The fact that your car runs hot, but stable, makes me think something around marginal but still functional coolant flow.  As you're quite confident the passageways in the engine block are clear, my thinking continues to come back to the radiator.  I'll bet a nickel something is blocking one or more tubes in the core.
On my car, the problem was the overheating didn't just run a bit hotter -- it ran hot enough to puke coolant all over the place and then get *really* hot.  It had done this for years and with multiple rounds of cleaning/flushing the system (and a number of other things, just like your list).  The coolant always seemed to get rusty looking too soon for my liking.  So late last year I decided something was gonna give.  Serious boiling out, multiple times, with  a buffered citric acid=based cleaner and Evapo-Rust's Thermocure de-rustingformulation.  Then almost an hour of the car running with the garden hose inserted in the radiator filler extension and the petcock open at the bottom.  Until it ran clear.
Why was it getting rusty so quickly?  Dunno, but I'm guessing when the shop (a good one) rebuilt my engine c 2011-12 the block was not cleaned completely.
My last oil analysis (after multiple rounds of overheating and all that flushing) showed a tiny bit of water in the oil.  I have my fingers crossed that'll disappear the next time it's changed and analyzed and there isn't a new problem.
But the progression from crappy rusty looking to water white clear gave me enough confidence to put in coolant and proceed.  So far so good.  Temperatures below 185F and no rust in the tanks.
Thank you Don that is a very illustrated way to shew the improvements of the coolant post flushing.
I discussed cooling on hot state TRs with Bob Schaller and he condemned the locally sourced water for its chemical contents
Peter,
Another recommendation if you opt to redo the rad…
When I dropped off my chassis for blasting at Decorrosion Services in Chertsey (following your recommendation) I noticed GT  Radiator Services on the same estate. Old-school place full of radiators of all shapes and sizes from all sorts of machinery in for repair.
I had them re-core mine with modern spec core and opted to eliminate the crank handle hole.
The result has been very good. Temp sits halfway on the gauge and deviated by only a needle’s width in traffic on the hottest days this summer.
Ben
I have had several radiators done by Frank of Viking Radiators. They only use top quality cores and make a good job. Father and son outfit going back years so know their business.
Regards Harry
While we are recommending radiator restorers I have used Guildford Radiators (actually in Cranleigh) on two occasions,
once for my 1935 Hillman rad, & once for the TR rad.  Both excellent jobs.
Peter
I mounted it cross wise. Inlet top left and outlet lower right. Unfortunately I do not have any photos, a computer crash lost them. I do plan to take some next time the nose is off. I will pull the grill and take some from the front.
The width of the radiator is about 11/2" under the distance between the inner guards so a length of alight aluminum angle attached to the inner guards acts to locate it. Its height is lower than the TR unit but with a fabricated lower mount Basically a length of aluminum angle attached to two short lengths square tube attached to the original chassis mounts, it sit nicely under the cars nose. This is attached to the rad utilizing the mounting tags on the rad.
Coolant connection is more complicated but not difficult. I have an Davis Craig coolant pump mounted on and under the left side of front cross brace. Utilizing the original steel coolant pipe that took the coolant from the rad outlet, I connected this to the Volvo rad outlet with an original 90 Deg lower rad hose. For me , this fed straight into the electric pumps inlet and the pups out let is straight up and connects to the block inlet. To achieve this I removed the original water pump and housing and fabricated a blanking plate with a suitable pipe to connect to the electric pump outlet.
Connection of the thermostat was simply two 90Deg hoses with a short connecting pipe. For me that was a plastic fitting with a temp sender fitted.
Next was the reserve/expansion tank. For this I utilized a late 90's Volvo unit attached to the front apron cross brace with a simple bracket. To connect this to the radiator I used the hose that came with the second hand tank I purchased and it fitted without any mods. This serves as the fill line which the system uses to fill. A vent line is then taken from the tank to the top right of the rad. In use, this line takes a constant flow from the top of the rad to the tank. this is then replaced by flow through the fill line.
I use a 10lb rad cap. The electric fan is a puller mounted on the top and bottom frame of the radiator. The bypass outlet of the thermostat housing is utilized to mount a temp sensor for my ECU. A 84deg thermostat is used.
To be honest, a well fitted TR rad should do the job although I am comfortable sitting in heavy traffic in over 40C. For me this was an interesting project and much more reliable than the TR unit. Much cheaper as well. My cost was around $400 less than a re-core. An interesting point was the warranty offered on new radiators from my suppler. 12 months for an all aluminum unit or a brass one. 24 months for an aluminum and plastic one.
