Z320 Posted August 25 Report Posted August 25 Today I tested the Golden Lucas and had some starvation when I wanted to rev up the engine uphill. Pluged back to my old Blue Bosch and had no problems anymore. This can be by accident and maybe has no causal relation. Quote
Stéphane Posted August 25 Author Report Posted August 25 Je vais la mettre à l interieur de l habitacle, plus frais que dans le moteur. Petite bouche, petite aération. Il fait chaud devant.Sous le tableau de bord facile d'accès au cas où ! Quote
RobH Posted August 25 Report Posted August 25 Eh bien, c'est nouveau. Ça fonctionnera je suppose, mais il n'y aura pas beaucoup de circulation d'air. Êtes-vous content d'avoir un très long câble HT qui passe dans la cloison? Il y a déjà beaucoup de choses en travers du chemin : la boîte à pédales, la colonne de direction, les tuyaux de chauffage, etc........ Quote
Z320 Posted August 26 Report Posted August 26 (edited) Hmmmm, I don’t know for sure and I don’t like people telling „I don’t know, but I can imagine…..“. This time I do it anyway: fitting the coil in the footwell possibly brings other problems. #1 If this would give any benefit and work well, producers would have done this in 150 years of car history. #2 The condenser close to the points and the ignition coil is a oscillating circut, the lenght and diameter of the cables may rule #3 This gives a strong (?) magnetic field close to you and electronic devices (navigation system, radio, mobile phone, pacemaker) Test it, surprise us and be prepared. Ciao, Marco Edited August 26 by Z320 Quote
RogerH Posted August 26 Report Posted August 26 11 hours ago, Stéphane said: Je vais la mettre à l interieur de l habitacle, plus frais que dans le moteur. Petite bouche, petite aération. Il fait chaud devant.Sous le tableau de bord facile d'accès au cas où ! I really would nt do that. The coil, Dizzy, points, capacitor all need to be close together - they are gregarious. Don;t argue, just do it. Roger Quote
Ralph Whitaker Posted August 27 Report Posted August 27 On 8/24/2026 at 6:52 AM, Ralph Whitaker said: I had the coil fail this year, after a 15minute blast up the M62 on the way to the start of the East Coast Run. It was six years old and had done approx 10,000 miles. Luckily I carry a spare of the same make, unbranded and bought from Powerspark. I have replaced the spare in my boot with one bought from The Green Spark Plug co, it is a Remax (remember them) branded coil and is supposedly made in England. Much is made of this fact on the website and all the boxes pictured say "made in England" on them, however I am not so sure, as when mine arrived the box no longer says this on it. However I am hoping that the price, £36 , is an indication of quality. Ralph As a follow up from this I asked the Green Spark Plug co whether the coils were indeed still made in England and the reply was that they were as they actually visited the factory where they are made. The "Made in England" has been removed from the boxes as the same boxes are used for some other products that are made in the EU. Ralph Quote
Stéphane Posted September 10 Author Report Posted September 10 (edited) Bonjour, Je mets la bobine en bas de l'aile le plus près du radiateur avec une manche d'air pour la ventilateur. Je garde ainsi la longueur du câble de la bobine. Photos à venir. Essais semaine prochaine. Mon moteur chauffe très fort. Tout est neuf avec 1200 miles, peut être une cause du problème !! Il faut que ça marche, car elle fait un concours d'élégance le 20. À bientôt Edited September 10 by Stéphane Photo Quote
Stéphane Posted September 23 Author Report Posted September 23 Bonjour, Concours élégance, nous avons fini premier. Le jour de ces 72 ans, un beau cadeau. Même des Mariés ont demandé la photo souvenir. La bobine est dans le nez, à côté du radiateur. ça marche ! Je ferais une photo..Merci pour vos conseils et discussions,; que du plaisir. See you. Quote
Stéphane Posted September 23 Author Report Posted September 23 Premier devant une rolls royce!! Quote
Stéphane Posted September 23 Author Report Posted September 23 Évidemment avec la référence de Ken Richardson pour l'historique. Quote
Stéphane Posted September 23 Author Report Posted September 23 Et l'immatriculation commencent par GB ,même si plus d actualité. Quote
stuart Posted September 24 Report Posted September 24 (edited) Congratulations, Stuart. Edited September 24 by stuart Quote
Stéphane Posted September 28 Author Report Posted September 28 HMerci Stuart, Voici la photo de la bobine mise dans le nez. Bien ventilé avec l'ouverture supérieure et à côté du ventilateur. Pour l'instant ça marche. Évidemment j'ai une deuxième bobine dans le coffre. Bien roulé ce week-end. À bientôt Quote
BlueTR3A-5EKT Posted September 29 Report Posted September 29 (edited) With the coil fitted there I would install a waterproof cover from a classic Mini. That will eliminate any chance of the coil being soaked and short circuiting by rain water coming through the grille. https://www.minisport.com/mini-ignition-coil-rubber-cover-8g727.html Edited September 29 by BlueTR3A-5EKT Quote
Stéphane Posted September 30 Author Report Posted September 30 Excellente idée, surtout chez moi il pleut souvent le temps du nord !! (frenshglish). Merci, Je m'en occupe avant une nouvelle panne. See you Quote
Stéphane Posted October 12 Author Report Posted October 12 Hello, Reçu la tête de bobine, merci encore pour ce conseil et adresse. Je vais la monté. Pour l'instant ça roule, pas de surchauffe ! See you Quote
