Richard B 2.5PI Posted August 19 Report Posted August 19 I see the TR5 has a 7lb radiator cap, whereas late TR6's have a 13lb cap. Can the TR5 take a 13lb cap or will something break? Quote
Z320 Posted August 20 Report Posted August 20 I use a 13 PSI cap on my TR4A without problems. Make sure a wax thermostat is fitted and not a bellows thermostat (not period, but I found one on a friends TR6). Anyway, the rad is 50 years old and it should not leak, but it can happen. Ciao, Marco Quote
stuart Posted August 20 Report Posted August 20 (edited) 20 hours ago, Richard B 2.5PI said: I see the TR5 has a 7lb radiator cap, whereas late TR6's have a 13lb cap. Can the TR5 take a 13lb cap or will something break? When replacing your cap make sure its whats known as a "Recovery cap" Thats the one with two seals, one on the sprung end and another under the cap itself. Buy good quality ones as Ive come across ones where when you screw them down the top seal under the cap bunches up and literally jams the sprung part of the cap solid so pressure cant escape. Stuart. Edited August 20 by stuart Quote
Richard B 2.5PI Posted August 31 Author Report Posted August 31 (edited) Thanks for the advice. I have now bought a Serck 7lb cap with the two seals. The old cap had fallen apart. Going to Malvern on the Friday, the TR ran very hot showing 3/4 to 7/8 on the gauge, the outside temp was circa 33-35 degrees and there was a lot of traffic jams coming from Sussex. I had to stop a couple of times at services to let it cool down and I added a pint of coolant each time. We had the heater valve open and on as well, which did help the engine, but not us! The return journey was much better on the Sunday, 25 degrees outside and the gauge ran in the middle with no coolant lose at all. I had flushed the system before the weekend and gave I it a second flush on return. I am now considering a re-cored radiator. Edited August 31 by Richard B 2.5PI Quote
Waldi Posted August 31 Report Posted August 31 Richard, You can do a couple of other things first: 1) Check the thermostat in boiling water: at what temperature does it open and when is it fully open (and does it go fully open?). 2) Remove all water hoses (including disconnection those to the heater matrix) and drain valve (block rhs) and poke with a fresh water hose until only clear water comes out. 3) Next: Flush the radiator and block with a cleaner (I used citric acid for the radiator). 4) Do you have a radiator cowl (like the paper card board item on a TR6), to avoid circulation of hot air? Waldi Quote
Z320 Posted August 31 Report Posted August 31 Hi Richard, what you are telling us is a bit „foggy“. Can you give us some more Information, please. Ciao, Marco Quote
Richard B 2.5PI Posted September 2 Author Report Posted September 2 To summarize; 2500 PI engine runs too hot when the ambient temperature is above 33-35 degrees. Engine is mildly uprated, 6-1 Revington extractor manifold, not sure what cam, but ports have been flowed. The cooling system has been flushed twice (so far) and the water was rusty. A cooling cowl is fitted around the radiator The standard mechanical fan is fitted No electric fan. Should I go for a re-cored radiator, or aluminum radiator. or is additional cooling required? Quote
Paul Hig Posted September 2 Report Posted September 2 19 minutes ago, Richard B 2.5PI said: To summarize; 2500 PI engine runs too hot when the ambient temperature is above 33-35 degrees. Engine is mildly uprated, 6-1 Revington extractor manifold, not sure what cam, but ports have been flowed. The cooling system has been flushed twice (so far) and the water was rusty. A cooling cowl is fitted around the radiator The standard mechanical fan is fitted No electric fan. Should I go for a re-cored radiator, or aluminum radiator. or is additional cooling required? On my 6 (same engine) had to flush system several times to clean. also added an additional thermostatically controlled fan in front of radiator. All appears to work well (so far 🤞). Fan has only cut in when sitting in traffic, otherwsie find standard fan keeps things within range Quote
Waldi Posted September 2 Report Posted September 2 Richard, Have you removed the hoses to properly flush the block and radiator? And have you checked the thermostat? And did you chemically clean the radiator with citric acid (or a similar product)? Waldi Quote
Z320 Posted September 2 Report Posted September 2 Hi Richard, how does the front side of the rad looks like (insects, dust)? Quote
