I have an issue with running hot.
I have always expected the wet liner 4 cylinder TR to run at just below to just a one 185°F.  Or 82°  C
What do others see as their everyday running temperature of their 4 cyl TR engine.?
I have reviewed and followed the advice here.
The temp gauge reading matches that of an IR temp reader and two capillary gauges that I have spare.   Top tank 99°c   Bottom tank 91°c   Side to side not equal much cooler at sides by 20-30°   (Upto 1 1/2” from side frame).  Centre not too different to top/bottom tank readings.   Wet box temp similar to surrounding tube temps.
Done today.
Head re-torqued.
Card duct in right place.   New hoses.   Coffee coloured plugs   No soot or oiling.   Tickover a nice steady 750 rpm.
test and replace thermostat   No issues.  Fitted both 82 and 72 just to see if they made any difference   There is no discernible difference   Tried both Waxstat and bellows construction.  Again nothing obvoios.
Restrictor fitted with 8-9 mm hole.
However……My  car runs at just under 3/4 hot on the gauge (200°f sort of).  It hits this temp quickly so I know the thermostat is functioning.   I have tested the thermostat and it does function as expected when boiled.   I have replaced it with a tested spare and the issue remains.
The car temp will only drop to just above 1/2 hot (185°f) if the car is running at a nice steady 60-70 on an open road.   As soon as traffic is hit the temp rises.   The electric cooling fan stops the car from overheating and pulls the temp down when sat in traffic.   So the fan is functioning.
The radiator does not over-boil.    Coolant is new Bluecol at 25% mix.
No water loss   No rising sump level.   No speckling on the spark plugs.
History.
The radiator was re-cored by Guildford radiator service 6 years ago (10k miles)   It took them 3 attempts to get a radiator built tgat actually fitted my car and allowed the starting handle to pass through.
Since the radiator was fitted the running temp rose visibly.  (Rad wet box not a wet box at all, just blanked off tubes in that stack) I also removed the oil cooler at the same time as fitting the radiator.
Water pump renewed by a Racetorations item.  No obvious changes apart from it not leaking.
Pressurised water expansion tank fitted, now removed without any change to running temp.
My next steps possibly are…..
confirm engine timing. And carb mixture.   Very long shot.
Do a boil and clean with proprietary radiator cleaner.
Refit oil cooler  or will this be masking another problem?
Replace radiator.   Duff re-cored unit that does not transfer heat as expected.
 ………or just ignore it.
Supplier info.      Does anyone have experience of Viking Radiators in Denham.?  I am loath to use Guildford again.
https://vikingradiators.co.uk
Edited by BlueTR3A-5EKT
Hi Peter,
Have you cleaned the radiator fins/vanes. They can collect a rather good insect collection.
I had my rad recored last Spring by Serck down Springfield road in Hayes.  They are NOT cheap
Since the recore the temp although not stable it does remain in a healthy position.
Roger
Sadly I think you are correct Marco.   I am trying all other possible routes before embarking on the mammoth job of removing the front of the car to change the radiator.
My guess would also be a radiator problem Peter, since changing the thermostat doesn't change anything.  -  maybe in the messing about you mentioned for the starting handle, they managed to block too many waterways in the middle of the rad.     Only 8 degrees difference top to bottom isn't good and probably the result of restricted flow. Sounds as though the sides are flowing better.
I used Viking rads. Chap works out of his shed as far as I could see. First attempt wept slightly but second has been fine so far. I'd use him again.
What's the restrictor for, is that standard?
Jerry
Edited by jerrytr5
Jerry
Thanks Jerry.  Real experience is very helpful
Jerry
You probably didn't see my edit: What's the restrictor?
Jerry
The restrictor is a simple plug the same external diameter as the internal diameter of the bypass hose.    It has  a 8-10 mm hole bored through it and is inserted in the bypass hose to reduce the flow of coolant from the  pump to the thermostat housing when a waxstat thermostat is fitted.   Triumph achieved this on TR4 A engines by reducing the diameter of the outlet bore from the pump housing.   Marco has a photo of the two housings next to each other to demonstrate the change.   The waxstat thermostat did not have the sliding blanking sleeve that closed off the inlet of the bypass hose when the thermostat opened, this is from the pump into the thermostat housing that the bellows thermostats had.  Hence the need to reduce the water flow if a waxstat thermostat is fitted.
