser and a new distributor cap from Distributor Doc. And the Bosch W7DTC.
But the real game-changer was discovering the mistake the repair shop made in 2017: the distributor was set too high due to a faulty clamp, causing the distributor cam to skip. No wonder it hasn’t run reliably or consistently well since then. Today I also installed a transistor ignition system, so the Points now serves only as a trigger, without combustion/burnup (what is the right word for that the point has no Erosion?)  It’s like driving a brand-new car!
…any photos of this faulty / too thick clamp? Are you sure the cam was skipping? - as wouldn’t this cause very serious issues of sparks occurring on the wrong cylinder and the dizzy rattling around, the cam disintegrating! etc, probably more like the clamp wasn’t clamping and so timing was going out by a long shot.
I did have an issue once, early on in ownership, after adjusting the dizzy timing so often, the clamp had encouraged the dizzy up, it still kinda clamped but not tight. Once totally slackening off the clamp and then ensuring the dizzy was fully down and ‘home’ I now ensure this is the case every time I adjust the dizzy timing - which is not that often.
Edited by Jules TR6
I've heard of something like this, but it wasn't the clamp; it was the "clamper" who put the clamp around the distributor too low on the distributor shaft,Distributorpinchbolt.jpg.77f73bccb0ae18629ab61fa18b7117a6.jpg below the rim instead of above it.
Edited by poolboy
picture added
Yes, we only noticed it because we wanted to test the springs on the distributor, and in doing so, we realized that the finger traveled much farther than would normally be expected. And with a little more force, it even went past the final stop.
The clamp looked as if someone had manually adjusted it. I took videos of both, but deleted the most telling ones—only the first one remains, where I was still applying just a little force.
On 7/26/2026 at 11:59 AM, Hamish said:
Just buy parts from DD
+1.
I think I know what Martin would say about your dizzy……….it’s knackered with that much play. I was with him the other day with a DM2 for my Tr4a, it had way less play and was described as above😂.
For me I would get it rebuilt by Distributor Doctor and then at least out know that the dizzy is top notch.
Good luck
As you can see, new parts have already been ordered from the distributor Doc and installed (points, condenser, finger, contact terminal 1 on the ignition coil). And ever since the correct clamp was installed and the distributor reached its proper depth, everything has been running perfectly. There’s also no more play at all—just the correct spring tension. Everything’s fine for more than 300 miles.
Good luck
Why a DM2? Should be a 25D4 surely for a 4A?
Well that’s what I thought too Stuart but apparently it could be a late style DM2 , which is what was on it……I’m not going to argue with Martin, he’s much more knowledgable (and bigger) than me 😂
Every volkswagen 1980>90 had copper ignition leads (with resistor ends).
Also all used Bosch Hall electronic ignition.
The 123 ign was independently tested in the usa. No interfereance could be found on the machine with copper.
Carbon leads went out with flares/ mk2 cortinas and last about a year. Then people made up copper replacements and the cortina started when damp.
On 7/24/2026 at 8:37 AM, Steves_TR6 said:
Another vote for the Bosch w7dtc from me, as well as strong performance they seem to last forever!
my ‘74 PI car ( but 2.7l and somewhat modified) runs 123Ignition distributor , beru coil, magnecor 8mm leads and the w7dtc plugs
checking my records I bought the plugs in 2019 and they’re still going strong!
steve
Update !
today the tr6 persistently ran on 5 cylinders, it’s never done this before.
i removed each plug lead in turn and isolated the fault to cylinder 6, the pi pipe had a strong pulse so i suspected the plug.
plug 6 was black and a little oily, other five were dry and dark brown
a new set of w7dtc plugs and full service is resumed, and the car is pulling really strongly so i think the plugs were overdue a change.
so seven years is the life of the Bosch triple electrode w7dtc plugs !
steve
I tend to carry a spare set in my '73 TR6 and have found great prices/service from Sparkplugs.co.uk so I just went onto there to check fitment.
According to https://www.sparkplugs.co.uk/bosch-spark-plug-0-241-235-756-w7dtc-0241235756-4  they do not fit PI TR6s, what am I missing?
Hi Steve
not sure why they say these don’t fit, I’ve had them in since 2019 with great results
they’re of course not original equipment as they weren’t invented in 1973/4 😃
steve
