PanJH Posted September 15 Report Posted September 15 I noticed leaks on the aluminum radiator on my sort of new to me TR3B. It has an aluminum radiator and there is fin damage near the area of the fan and it's leaking coolant. I'll be taking the radiator out tomorrow and take it to a local shop to have them look it over. I also looked online and see replacement radiators from $200 to over $1000. I'm wondering if replacementisn't a better route than repair and if so, what replacement would be a reasoanble one to install. With such a wide price range, I'm sure some of those listed online are junk and some are just over priced... what ones are a good value/ work good ? Quote
Don H. Posted September 16 Report Posted September 16 The very lightly used Wizard Cooling aluminium radiator I had on my TR3B got schlepped from the US to Goodwood as a gift for a mate’s TR3A. I went to a re-cored original radiator. The aluminium one just never looked right in the TR3B’s otherwise largely original engine bay. Brass is likely a lot easier to repair. Most moderns with ally radiators just get a new one (often with crimped-on plastic tanks. Quote
Richardtr3a Posted September 16 Report Posted September 16 I will look tomorrow , in the garage, and find out which company helped me with my radiator repair. Richard Quote
Richardtr3a Posted September 17 Report Posted September 17 I have checked my old invoices and seven years ago my radiator was repaired by :- Guildford Radiators, unit 10, Littlemead Ind Est, Cranleigh, Surrey GU6 8ND 01483 27771 . In Cranleigh not Guildford !! My radiator was repaired and upgraded with extra fins. Before that I had a blank cap on the radiator and an extension pipe to an extra pressured small container in the engine bay. I spoke to Guildford Radiators this morning and they are very helpful. I also have a list of other repairers who supplied me with proper quality parts, new or overhauled Good luck Richard . Quote
RogerH Posted September 17 Report Posted September 17 Hi Richard seven years is not a particularly long life for a repaired radiator done by a competent repairer (depending on what was wrong) Are there others you can take it to. Roger Quote
Richardtr3a Posted September 17 Report Posted September 17 Hi Roger, This thread was started by PAN JH and he has a problem. My radiator was rebuilt and It was seven years ago and there have been no problems since. I am expecting another long spell without needing any repairs. I do not need to take it anywhere at all. Richard Quote
BlueTR3A-5EKT Posted October 4 Report Posted October 4 I am at the point of pulling the trigger on getting my original radiator recored. Now to find a recoring company who want to do the job and understand my requirements It was recored 7 years ago with a starting handle hole and the car has run over hot ever since. This summer has just exacerbated the engine running temperature with the radiator electric fan being on continuously, even at motorway speeds. No the engine is not knackered and all running adjustments are ok. Ie fuel and ignition. Using an infrared red temp gauge on the radiator core displayed the centre vertical 3” of the radiator to be 20° c hotter than the rest of the radiator core. That temp being the same as the header tank and vehicle thermostat temp gauge. My decision is to dispense with the starting handle hole as I can turn the engine over using a socket spanner on the front crank bolt. The likelihood of needing to hand crank to start is quite a distant one The gain in cooling I hope for should negate the requirements of an oil cooler. This is based on my brothers 3A with a rebuilt engine and a full width radiator core without starting handle hole. Quote
Trev Good Posted October 4 Report Posted October 4 Check which aluminium radiator you have! Is it British, European, or a cheap Chinese one? The British and European ones can and should be repaired, the Chinese ones are rubbish and should be replaced! Quote
Lebro Posted October 4 Report Posted October 4 Guildford Radiators (in Godalming!) did a good job on mine. Not too far from Keith. Bob Quote
BlueTR3A-5EKT Posted October 4 Report Posted October 4 21 minutes ago, Lebro said: Guildford Radiators (in Godalming!) did a good job on mine. Not too far from Keith. Bob That is who built the radiator I have that causes hot running. It took them 3 goes to get the starting handle hole in the right place. I think that they just gave up and cut a hole and blocked the tubes on my radiator. Quote
harrytr5 Posted October 5 Report Posted October 5 Try Frank (Viking Radiators) Denham. 01895 831300 Great company and have used them many times. Frank will sort you out and knows his business. Regards Harry Quote
BlueTR3A-5EKT Posted October 5 Report Posted October 5 15 minutes ago, harrytr5 said: Try Frank (Viking Radiators) Denham. 01895 831300 Great company and have used them many times. Frank will sort you out and knows his business. Regards Harry Thank you Harry. Quote
