I'm rebuilding an engine for my TR8 : I bought this TR8 coupé (a very early factory model) several years ago, minus engine and gearbox, and would like to built the same 3L5 engine as in my TVR350I.
The TVR engine output is 197hp, that's far enough for me : very smooth AND healthy, able to "sing" beautifully 'till nearly 6000Rpm.
Obviously, the camshaft in my TVR engine is not a Range Rover camshaft (TVR 3L5 engines were built from RR new engines by the factory), neither the same as a TR8.
I have to find the right one :
- V8 Developments "Stealth" camshaft   Edit : can't use this one, as it need pockets in the piston head for valves clearance. The V8 developments MC1 camshaft has lower lift, so is a option.
- Newman Ph2 camshaft
- Kent H214, 218 or even 224
Or any other one who don't come up to my mind.
Again, I don't want to make a race car, but something with very similar performances to my TVR350I.
NO, increasing the engine capacity is not an option I will consider.
Thanks for sharing your experiences !
Edited by Chris59
Many years ago (1980s) I had a 214 cam fitted to my 3.5 Rv8 and from what I remember it was a good all rounder. I might have had to shorten the valve guides slightly to allow the spring caps to clear the valve guides at full lift, but it didn't need the spring seats machining to prevent coil binding. I have a Stealth cam fitted to the 3.9 in my Toledo, but that needed the spring seats machining as well as the guides.
The piston cut outs were actually really easy and cheap to do, I make cutters from valves by cutting teeth into the edge of a pair of  valve heads, I used a slightly oversized inlet valve for the inlets and a narrowed inlet valve for the exhaust. Grinding the top of the valves into a triangular shape grips the chuck of an electric drill really well, and the head is used as the jig to hold the valve in the correct position. Takes a few seconds per cylinder once the head is loosely bolted down.
Done several Stag engines the same way, but that needs a cut down head due to it being overhead cam
Thanks for this interesting reply.
I also have to find a new camshaft for my TVR350I, but I'll only swap it for another one + followers, I won't remove the heads or even take the engine out of the car.
In this engine, there is no pockets in the pistons, and I certainly won't remove the heads to modify the valves guides, so I've to find a camshaft very similar to the TVR one.
I'm still waiting for a reply from Kent about the modifications required by their camshafts, but V8 developments tell me their MC1 will be a straight fit.
Edited by Chris59