Will post some photos when I can take some Happy to answer any specific questions
Edited by Trumpy3
correction to detail
Work in progress.
3 hours to get to this point.   Hoses yet to disconnect and then remove Revotec fan unit.
4 minutes ago, BlueTR3A-5EKT said:
Work in progress.
Slow coach, At Malvern one year we bet Phil Tucker he couldnt get the front off his 3a in an hour in the main ring and he did manage it.
14 hours ago, Trumpy3 said:
Peter
Thank you Brian.   That gives me me options to consider
Here's the Tech Q&A article published in the latest (August 2026) issue of the Triumph Register of America Newsletter.  Seemed relevant to this thread.
Edited by Don H.
Thanks for that Don.
Stuart. It took me another hour to get the radiator out.  Stupid bolts that hold it in the chassis. Fit studs is the solution
On 8/28/2026 at 11:00 AM, BlueTR3A-5EKT said:
...Stupid bolts that hold it in the chassis. Fit studs is the solution
The TR Register Australia used to have a public tech tips section on their website, but it seems to be gone now.  One of the tips was this one posted on here by @Trumpy3 -- slotting tops of the bottom bolts so they can be tightened or loosened with a screwdriver from up top.  A wrench or socket on the bottom can be used for final torque or release.  I did that to my car years ago and it indeed makes it easier to slot the tops of the lower radiator bolts.
Edited by Don H.
Yes we have had this tip before on here. As it’s something I have done in the past.
Was a tip from Fireman some years ago iirc?
On 9/1/2026 at 2:31 AM, BlueTR3A-5EKT said:
A photograph example from my brother yesterday.  IMG_1659.jpeg.c8901f08366ae2fbee010bf131cd99b0.jpeg
Yes, that's it.  Looks terrific.  The Wigglesworth brothers are better machinists than I am!
  • 2 months later...
Spent the day fitting an old but sound spare radiator to prove the cooling inefficiency of the existing radiator that has a starting handle hole.
Yes better.  Flushed using Prestone product.   Thank you Don.   Better still   There was a tinge of discolouring in the drained coolant/cleaner.   No reduced flow from the block drain.
Jury rigged the sucker electric fan in front of the radiator.   Damn, that  warmed the garage up when it kicked in.
The current radiator is now away for recoring without a starting handle hole.  We have proved it is not the engine adding to the overheat issues.
Peter
Great, nice simple and quick fix.
Brian
Hi Peter, we’ve just returned from a Rally in the French Alps. Temperature gauge showed a needle width below 185,  unless on the one occasion when  we were stuck in riot traffic🫣,it then rose until the Revotec kicked in. My rad was re cored without a starting handle hole 15 years ago ( ?)
As an aside we covered 2018 miles, averaged 32 mpg, and used/ lost 250 ml of oil.
Iain
Ps Third in Class (17 in class)
Thank you Brian and Iain.
Iain.  Do you know what temp thermostat you are running?  Do you also have an oil cooler?
We tried different temp thermostats and confirmed an 88 degree significantly raised the engine running temp, as it should.  The standard 82 sets the running temp at or just below 185 on the gauge.  The place it should be for driver comfort.  We tested 2 other capillary temp gauges to prove the one fitted in the car was not misreading.
Hi Peter
no oil cooler and i'm pretty sure its an 82C stat, with a partially occluded bypass.
I did have some trouble 18months ago, when the capillary broke on another rally and i had the gauge refurbished......it never read correctly, i used my Infra red gauge until i was blue in the face taking comparative readings and eventually convinced it was the gauge at fault, paid for another gauge. This was then tested  back to back in a kettle and lo and behold the refurbished gauge was the issue, again using the IR meter to check what was going on. After these tests the refurbisher credited me.
Cheers
Iain
2 hours ago, iain said:
Hi Peter
Cheers
Iain
The gauges are quite easy to calibrate yourself, fill a jug with hot water from a kettle, & adjust the temperature (read using a known good thermometer) to 185°F
remove the bezel & glass from the gauge, dunk the sensor end into the water, then push the needle left or right till it reads 185°.  Replace glass & bezel.
Hi Bob
i might have attempted this but it was erratic, which I never understood, sometimes over recording and others under….I have no idea how that could happen?
cheers
Iain
