Ecosse Posted August 27 Report Posted August 27 Good Afternoon All, Just checking the car over for the Bo'ness Hillclimb next weekend only to find the speedometer cable has given up the ghost, apparently new cables are currently unavailable. I am driving the car to the event and do not want to fall foul of the law, it is not the most inconspicuous of cars. Could anyone advise of the engine revs at 70mph on a 5-speed car, I should have paid more attention and cannot quite remember the revs. Thanks, Cliff Quote
john.r.davies Posted August 27 Report Posted August 27 Cliff, The Googler Ai says: "A factory-specification Triumph TR7 with a 5-speed manual gearbox typically revolves at approximately 3,000 RPM at 70 mph when in 5th gear. [1, 2] The exact engine speed depends on the rear axle (differential) ratio equipped on the specific vehicle model: [1] Standard UK / European Models (3.90:1 Differential) Revs at 70 mph: ~3,000 to 3,100 RPM Most factory 5-speed cars utilize a 3.90:1 final drive ratio coupled with a 5th gear overdrive ratio of 0.83:1. On standard 185/70 R13 tyres, this translates to roughly 22.5 mph per 1,000 RPM, placing the engine right at the 3,000 RPM mark at highway cruising speed." Hope that helps. Certainly Gareth Thomas' "Tuning Manual" says that a 4.11 diff (only a little higher geared than yours) will do 24mph/1000revs, so at 3K, 72mph John Quote
jerrytr5 Posted August 27 Report Posted August 27 I had a similar problem Cliff. I fitted a digital GPS speedo. Works a treat, I probably won't bother fixing the cable. https://www.ebay.co.uk/itm/204714109382 Jerry Quote
Ecosse Posted August 28 Author Report Posted August 28 Good Morning John and Jerry, Thanks for your replies, much appreciated, I have just ordered a digital speedo. Cliff Quote
