Some time ago I fitted a used TR5 oval washer bottle and pump assembly to my car and  it has worked well for years, although I have had to replace the pump motor once. Recently I found that I have to operate the switch three or four times before cleaning jets emerge. The reservoir is full and both jets are clear, has anyone ever had this issue and found a solution?
2 hours ago, Peter V W said:
Tim, this is a later Lucas pump if you are not worried about originality.
Peter
Thanks Peter, that looks very much like the replacement motor I fitted, it pumps well, it just takes a few goes before it works.
2 hours ago, RogerH said:
Hi Tim
are you using decent screen wash  - not dodgy soap suds.
No soap suds Roger, just Lidl's finest Screen wash at £2.99 for 5 litres as I recall and good down to -5 degs C.
Does it have a non return valve on the bottom of the pickup pipe in the tank? They stop it draining back so its then all held in the pipe work but often become problematical as they clog up with the usual gunge that accumulates in the bottom.
Thanks so much Stuart - no it doesn't have a non-return valve to keep the tubing primed, as usual it sounds like you have come up with the answer! I will source a valve and report the outcome.