From my experience, a 7-9 Deg C is about the expected average drop across the radiator. When doing heavy duty engine installations, that is what we aimed for. Of course that will depend on the ambient temp V the engine temp so calculations are done with the worst case scenario. The hole for the crank handle will reduce the flow through the rad by about 20/25% unless a flow around is built in. Even then there will be a small reduction.
The crank handle hole may well explain the rads center performance. The bypass reduction is to compensate for the wax stat thermostats inability to close off the bypass passage as the bellows type does. There must be some flow so the thermostat and temp sender can feel the current temp. WE tend to go for 1/4" to 3/16" hole. This bypass directs coolant from the thermostat direct to the water pump bypassing the radiator.
Given the info provided, I would agree with the general view that the radiator could be the problem.
Brian
Oh yes, I aim for mid 80'sC and use a 85 C thermostat with fan set at 87C
Edited by Trumpy3
Missed the actual question.
The bellows thermostst is a horrible plug for the flow.
And it can‘t close the bypass because there is a wide gap to the housing.
All about what the sleeve does is a nice wish.
AP1GczN6Cg6MFXbmNpAMZVMS9s7j0v6DzNdLeVCZ
By my measuring always never less of 30% of the flow goes the bypass, not the rad.
This is no problem, but the flow rate to the rad can be improved by a reduced diameter like Triumph did it with the TR4A
„Only“ 5 - 8 K drop of the temperature when hot is OK, more is worse. Why? If wanted I can explain.
Ciao, Marco
Edited by Z320
I use a blank with a 3 or 4mm hole, just enough to bleed air and allow a very low flow. I know one very quick TR4 that has the bypass completely blocked.
Both cars maintain running temperatures very well in all conditions.
1.  Is your temperature gauge reading correctly
2.  The satrting handle hole wont be helping the situation
3. It has been unusualy hot
Bob
Every engine „loves“ to have always any flow.
The bypass allows to heat the engine up to the same temperature everywhere.
My measurement with the 4A pump housing and wax thermostat showed
there is automaticly no flow via the bypass anymore, when the thermostat is fully open.
Hi Peter, you probably remember my wows with overheating for the C and B days in Richmond, I feel your pain. That was I remember a crap refurbished radiator, that you ID’d at the time.
Within the last 15 years I had my radiator rebuilt by Raysons in Yeovil. Apart from the header tank leaking, probably due to harsh roads on one rally, it’s been fab. Normal running temperature, is just below 185F on the gauge.
Run to Malvern was a warm day and the 110 miles was covered in just under 2 hrs and I never saw anything above this on the gauge. I don’t have a starting handle hole. I use a Revotec puller fan, which cuts in at approx 200F and drops the temp very quickly when in traffic.
If I leave the engine running whilst working on it in the shed, it warms up quickly, you can actually see the temperature gauge kick downwards when the stat opens, it will then idle for 10 or more minutes with the gauge moving very slightly back to normal ((185F).
My suspicion is the rad, as others have said, you have eliminated other causes.
It took me about 18 months and a huge amount of reading here and elsewhere to get the temperature in my 3A to the correct level. I particularly looked at the experience of owners in hotter climates.
Like others I agree that your radiator appears to be the root cause of the change to higher temperatures. But here are a couple of observations from my experience.
I installed the partial block in the bypass hose.
The starter handle hole does not help as it reduces the effective radiator area. I had this too.
I constructed a scoop at the base of the radiator to supplement directed airflow from the cardboard dam. An owner here had reported this on the Forum
I installed a high flow thermostat as used by Australian owners.
I also had an oil cooler in front of the base of the radiator. Research suggested that this created air turbulence between the two reducing air flow through the rad behind the cooler. Unless you need it, I would not add the oil cooler.  I enclosed the area around the cooler to the face of the rad (a sort of tunnel) to force air directly from the oil cooler to the radiator.
I installed a non standard otter switch to enable the electric fan to kick in earlier. I bought a cheap Chinese measuring device installed in the top pipe to the thermostat housing to identify at what temperature the thermostat was activating. I could then calculate the likely heat change down the radiator to help identify the appropriate rated switch.
