Rich Horton Posted September 4 Report Posted September 4 Morning All, I've taken delivery of the autodoc driveshafts and ordered the TR6 front wheel studs from Rimmer to fit and have found that they seem very tight to insert and all I'm achieving is to flatten the stud splines as per the attached photo. Is this normal and should I proceed or is there a problem? The hole in the hub appears to be 12.5mm and the stud 13.3mm so 0.8mm difference. Its also a fair bit shorter and when taking the hub thickness into consideration ( they are very close ) i think I'll have nearly a cm less of thread for the wheel nut. any advice would be gratefully received. Quote
Chris Hale Posted September 4 Report Posted September 4 They should pull in if you pull them through with a nut. Make sure you are pulling them in square. If they are a cm shorter then you may need to get some longer studs as you should be able to get a minimum of 8 turns of the wheel nuts once the wheel is fitted before they start to lock up Quote
stuart Posted September 4 Report Posted September 4 (edited) I’ve never been keen on their studs as they seem to be made of cheese. Picture below of original front stud lengths. If I need longer studs for Minilites etc then I buy mine from Cambridge motor sports as they’re also made of good steel.https://cambridgemotorsport.com/classic-historic/12564-tr2-6-1-2longer-wheel-stud.html Stuart. Edited September 4 by stuart Quote
BRENDA1 Posted September 4 Report Posted September 4 Looks like you could do with a new tape measure soon. 😂😂 Mike Red Rose Group Quote
PodOne Posted September 4 Report Posted September 4 Nothing wrong with a well matured tape measure 😁 Quote
trchris Posted September 4 Report Posted September 4 They are a tight fit l drifted mine in however a fellow member slightly increased the diameter in the hub Chris Quote
stuart Posted September 4 Report Posted September 4 (edited) 39 minutes ago, trchris said: a fellow member slightly increased the diameter in the hub Chris I wouldnt, they do need to be a very tight fit or they may slip. Thats what the knurling is for, to grip the hole. Stuart. Edited September 4 by stuart Quote
trchris Posted September 4 Report Posted September 4 Indeed Stuart l did raise an eyebrow or both, as a post drift l was told some of the usual suppliers are now selling these identical drive shafts at a hefty profit margin Chris Quote
stuart Posted September 4 Report Posted September 4 7 minutes ago, trchris said: as a post drift l was told some of the usual suppliers are now selling these identical drive shafts at a hefty profit margin Chris Of course they are, Im surprised AutoDoc havent run out of them by now😉 Stuart. Quote
Mike C Posted September 4 Report Posted September 4 6 hours ago, stuart said: I wouldnt, they do need to be a very tight fit or they may slip. Thats what the knurling is for, to grip the hole. Stuart. +1 Quote
DRD Posted September 5 Report Posted September 5 20 hours ago, stuart said: I’ve never been keen on their studs as they seem to be made of cheese. Picture below of original front stud lengths. If I need longer studs for Minilites etc then I buy mine from Cambridge motor sports as they’re also made of good steel.https://cambridgemotorsport.com/classic-historic/12564-tr2-6-1-2longer-wheel-stud.html Stuart. The trouble is longer studs won't easily fit in without some surgery on the stud head or the outside edge of the hub disc. Quote
stuart Posted September 5 Report Posted September 5 3 hours ago, DRD said: The trouble is longer studs won't easily fit in without some surgery on the stud head or the outside edge of the hub disc. They only nee a little grinding off the edge of the flat, I have used them before.It doesnt compromise fitting. Stuart. Quote
Slantfour Posted September 6 Report Posted September 6 I bought mine from Robsport, no issues inserting them and tapped them nicely into place. All sorted now, just need to tighten the 'Jesus Nut' to the correct torque. Quote
wheeler Posted October 15 Report Posted October 15 I have fitted the AutoDoc CV drive shafts, everything went well until it came to fitting the wheel studs to the new hubs. Tried to drive them in with a drift and press them in with my large vice, all failed to fully insert them. Finally I bought one of these from Amazon and used with an impact wrench the wheel studs pull in nicely. Bill https://amzn.eu/d/0hYqmpJZ Quote
stuart Posted October 16 Report Posted October 16 16 hours ago, wheeler said: I have fitted the AutoDoc CV drive shafts, everything went well until it came to fitting the wheel studs to the new hubs. Tried to drive them in with a drift and press them in with my large vice, all failed to fully insert them. Finally I bought one of these from Amazon and used with an impact wrench the wheel studs pull in nicely. Bill https://amzn.eu/d/0hYqmpJZ But thats for metric studs. Stuart. Quote
BlueTR3A-5EKT Posted October 16 Report Posted October 16 Would a quality one of these push the studs in? Quote
wheeler Posted October 16 Report Posted October 16 9 hours ago, stuart said: But thats for metric studs. Stuart. Hi Stuart, I should have explained, the device comes with metric wheel nuts which I discarded and used one of the TR6 wheel nuts, works fine. Bill Quote
dblenk Posted October 18 Report Posted October 18 On 10/15/2026 at 7:20 PM, wheeler said: I have fitted the AutoDoc CV drive shafts, everything went well until it came to fitting the wheel studs to the new hubs. Tried to drive them in with a drift and press them in with my large vice, all failed to fully insert them. Finally I bought one of these from Amazon and used with an impact wrench the wheel studs pull in nicely. Bill https://amzn.eu/d/0hYqmpJZ Bill you changed the nut then ?? David Quote
wheeler Posted October 19 Report Posted October 19 Hi David, yes it comes with metric nuts for modern cars. I just used a spare TR6 wheel nut to fit the new wheel studs. Bill Quote
