Posted by mods, on behalf of a new member, John.
I am new to the TR4 and classic car world with experience in classic bikes. My new 1961 TR4 has an electrics issue. No front or rear lights, no Indictators. The previous owner rewired it
I have traced wires done limited checks with a multi meter. I suspect I’m looking for a single broken or disconnected cable
Any suggestions on where to start. It’s a 4 fuse Lucas board. I can get power both sides of the fuse on the top 3 fuses. Nothing on the bottom. An expanded wiring diagram came with the car ( same one as the Haynes manual) but I can’t make head nor tail if it
Any suggestions would be appreciated
Stewart
Edited by Lebro
I assume that the above should say the previous owner rewired it, if so it`s any ones guess as to what is wrong. For a start according to my info the TR4 only had 2 fuses. The PO has fitted a 4 fuse box which is a common upgrade, and may only have needed 1 extra fuse so has not connected the bottom fuse. Are there any wires coming and going from it.  A picture of the fuse box would help. Otherwise all you can do is start tracing wires.
There should be a brown and blue wire from the control box that goes to the ignition switch, on that same terminal on the switch there should be a second brown and blue that supplies power to the lighting switch and hence to the headlights via the dipswitch. There is also a red and green coming from the lighting switch which supplies power to one of the fuses and from that to instrument lighting and sidelights.
The second fuse on a standard fusebox is also supplied from the ignition switch via a light green wire and that controls the brake lights, heater blower, water temp and fuel gauge, indicators and wiper motor.
The fact that you have no headlights, sidelights, or indicators means that both standard fused circuits are compromised, yet you seem to have power to at least 3 fuses so I`m stumped. I`d start by checking the connections on the back of the ignition switch and see what is going on there.
I have just worked all this out from looking at the Haynes wiring diagram you refer to.
As I said before, your wiring does not sound standard, so any mods done by the previous owner could invalidate the factory wiring diagram and the only way is to work your way through wire by wire .
Incidentaly, does it still have a Dynamo or has it been converted to alternator, because that would require adapting or re-wiring the Regulator box, or even removing it completely.
Ralph
Edited by Ralph Whitaker
Additional thoughts
Hi Stewart
firstly you need a decent, clear wiring diagram - http://www.advanceautowire.com/tr24a.pdf
Check that the fuse of the affect circuit has 12V on both ends.
Npw you can follow the wires down ther route through the loom and see where the 12V stops.
Do not forget to check where earth wires are attached to te body work.  You need a very clean connection/
Given the wiring has obviously been modified, there are a few things we need to know before anyone can make any sensible guesses.  A good start would be a set of sharp, clear photographs showing the under-bonnet arrangements from a number of angles.
Does the car still have a dynamo or has it been fitted with an alternator?
Is there still an ammeter?
Is the starter motor standard with the original type solenoid on the bulkhead or has a modern geared starter been fitted ?
( Those might sound irrelevant to the 'fault' but it can alter where power feeds come from. )
Power to the lights should not affect the indicators.  The only common point to those is as Roger said - they may share an earth connection.
By 'lights ' does that mean headlights too, or just the  side lights?   Do the brake lights work?
morning all.  It is on a brand new dynamo and no lights or indicators work. all bulbs work.  It has been rewired and I did find a loose connection toilet the rear of the ignition switch.  It came with two large expanded Haynes manual wiring diagram which as you all say refers to a two fuse system but infers that this was the "plan". Sadly he has passed away so I cannot ask him. This is the fuse box.  The brake light out feed shows permanent power but there is no the brake lights.  I have found a part solution to the rear lights and brake lights in a faulty connector but when replaced the lights and number plate light remain on all the time, brake lights work
  • 2 months later...
On 7/31/2026 at 9:27 AM, RogerH said:
Hi Stewart
Hello Roger,
I am curious as to why the TR4a wiring diagram shows eight instrument lights when the TR4a has 4 small instruments plus rev counter and speedo. What were the other 2 instrument lights used for?
Thank you
David F
Two lamps per gauge in the speedo and tacho.  One lamp in each of the small gauges
3 in the speedo if you include the high beam warning
17 minutes ago, RogerH said:
Hi Folks
Interesting. I have only one illumination bulb in both the speedo/tacho.
You will have only one illumination filament if it is a pressed steel case speedo/tacho on a TR4A
The cast case type used TR 2-4 had two illumination filaments per speedo/tacho.