I raised the rear of the bonnet slightly to try and improve hot air dispersal. There is no easy route for hot air to escape the engine bay. Not sure how effective this was because in theory escaping air would meet air forced down the windscreen.
Cleared as much crap as I could via the drain on the block followed by multiple flushes.
After all this the temperature rarely rose above normal.
Miles
Thanks all.
I too suspect the radiator but have ignored it as it was newly rebuilt at vast expense.   The car runs nicely but the running engine temp level is alarming as I fear the  day it overbloils.
I have always expected the TR to run at just below to just a one 185°F.  Or 82°  C
Radiator it will be I think.   Just need to schedule it in and get my willing fraternal volunteer on duty.   Plus source replacement radiator without starter hole.
Been out and tried it again this morning but it has not self repaired overnight   If fact the rear carb has git a strop on because of its perceived lack of being fiddled with and chose to leak from the float chamber   New needle and seat ha s fixed it plus ethanol proof flex hoses in case the insides were degrading and shedding bits of rubber   Yes it has NATO spec ethanol proof floats.
Timing is 10° BTDC at tickover   Max advance is at 3k of 30°  Vacuum advance is functioning.   Mixture at tickover fine   No plug whitening after high speed runs. All plugs same colour.  Bosch W8 BC fitted.
Yes the temp gauge looks to be accurate by comparison to Maplin hand held IR gauge and two NOS capillary units from other cars.   I just sat their bulbs in the header tank and all other temp readings were near enough to be the same.
The thermostat is Australian, a Tridon 82° item that I have tested and it starts to open at 82° and when the temp gets to 92° it opens so far it compresses the spring. - so fully open by 92°.    It was given to me by another forum user who was chasing similar issues.   I would say that was correct function.   (I had a job once testing thermostats for RR & Bentley spares.  The spec sheet for them gave similar function observation and temperatures)
The starting handle hole looks like there is a bypass around it but the thing is 2” wide so getting on for 20% of the radiator core tubes are compromised.
Yes the ambient temp has been high recently but the car engine temp I think is disproportionately high as it is running at getting on for 20°c above where I had hoped it to be.  Maybe my understanding of how ambient affects radiator cooling function is not correct.
The running at 60-70 mph on an open road always (pre radiator change) used to stabilise the temp at 185°f /82°c and you could watch the gauge needle ‘hunt’ up and down around that temp marker spot, as the thermostat presumably opened and closed.
Thank you Marco for the photos.
Timing is normally 4 degrees, BTDC have you tried that? Is the dizzy rebuilt by Martin to suit the engine?
4 degrees BTDC + 2 x 10° advance + 3° vacuum advance here,
10K for fully opening of the thermostst I can confirm by my own measuring with different wax thermostats.
One of Martin’s distributors specifically timed for the Tony Dean 2R cam that is fitted.  Max mechanical distributor advance centrifugal is 10°   (20° at the crank)
Standard distributor has 15° max centrifugal thus giving 30° at the crank   Add the 4° and for standard and you are at the best place for standard settings with regular fuel.
As you may guess I have trialled that timing change.
At 4° BTDC crank the engine is flat and lifeless using Martins distributor.   Tickover is silky smooth at that setting but pick up is dreadful.
The kangaroo petrol problem in first gear at low revs is reduced at less static advance but not eliminated.
Peter
sorry late to this one but if it’s any use to you my car typically runs around the 185f middle of the gauge when moving.
it can rise to the next temp gauge mark which I have always taken to be 207f where my electric fan cuts in from an otter switch in the Ali tube from the lower rad inlet.
I have a tr4 rad with a separate header tank and no starter hole.
my idle timing is about 20 (edit should say 10) deg and rising to about 33deg at 2.5. 3k
Edited by Hamish
1 minute ago, Hamish said:
Peter
my idle timing is about 20 deg and rising to about 33deg at 2.5. 3k
Thank you Hamish. Real:world experience there that matches what I had before changing radiators.
Peter
If you really want to cool it, fit a Volvo 240/440/740 radiator. That will change your problem ........ the problem will then be how to get it hotter.
Brian
