Junior Posted July 17 Report Posted July 17 Hi Folks, Am looking for help and advice on my Tr7 constantly misfiring through the carburetor, usually front then cutting out almost immediately then not starting again for a while. Also needs to have a rich mixture to start or it won't start atoll. Thank you for your time on this matter. Quote
Ecosse Posted July 17 Report Posted July 17 Try checking the rubber / metal mounting block between the carbs and manifolds for splits / leaks. A shot of WD40 around the mounting block should show any issues. Cliff Quote
Junior Posted July 17 Author Report Posted July 17 Hi Cliff Yes I've change all the mounts and gaskets on the carbs and the intake manifold changed the jets and needles and also the condenser and points and rotor aswell as the coil unfortunately it never helped. I'm wondering if it's because I've not used lead additive Quote
jerrytr5 Posted July 19 Report Posted July 19 On 7/17/2026 at 12:54 PM, Junior said: constantly misfiring through the carburetor I'm not entirely sure what you mean by that, & you seem to have made a number of changes, so perhaps it is time to go back to basics. Check valve clearances, compression & static timing. Then move on to sparks, then fuelling. Good luck. Jerry Quote
